06-16-2016, 06:52 AM | #23 |
Rep 433
its not a wind up .... I studied psychrometrics for 10 years and then taught it for 10.
Then I got a life and bought a BMW....
David - Bored with Audi
MY2019 X3 40D M-sport with all the toys. Also a Mini CS for the wife and me to play in at the weekends |
06-16-2016, 07:00 AM | #24 | |
Rep 92
If I'm doing something wrong I would rather know. I'm of old school with air con thinking it will dry my throat etc. |
06-16-2016, 07:43 AM | #25 |
Rep 32,881
I sometimes get instant dry eyes when I go in a shop with AC on, it's never happened in a car for some reason though!
06-16-2016, 04:39 PM | #29 | |
Rep 15,858
You've had some well reasoned answers to the issue. Even with the system adjusting through a pre-determined progression of adjustment to try and respond to the signal from the anti-fogging/condensation sensor, it can't dry the air sufficiently through air flow alone. I'm in the Scottish Highlands and push the limits of any Climate Control system through the seasons, on many occasions. Seen the limits of HVAC systems in many cars, when you try and shortcut the full function. Using the A/C function is the simple answer, let the HVAC system do its job easily and as designed, when conditions place more demand on it. There is one factor not mentioned by others which can impact on humidity into the cabin. There is a lot of 'content' to our current systems. They are deeply embedded into the bodywork. Heat soak from the engine bay with damp air doesn't do us any favours, we hit conditions where we need a little help to dehumidify the air. There is the possibility of water ingress. Check out the drains from screen water drain off, for debris, etc., just to be sure it isn't simply moisture overload around the air intake. |
10-29-2016, 05:31 PM | #30 |
Rep 333
I'm starting to get condensation issues.
I don't really like using Air Con unless it's in the rain as it clears my windscreen and keep it clearer during a journey although recently I had to use it every time I drive When I leave my air con on it makes my car feel sluggish and I have resulted to use sport constantly which I feel is unnecessary daily practice ? Maybe leaving the air con on in 6 pot bmw might be better because you won't feel the reduced Bhp although certainly in mine you do. Looks like I may have to visit the service department for solution unless someone has alternative idea what my problem is for example, my climate settings. |
10-29-2016, 06:25 PM | #31 |
Rep 427
My experience...
I only use aircon when the weather is hot. Occasionally run it during the winter to ensure its working. (It should be run, at least occasionally). The car windows never mist as long as the cabin re-circulation button is set to off. (No green light on an E90). If it is on, continual re-circulation quickly increases humidity in the cabin and the eventual result is misting. If the aircon has been on for a while, and then you want to switch it off, it is usually necessary to dry the cabin filters out for a while, to stop misting. Do this by putting the heating and fans on high (25+ degrees) for a few minutes (aircon switched off) when the engines warm. (Be careful and open the windows, since this can cause serious windscreen misting). It will clear after a few minutes. Will usually get rid of the smell as well.... You can then set back to normal temp and fan speed, but make sure the re-circ button lamp is off. This wont be necessary again until after the aircon has been used again. If you prefer re-circ air or auto mode, you will have to have the aircon on.
F30 Estoril Blue 335D MSport.
Geo's comps56.00 |
10-30-2016, 01:23 AM | #32 |
Rep 403
This Never turned air con ok let's give it the proper name "climate control" off ever in about 10 years in any of my cars Why do people still think air con is used to keep you cool on the odd hot day? If that were the only benefit no one in the uk market would every buy it. We don't get any hot days Leave your climate control ON all year round and just vary temp with seasons and you will never see misty windows whilst driving. |
....,,,,..,,..6732.50 |
10-30-2016, 02:34 AM | #33 | |
Rep 333
My other half has a mini (with climate control) and she never uses the aircon and her windows stay nice and clear. So this is why I think it's fault on my car because surely the mini and my car uses the same system. |
10-30-2016, 03:16 AM | #34 | |
Rep 20,651
http://www.edn.com/design/automotive...control-system As well as keeping us drivers and passengers at a temperature we like, it also serves to keep the humidity levels constant. So this time of year it spends most of its time stripping out that water moisture. Just leave the bloody thing on auto and do not touch it ever again, oh and just set the fan to a low setting as well - sorted. |
Geo's comps56.00 |
10-30-2016, 12:40 PM | #35 |
Rep 427
Switch it off!
Leave the circulation control on fresh air. Have the extra 5 horsepower going to the wheels
Geo's comps56.00 |
10-30-2016, 05:41 PM | #36 |
Rep 333
10-30-2016, 06:02 PM | #37 | |
Rep 15,858
Autumn... leaves? Seriously, blocked airflows and water drains can be a cause, if changes in function occur this time of the year. Some conditions simply overload the HVAC system without A/C support. |
