07-03-2016, 06:26 AM | #1 |
Rep 93
Tracking / wheel alignment
I'd like to check the front wheel alignment on the f30. Do the string methods actually work for checking at home?
07-03-2016, 09:43 AM | #2 | |
Rep 15,858
I've used string lines on my current F11 and checked out front and rear toe-in. I have set out the dimensions with CAD (to save the maths), works well if you set the lines at wheel center height (I use axle stands) and run parallel lines along the car as the references. Set the lines from center caps and to body positions, to double check line positions. Then measure in to rim edges for alignment settings. |
07-03-2016, 09:57 AM | #3 |
Rep 93
I ran a tyre on low pressure for a long time. The left edge had also worn.
Had a new tyre fitted so wanted to check if tracking is out or it was because the tyre was low pressure. Hate going to garages just for a check. They are Just as likely to say it's out even if it isn't. For armed is forwarned I guess. Does the steering wheel have to be straight to check? How can you tell if it's perfectly straight? |
07-03-2016, 10:25 AM | #4 |
Rep 15,858
Yes, you want the steering wheel in mid position, as it is when driving straight ahead. (I assume it is running without a left or right bias when driving straight). If your lines are parallel, you should have equal toe-in each side.
