11-01-2016, 08:07 PM | #11111 | |
Rep 40,752
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE Last edited by shawnsheridan; 11-01-2016 at 08:26 PM.. |
11-02-2016, 02:55 PM | #11113 |
Rep 40,752
PM sent.
Skello45.50 |
11-02-2016, 03:11 PM | #11114 |
Rep 5
Hi Sir Shawn, Could you please PM me the latest E-Sys link, full psdzdata, Tool32, and instructions on how to flash F30 ECU please? My previous Tool32 does not have a F01.PRG file.
My car 2013 328i has a Drivetrain malfunction error and it currently cranks but does not start after I removed ECU and installed it back in. If you have come across this issue, I would like to have your advice. Thanks. |
11-02-2016, 03:14 PM | #11115 | |
Rep 40,752
11-03-2016, 12:10 PM | #11119 |
Rep 40,752
PM sent.
11-03-2016, 02:43 PM | #11120 |
Rep 7
Hello, I am new in coding and I need some help here.
I have an 2016 F30 330e (plugin hybrid), engine is 320i without SAT. I have followed the procedure as described below for adding SPORT+ & LC. All went well, but I cannot find anywhere the option 'EGS/3000 Applikation -> Sportschalter_alt' and 'EGS/3000 Applikation -> Sportschalter'. 1. Added 2TB option and deleted 205 in salapa element. 2. Kombi => 300C ECO_FDS =>Function FDS_MENUE_TEXT_1=> menue_3 FDS_MENUE_SIGNAL_1=> menue_3 FDS_MENUE_TEXT_2=> menue_3 FDS_MENUE_SIGNAL_2=> menue_3 FDS_MENUE_TEXT_3=> menue_3 FDS_MENUE_SIGNAL_3=> menue_3 FDS_MENUE_TEXT_4=> menue_3 FDS_MENUE_SIGNAL_4=> menue_3 EDIT: FDS_MENUE > Ausgelesen > menue_3 (Werte=03) 3. ICM Module/ 3000 Daten/ IcmKod_B_Sportlenkung/ verbaut ICM/IcmKod_B_S2TBA -> verbaut ICM/IcmKod_B_S205A -> nicht_verbaut Question: Where can I find this EGS option and do I actually need to code this in a 2016 F30 or is this cancelled in the newest version? I am using E-sys 3.27.1 and Pdzdata v.59.4_PSdZData_Lite. Last edited by Happy Bimmer; 11-03-2016 at 03:08 PM.. |
11-03-2016, 02:50 PM | #11121 |
Rep 8,364
11-03-2016, 02:59 PM | #11122 |
Rep 7
In salapa was mentioned 205 which I have modified into 2TB (SAT). I have no paddles in my car and acc. dealer also not a SAT, which was option but I didn't pay for it.
11-03-2016, 03:16 PM | #11123 | |
Rep 8,364
You can always use TM's NCD / CAFD Tool (SVT-CAFD Resource) to load you SVT, select 2TB and see which ECU and how they are affected. |
11-03-2016, 03:31 PM | #11124 |
Rep 7
I have absolutely no doubt about your knowledge ;-)
I have an 8 speed automatic transmission. Is this the 2TE? Below my modified salapa data where 2TB is added and 205 is deleted: 216,230,258,2L3,2PA,2TB,2VB,320,3L8,423,481,497,4A E,4CG,4NE,521,534,548,698,6AC,6AE,6AG,6AK,6NH,6WA, 845,868,886,8KA,8S3,999,9AA EDIT: I have downloaded TM's NCD / CAFD Tool and clicked on button SVT-CAFD. This opens only .xml files while I only have .ncd files. The only .xml file I have is FA... Is there a help for this program? Last edited by Happy Bimmer; 11-03-2016 at 04:08 PM.. |
11-03-2016, 07:27 PM | #11125 | |
Rep 8,364
It would be more work, but you could separately load your each NCD's in FA-CAFD and select 2TB option to see how affected. |
11-04-2016, 06:05 AM | #11126 | |
Rep 7
I don't know which results/items I have to modify more to get SPORT+ and Launge Control actually to work. With the changes I have already made, SPORT+ & DSC off (automaticly) is working acc. to the i-Drive and dashboard screen, but I have not tried LC yet. EDIT1: I don't know either if SPORT+ is actually working or that I only see the message SPORT+ in the screen... EDIT2: I just drove home from work and noticed that SPORT+ mode resulted in faster gear shifts, so I assume this is working correctly. I only have to check Launge Control. Do you know if this EGS coding is for enabling LC or is this for something else? Last edited by Happy Bimmer; 11-04-2016 at 08:17 AM.. |
11-04-2016, 11:53 AM | #11127 | |
Rep 8,364
It is for Sports, LC, Sailing, etc |
11-04-2016, 01:08 PM | #11128 |
Rep 7
Thank you for all your help Almaretto.
I'll check asap if I can find this LC in GKEB Cafd file. However if I recall corectly I didn't find these options before under '3000 Aplikation, 02'... |
11-04-2016, 01:34 PM | #11129 |
Rep 8,364
If you have that cafd, it will be present but may not be possible such as for the F01. If you have anymore questions, let me know.
Happy Bimmer4.00 |
11-04-2016, 01:43 PM | #11130 |
Rep 343
Files needed please
Hi Shawn
Could you please send me the link for the files as well please? Thanks as always!!!
2012 F30 328i, Alpine White on Black, Luxury, Premium + Exec. Package...
11-04-2016, 02:13 PM | #11131 |
Rep 40,752
PM sent.
11-04-2016, 02:51 PM | #11132 |
Rep 2
Shawn,
Can you please send me the E-sys and Psdzdata for and 2013 F30 328? Thx |
reenendete0.00 |
