12-12-2023, 05:34 PM | #1 |
Rep 119
F31 2016 328d ID4 to ID6 TMC Issue
Hello,
I've searched extensively for this but did not find anything conclusive. My issue is i have a 2016 F31 328d LCI North American Model. Originally came with ID4 i ended up upgrading the ID4 to ID6 along with a touch screen. Had the coding complete and everything worked fine. Recently had a recall to replace the TCM module and the coding was off since the dealership did not recognize the ID6. Got the coding back complete to have ID6 operational again but there is no communication between the TCM and the Idrive unit. I've tried with a couple coders and they tried using different FSCs and even swapped over a TCM from a 2018 M3 but did not make a difference. Anyone got any ideas? I am running fresh out and would like to try to get connected drive working back on this car. Willing to pay to get it fixed. Thank You |
12-22-2023, 12:33 AM | #4 |
Rep 2,047
You cant swap TCB unless you order from dealer, its vin locked. And it not FSC issue. Restore the TCB for the car and check the coding in the TCB. What communication issue did it have? Could you see the modules in esys or ista?
12-22-2023, 11:58 AM | #5 |
Rep 119
I understand you can not swap TCBs. I have swapped the Idrive system before a recall to the TCB that was completed by the BMW dealership. The dealership has updated the TCB to the new version but an error occurred since ID4 was not installed and ID6 was. The dealership was unable to get the TCB to work, and i am unable to get the TCB to work. I do not believe there is any restoring of the coding for the installed TCB.
For communication it is not communicating with BMW. I have tried to reactive connected drive several times and it does not receive any activation codes. I have tried to have coders get it to work any no one has figured this out yet. I can scan to show you the codes if you think this will help. |
12-23-2023, 09:46 AM | #8 |
Rep 1,117
If I am reading between the lines properly, the OP had a 2016 vehicle with the first generation ATM HW which would not do VoLTE, so under the warranty BMW replaced the ATM to the newer HW model and attempted to code it.
Reading more into the tea leaves, as the 2016 HU were HW 2.x/ID4, OP had a remote coder install the “fixed” car play coding and files into the HU which allows him to run ID6/Car Play. As multiple posters have stated over the years, those hacked Car Play files blow up ISTA’s ability to code the HU properly (are the files for CarPlay read only to keep BMW from overwriting them as is possible with NBT EVO units)? So the Dealer did the ATM Swap as per warranty and now ISTA isn’t coding the car properly. The correct procedure would have been to do the warranty work replacing the ATM prior to updating from ID4 and then and ONLY then, apply/update the ID6 CarPlay hack. Again, that’s what makes sense based on interpreting what is posted here. |
12-23-2023, 10:45 AM | #9 |
Rep 2,047
It make me wonder how they proceeded with the TCB swap with the retrofitted headunit. They will usually just refuse to work on the car or tell you to replace the unit. They use ISTA for coding and programming and it will definitely not proceed with any coding/programming unless the correct modules are installed in the vehicle.
Sometime it might be the SIM IMEI of the TCB isnt synced to the servers. You can call Connected drive support and ask them if the SIM is enabled and if they can check if communcation betwenn the TCB and the backend servers. |
12-24-2023, 01:03 PM | #10 | |
Rep 119
This is not a hacked unit, i bought a used ID6 unit and had it coded to the car. I agree i wish i kept the original ID4 unit and had the work done but i couldn't predict this myself. You are correct for the most part the cars original config came with ID4 so the dealer couldnt get ISTA to work properly since the headunit was swapped out for an ID6 unit. Is the only way to get this to work is find an id4 unit and try to get the dealership to recode it with ISTA? |
12-24-2023, 01:05 PM | #11 | |
Rep 119
They installed the new TCB unit and tried to code multiple times but failed. I told the dealer do not worry about the coding and i would take care of it at home. Not knowing of the consequences unfortunately. I guess now that the issue is now known is there any way to fix this besides assuming more? |
12-24-2023, 01:59 PM | #12 | |
Rep 1,117
Again, you will find others in various threads with same issue (coding HU with ISTA at Dealers) after the hacked CarPlay files are installed. It would have coded fine at the Dealer if the hacked CarPlay files were not installed. Also the reason I paid BMW the $295 for CarPlay instead of the hacked route. Future problems like this that end up costing you much more in the end. |
12-24-2023, 06:58 PM | #13 | |
Rep 119
12-24-2023, 07:20 PM | #14 | |
Rep 1,117
Have whoever hacked your CarPlay to delete the files they installed returning it to normal state. Then have Dealer do his thing. |
12-25-2023, 01:20 AM | #15 |
Rep 2,047
Dealers dont have an issue with hacked carplay, they can code fine. Sometimes they cant even detect the patch. Its only after they flash will the unit and it returns to stock with patch wiped and have missing OEM FSC.
The main issue is the ID6 retrofit. Just focus on the TCB for now, it should be able to commuincate with backend servers without HU. If you have ISTA you can check the data and read out the state of the unit. |
connected drive, f31, id4, id6, lci |
