07-26-2013, 06:38 AM | #4115 | |
Rep 40,730
VO Code: Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Right-Click on ECU (the ECU itself not the underlying CAFD) => Select CODE.
07-26-2013, 06:40 AM | #4116 |
Rep 40,730
PM sent.
07-26-2013, 07:28 AM | #4117 |
Rep 60
Drives: F30 330e & E92 335i
Thank you Shawn, works like a charm.
07-26-2013, 12:55 PM | #4119 |
Rep 24
3.22.5 Token
Just a quick question, I've got my stuff from Akiss, do I have to anything more than put the 2 patched files in the appropriate folders, re-named obviously.
Thanks |
07-26-2013, 01:10 PM | #4120 |
Rep 1,892
07-26-2013, 01:59 PM | #4121 |
Rep 24
Turns out I didnt have to do anything other than put the files in the folders.
Actually I did half a job, i managed to change the FA without any EST reference in e-sys, Im wandering if this had an impact on phone data not working? Last edited by RSC27; 07-26-2013 at 03:55 PM.. Reason: half a job |
07-26-2013, 03:25 PM | #4122 |
Rep 40,730
True, as it will use any valid Token. So, if you have more than one, pick the one with the longer Validity Period.
07-26-2013, 03:28 PM | #4123 |
Rep 40,730
Not sure on F30, but for F10, you need Option Code S302A, and then HU_CIC => DWA = aktiv.
07-26-2013, 03:46 PM | #4124 | |
Rep 263
by changing what you said I would sound USA? thank you What is known is that this otpion Uploaded with ImageShack.us Last edited by thebadboy; 07-26-2013 at 04:01 PM.. |
07-26-2013, 05:00 PM | #4125 |
Rep 937
Drives: F30 & F25
Any clue why it says "no est file chosen?" (C155) when edit FDL?
some lip, some springs, some brakes, some wheels.
07-26-2013, 05:14 PM | #4126 |
Rep 40,730
You have not gone into E-Sys => Options => Settings => EST Tab => EST: Field, and told E-Sys where your .EST Token is located.
07-26-2013, 05:20 PM | #4127 | |
Rep 40,730
Buzzer duration Buzzer frequency Your picture of A2DP_PROFILE is for enabling Bluetooth Streaming on Combox equipped cars.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE Last edited by shawnsheridan; 07-27-2013 at 04:17 AM.. |
07-26-2013, 05:37 PM | #4128 | |
Rep 263
ok, I'll get in FZD, an idea of the number of the section, thank you A2DP_PROFILE is "nicht-aktiv" and yet the Bluetooth streaming works. what will change if I active? |
07-26-2013, 05:41 PM | #4129 | |
Rep 40,730
Some settings are duplicated in Combox and CIC. It's not clear to me which one you have shown in the picture. Anyway, if yours is working, then the other one must be enabled, and enabling this one won't do anything more.
07-26-2013, 06:55 PM | #4130 |
Rep 937
Drives: F30 & F25
Thanks! that was it! the instructions in readme didn't show that
07-27-2013, 03:32 AM | #4131 | |
Rep 263
great thank you, how coding for the tire pressure in the idrive |
07-27-2013, 03:52 AM | #4132 | |
Rep 40,730
Requires Option 2VB.
07-27-2013, 04:11 AM | #4133 | |
Rep 263
really thank you, it works for the alarm ==> FZD ==> 3001 alarm types ecc ==> us buzzer hight level 3 ==> 10 buzzer low level 2 ==> 7 alarm duration 39 ==> 60 excellent. we must add in the cheat sheet, ca could be used to other people |
07-27-2013, 04:18 AM | #4134 |
Rep 40,730
Glad it worked for you.
07-27-2013, 04:45 AM | #4135 |
Rep 263
07-27-2013, 05:05 AM | #4136 |
Rep 40,730
It is not possible with CIC. Only the new NBT Head Unit can have different Logo's.
