BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > F30 LED turnsignals installed
      05-29-2013, 09:12 AM   #133
fricfracfrank
fricfracfrank's Avatar
Drives: 2019 X3 M40i
This may have been covered before but what about the LED front & rear turn signals that were in the e90?
Present: 2019 X3 M40i Phytonic Blue
Past: 2013 335i xdrive Estoril Blue
2011 328i xdrive Black Sapphire Metallic
      06-07-2013, 07:24 AM   #134
m3kidd
Drives: 13' F30 328i / EK Civic
Originally Posted by rustyminded View Post
Hi, we can't see the video, any way you can repost, I'd like to see the light output. Last LED 1157's I had were not bright enough on my old car.
thanks
      06-08-2013, 06:39 AM   #135
rustyminded
rustyminded's Avatar
248
Drives: BMW 328i
thanks
It's now public I didn't notice it's privacy, it's almost as stock and I'm satisfied no errors.
      06-11-2013, 01:49 PM   #136
netwhiz1
netwhiz1's Avatar
Drives: '12 F30 335i Sport-Line
Anyone want to make a post with error free led's for turn signals and brake lights including links where to buy?
I can't seem to find the link to any that are still for sale.
      06-11-2013, 07:50 PM   #137
Balzz
Drives: F97 X3M
2019 M4  [0.00]
2021 X3M  [0.00]
I just received these and they are INSANELY bright. I'll get some video in direct sunlight tomorrow. Hands down, brighter than any 18, 30, even 45 SMD LED bulbs I've tried in the past.
http://www.ebay.ca/itm/221219595675?...84.m1497.l2649
      06-12-2013, 12:26 AM   #138
henryeeex
Drives: 2013 335i
cant wait for the pics!
      06-22-2013, 05:19 PM   #139
rustyminded
248
Drives: BMW 328i
just made a video this is the 68 red smd
http://www.youtube.com/watch?feature...&v=ebRTR7LlaEc
      06-22-2013, 06:41 PM   #140
Steve33
Steve33's Avatar
Drives: 2018 SQ5
What about amber CREE LED's?
      08-26-2013, 10:49 AM   #141
carzaddict
Drives: 2015 Cadillac Escalade ESV
so at the end of the day, what is the general consensus about the LEDs
which ones are best for the front/back based on value to brightness ratio
      08-29-2013, 04:51 PM   #142
LeoSaavedra
LeoSaavedra's Avatar
Colombia
Drives: BMW 430i F33
Smile
Any luck with the Video?
thx!
      08-30-2013, 03:10 PM   #143
vip
vip's Avatar
Drives: 2001 Alpine White M5
I installed some aftermarket turn signals and at least each day the L and R ones trigger a turn signal malfunction message. Though they still work correctly, I get this message still.
Anyway to code this out, or that just the ECU saying I have an aftermarket led and that its not stock.
sent from bimmerpost Android app
      09-03-2013, 08:22 AM   #144
G20_Transporter
Enthusiast
Drives: 2020 X5 40i
Originally Posted by svache View Post
Well guys, I spend an hour or so in my car just now, partly of it in dark (was doing some coding but didn't had any lights on, just the engine was running) and then I noticed for the first time that, every 30 seconds to a minute, the turn signals would give a real short blink. Seems they're not as much error free as I hoped they would be (and as they were advertised). I then did some more tests and noticed that when you just turn the ignition on, and all the lights are off, you could see the turn signals blink like crazy for a short time. I will try to see if there's anything in the code that we could chance so this would go away but, quite frankly, I don't have too much hope for that. We'll see, but just know that they might not be completely error free as was first said by the seller (and by me as I thought it was true).
the bulbs do a rapid blink during every startup, but don't throw codes out or do hyper blink. I ran LED lights on my 2007 e90 and they did this as well and they do it also in the F30. on the e90 after 3 years they are still working. so i don't forsee any issues.
      09-03-2013, 01:19 PM   #145
00punisher
Spain
25
Drives: F36 420d
thx!
+1
Thx!!
      09-17-2013, 03:49 PM   #146
00punisher
Spain
25
Drives: F36 420d
Originally Posted by 00punisher View Post
+1
Thx!!
Any news? Thx!
      09-30-2013, 04:16 PM   #147
bmw_fascinated
bmw_fascinated's Avatar
Drives: F22 228i
So are there bulbs that don't flash every few minutes?
Does it correlate with the number of leds and the wattage or depends it just on the additional load resistor? What resistance is measured below the forward voltage?
What are the values for cold and warm resistence deposited in the code?
Otherwise; could a resistor-capacitor combination be used to have low restiance for short pulses? Has anyone measured the pulsewith and duty cycle of the check signal?
      10-01-2013, 10:55 AM   #148
TheHitchhiker
TheHitchhiker's Avatar
Drives: 2019 BMW X5 50i
Hey everyone, I got these and installed them, looks pretty good and it is bright enough. No errors so far. Damn easy to install.
http://www.ebay.com/itm/280709475309...84.m1497.l2649
One thing though, it says not to use these as DRLs because they may produce heat. Should I be worried about that? As they do come on when low beams are on. Would it make them less bright when it heats, or is it because it can damage the housing? The OEM bulbs i took off were extremely hot too.
I have a slow motion video (testing the new 5S ) which shows the difference and some photos.
Current: 2019 G05 x5 50i M-Sport
Past: 2016 F10 550i M-Sport ~ 2015 F83 M4 Convertible ~ 2013 F30 335i M-Sport ~ 2006 E85 Z4 30i
      10-01-2013, 11:07 AM   #149
v1k1ng01
v1k1ng01's Avatar
Drives: 2013 335i M-sport
The flicker from LED's on start-up, and every minuet or so is caused by a self test diagnostic program in the Electronics Control Module. With incandescent bulb's the power the car uses to function check isn't enough to light it up. Because LED's are so much more efficient at using energy the energy actually lights up the diodes. Only fix is to disable the function with coding, or live with the flicker.
      10-01-2013, 11:16 AM   #150
v1k1ng01
v1k1ng01's Avatar
Running the bulbs to long can make them to hot and damage them. I don't think they will damage the housing however I have noticed color dulling with inferior SMD LED's.
      10-01-2013, 11:22 AM   #151
TheHitchhiker
The best is to code them off when low beams are on then. I don't like the way it looks anyway. I like it only with the rings.
BTW, I haven't noticed flicker with these bulbs. Am I missing a point?
      10-01-2013, 05:12 PM   #152
bmw_fascinated
Drives: F22 228i
has anyone tried such bulbs? http://www.alibaba.com/product-gs/54..._Q5_power.html
I think, they might produce a better beam pattern.
Can the diagnostic easily be switched off, or is it very complicated?
Is there any feedback from zeezz about his coding?
      10-02-2013, 05:14 AM   #153
v1k1ng01
v1k1ng01's Avatar
I agree, I just haven't gotten around to doing any coding myself. Led's used on the F30 where incandescent bulbs are installed stock should flicker on start-up and randomly every minuet or so while the car is running.
I've observed it happening on both front and back turn signals as well as brake, and reverse lights.
      10-18-2013, 05:09 AM   #154
benoa
benoa's Avatar
Japan
47
Drives: 320d Touring Luxury
No luck with my 1st try :
http://item.rakuten.co.jp/advance-sh...mal_browsehist
=> not bright enough + flickering
Has anyone tried those:
http://www.ebay.com/itm/221076959783
I have just ordered them...
