BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Golf Tee Mod
      04-30-2012, 10:50 AM   #1
Clarence Watson
Drives: 2008 BMW 335i
Golf Tee Mod
Just an E92 owner here wondering if the F30s (both 328i and 335i) have the capacity for the golf tee mod or something similar. Is the vacuum-powered "flap" still in its left tailpipe location on the 335i?
      04-30-2012, 11:04 AM   #2
ric124
ric124's Avatar
Jamaica
452
Drives: F87 M2 BSM MT
2017 BMW M2  [0.00]
check this out its on a 328i and I would really like to know if this would work on a 335 as well.
http://www.f30post.com/forums/showthread.php?t=676468
      04-30-2012, 03:48 PM   #3
Clarence Watson
In response to this being moved to N55 Turbo Engine / Drivetrain / Exhaust Modifications forum, can someone confirm that the golf tee mod, as it relates to F30, is the same as for E9x? I was under the impression that this was specific to the model, not the engine. I didn't know that all N55s would all have the same stock exhaust configuration and thus be modded the same way. What about N20? Is F30 = E90 for purposes of golf tee?
      05-01-2012, 08:30 AM   #4
TEAShea
Drives: 2012 328i
I deactivated the exhaust valve on my F30 328i. It is electrically operated instead of vacuum powered so the golf tee method will not work. However, it is just as easy. There is a spring clip that connects the actuator to the stem on the butterfly valve. Just remove the clip. Then use a piece of wire or some epoxy to fix the butterfly value in the open position. It makes a little difference but not as much as I hoped - almost barely noticable sound increase. So I did some exhaust system modification to make it louder and now it sounds very good. Good tone and volume and no resonance.
      05-01-2012, 02:34 PM   #5
ric124
ric124's Avatar
Jamaica
452
2017 BMW M2  [0.00]
What kind of modification did you do?
      06-20-2012, 03:53 PM   #6
AWMSPORT
1ST CLASS AWMSPORT
AWMSPORT's Avatar
Drives: 13' 328 MSPORT
BUMP...+1
'13 328i MSport, AW, Black Dakota leather, Premium Pkg, xenons, ///M Perf, side skirts,Front Lip, Fully coded, CF roundels, Matt Black Grillz, Painted reflectors (front & rear) Smoked tail lights, Plazma l.E.D White PY27W front turn signal,trunk spoiler, Matt Black roof, 8K D1S HID,Custom Exhaust,!
Soon:
JB4,DP,H&R sports,rear diff,!
      07-16-2012, 03:10 PM   #7
ric124
ric124's Avatar
Jamaica
452
2017 BMW M2  [0.00]
Originally Posted by SG335SPT View Post
BUMP...+1
+1
      07-17-2012, 05:35 PM   #8
ƒ°
ƒ°'s Avatar
101
Drives: ✚
BUMP...+1
+1
+1
      08-11-2012, 08:29 PM   #9
fshubert
fshubert's Avatar
89
Drives: 2015 F30 335i
I had the M-Performance exhaust put on mine soon as it came off the boat. Nice sound. But the golf-tee (OK, removal of spring clip and wired open exhast butterfly) makes for a sweet growl at all RPMs.
2018 Mustang GT | Royal Crimson | Black Leather | 6-speed | Cold Weather | Premium Pkg | 20" Alloy Wheels | Tuned to 510HP | Less than $45K
Previous loves: 2015 F30 335i / 2013 F30 335i / 2009 E90 335i / 2007 E90 328xi
      08-12-2012, 10:24 PM   #10
ƒ°
ƒ°'s Avatar
101
Drives: ✚
+1
Okay fellas. I finally had a day off to mess with the car a bit. Although the Golf Tee Mod is not the same as what I did, the outcome can be the same. I didn't take any pictures. Sorry. But it's quite easy to understand once you get under the car.
Although disconnecting the electrical harness can leave an error embedded in the computer, it will not give you an error in iDrive.
There are several ways you can do this mod. One is completely error free (at least in theory).
There are 4 important components to this mod.
1. Electrical wire harness
2. Actuator that turns exhaust flap hinge
3. Clip that connects the actuator to the exhaust flap hinge
4. Exhaust flap hinge
ERROR FREE METHOD (easiest)
- Remove the Clip that connects the actuator and flap with some needle nose pliers.
- Secure the flap with a wire of some sort in the open position.
- This method will keep the actuator plugged in and working. But it will not be mechanically opening the flap. But the computer shouldn't know the difference.
UNPLUG ACTUATOR
- Unplug electrical wire harness from the actuator.
- Secure wire harness out of the way so that it is not dangling.
- Unclip Actuator with pliers.
- Remove actuator all together. All you need is a 10mm socket wrench. 3 bolts.
RESULTS***
In my opinion, it made very little difference in sound. But then again, I just drove it up and down a quiet street. And then had my friend do the same as I watched. I did notice a loud turbo whistling sound that I never noticed before.
      08-13-2012, 09:08 PM   #11
ric124
ric124's Avatar
Jamaica
452
2017 BMW M2  [0.00]
UNPLUG ACTUATOR
RESULTS***
Thank you Sir!
      10-01-2012, 05:41 PM   #12
Sp82
Sp82's Avatar
166
Drives: F15 X5/G30 5er
did this yesterday on my car..almost no difference in sound at all..very disappointed, when I did this on my E92 335, the sound notice (with actuator unplugged) was AMAZING
      11-27-2012, 11:56 AM   #13
jsedlak
jsedlak's Avatar
Drives: F30 335i 6spd
Sorry for the bump... but I just wanted to bring this up. When I was picking up my car yesterday, my CA called this mod out specifically. He said that it may sound like an awesome thing to do, but you lose a little back pressure and over time it can cause some issues that can be traced back to the mod.
I'm not going to attempt to suggest his comment is completely truthful, accurate or valid - but wanted to bring it up so that others can rethink the mod.
      11-27-2012, 01:13 PM   #14
EB_F30
Drives: 13' M Sport 335 6MT
I could see how you would loose a little back pressure...most exhaust mods will do this. You will see a gain more in the high end do an increase exhaust flow but may loose a tiny low end due to again more free flowing exhaust. I don't see how this could cause any issues?
      11-27-2012, 01:15 PM   #15
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
the flap's probably there for a reason...i left as is, since sound change was barely noticeable according to posters..
SOLD: 2012 335i Mineral Gray
      11-27-2012, 03:26 PM   #16
rtgirard
1-5-3-6-2-4
Drives: Awaiting 2013 335xi -
Honestly, on cold start my car is quite loud with just the right-side pipe open. When the actuator opens the left-side flap (and the actuator is surprisingly loud), then the whole tone actually quiets down as the car finishes warming up. And furthermore, once the car is warmed up, I've yet to see the left-side pipe close up again... it seems to stay open all the time for me.
      11-27-2012, 10:29 PM   #17
ric124
ric124's Avatar
Jamaica
452
2017 BMW M2  [0.00]
Sales people say the darndest things! Flap is open on startup, most likely highways and every time you want to drive hard. when you are cruising it is closed.
      11-28-2012, 06:26 AM   #18
rtgirard
1-5-3-6-2-4
That's the exact opposite of how mine behaves. Left pipe is closed on cold start... actuator opens the left pipe after ~1 min of idling and then it stays open until I shut the car off.
      11-28-2012, 06:42 AM   #19
jsedlak
jsedlak's Avatar
Yeah I know, I know.
Thing is... he had no reason to lie. I had the keys to the car and was ready to get in and be on my merry way.
Anyways - just thought I'd mention it. No big deal.
      11-28-2012, 10:55 AM   #20
ric124
ric124's Avatar
Jamaica
452
2017 BMW M2  [0.00]
Nice then you dont need to do the mod.
      11-28-2012, 02:45 PM   #21
shivaswrath
Drives: 2012 335i
Wait, mine does that too.
I even posted a video on here of it...left side closed, right side spewing exhaust on startup. Once it's warmed up, both are open and GTG.
      11-28-2012, 02:49 PM   #22
justinnum1
Drives: 2018 330i Msport 6mt
anyone else think the PPK would make the performance exhaust sound much better?
F30 330i Alpine white/Coral red Msport 6MT
