BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > F30 LED turnsignals installed
Studio RSR
      11-28-2013, 07:17 AM   #177
benoa
benoa's Avatar
Japan
47
Drives: 320d Touring Luxury
Finally managed to code to stop the flickering during self-test.
Very happy with those LED, as bright as the original bulbs : http://goo.gl/aFPlrC
Will try to take pictures / video later on.
      12-04-2013, 08:45 PM   #178
Mt3vie
Mt3vie's Avatar
Drives: F30 M
Got these, shows errors and also bulb flickers fast when turning signal is on
http://m.ebay.com/itm?itemId=141100334555
      12-04-2013, 09:12 PM   #179
benoa
benoa's Avatar
Japan
47
Exclamation
Link does not work...
Please note that there's no way around coding if you want your LED to stop flickering. As promised above, this is what I managed to get with coding and decent LED :
      12-05-2013, 05:55 AM   #180
bmw_fascinated
bmw_fascinated's Avatar
Drives: F22 228i
nice video.
the front LEDs are brighter than I expected - seem to be really good chips.
As I see you are using a 5x5W Cree LED in the taillights - ordered a similar bulb without projection lens: http://www.ebay.com/itm/221192124955
@mtevie
did you order this bulbs http://www.ebay.com/itm/141100334555 - just searched by the item number ? Can't imaging that those one can replace a bulb with more than 5-10watts.
      12-05-2013, 07:43 AM   #181
benoa
benoa's Avatar
Japan
47
Originally Posted by bmw_fascinated View Post
nice video.
@mtevie
I use 6x5W and yes those are too weak (the very low price is also suspicious).
      12-06-2013, 02:13 PM   #182
Mt3vie
Mt3vie's Avatar
Drives: F30 M
http://www.amazon.ca/gp/aw/d/B00CBQY...dir_mdp_mobile
Low power but no errors
      12-06-2013, 03:07 PM   #183
ktula
Drives: 2014 F31
What kind of bulbs did you end up using for the rear turn signals? Are they as bright as the factory bulbs?
      12-06-2013, 05:50 PM   #184
benoa
benoa's Avatar
Japan
47
Same type as the front (but with 180 degress) and even slightly brighter.
It's not about the error but the flickering at startup and during self-check up (ever 4 minutes or so). And as you said : low power, which is a safety hazard.
      12-06-2013, 06:26 PM   #185
ktula
Drives: 2014 F31
I thought the rear bulbs have to be BA15s? The link you provided for the front LEDs were BAU15s. I was not able to find BA15s at the same eBay shop.
      12-06-2013, 08:00 PM   #186
benoa
benoa's Avatar
Japan
47
Yes, hence the "(but with 180 degrees)" - sorry for being unclear.
      12-06-2013, 08:41 PM   #187
ktula
Drives: 2014 F31
Just to be clear, you used the same LED bulbs as those for the front turn signals, but you just rotated them 180 degrees? If you were using the BA15s bulbs, do you mind providing the link where you got them? Thanks!
      12-06-2013, 10:59 PM   #188
benoa
benoa's Avatar
Japan
47
No. PY21W/BAU15S for the front and P21W/BA15s for the back. The difference between the front and the back lies in the layout of the bayonet : 150 degrees for the front, 180 degrees for the back.
      12-07-2013, 12:24 AM   #189
ktula
Drives: 2014 F31
Do you have link to where you got the P21W/BA15s?
      12-07-2013, 04:47 AM   #190
bmw_fascinated
Drives: F22 228i
http://www.ebay.com/itm/221192124955 -> not bright enough
      12-12-2013, 03:28 PM   #191
bmw_fascinated
Drives: F22 228i
I accidentally found these on ebay:
http://www.ebay.com/itm/331055302929
http://www.ebay.com/itm/181280296943
260lm doesn't sound much, but referring to the few reviews I found (and the google translate output) they seem to be at least as bright as the OEM bulbs ...
http://shumauto.com.ua/lampy-philips...24vcanbus.html
Haven't seen these LEDs in Germany - has anyone of you seen them before?
      01-18-2014, 04:11 PM   #192
bmw_fascinated
Drives: F22 228i
These LEDs are also very bright (at least as bright as an amber bulb, if not even brighter) : http://www.ebay.com/itm/231115946594
The only disadvantage are the yellowish emitters since they use a blue (460nm) InGaN semiconductor combined with a phosphor on top that emitts broadly around 590nm.
      01-20-2014, 02:44 PM   #193
zeezz
Drives: F30 328i Sport Line
http://www.ebay.com/itm/191027694132 bought these for my front signal turn lights -they work, but are not bright enough compared to stock. will keep looking although i'm tempted to just go with one of the ~30-40$ options, they look to be a lot brighter.
Quick demo - front left is LED, front right is stock. It's not that apparent in this video but take a look at how much of the housing gets lit up by the standard incandescent, also see how much of it shines onto the ground compared to the LED. http://www.youtube.com/watch?feature...&v=lecWFfxk8ww
      01-21-2014, 12:22 AM   #194
zeezz
Just bought this, I *think* these are the same ones that benoa has on his car (thanks for the video btw). Will let you guys know how it is in 10-20 days, haha.
http://www.ebay.com/itm/2x-30W-Bau15...4821cc&vxp=mtr
      01-21-2014, 12:35 PM   #195
chrisymarr
Drives: 318d
need to get myself a set they look great
      01-30-2014, 09:22 PM   #196
zeezz
WOW these bulbs just got here and they are amazing! The brightness blinds me when looking into the bulb, kind of like the old E90 LCI turn signals. Excellent visibility, even better than stock.
For those of you curious, here's a clip.. you can't really tell but they are brighter than the stock bulbs on the left. You can compare the output to my previous LED video (few posts up) ... way brighter. I'm going to get a set of these for my rear turn signal lights as well.
      01-30-2014, 11:56 PM   #197
F30EDR
Drives: Black Sapphire F30
No error?
      01-31-2014, 12:14 AM   #198
robgutie328i
Drives: Mel Red 2014 BMW 328i MSport
why cant they make an led that is white when its on and blinks amber when turning.... They can make Borg eye ware but cant make a cool light!!!! Fix this problem mighty INTERNET! cause in texas i believe u have to have amber lens or amber bulb
