06-18-2016, 12:25 PM | #1 |
Fool
1859
Rep 3,542
340i now always starting as if it was cold
I had a new gearbox fitted to my 340i recently, I got the car back yesterday and since I've had it back, regardless of the oil temp, it always does a cold start. Previously, it only did a cold start if it wasn't up to temperature but that's no longer the case.
Is it cause for concern? I'm not sure it needs to do that all the time. Anyone else got this, or anyone with a brand new one doing this? They updated the car's i-step in the process so I'm wondering if it's something to do with this or if there's a sensor unplugged. Thanks! |
06-18-2016, 02:07 PM | #3 | |
Fool
1859
Rep 3,542
06-18-2016, 04:59 PM | #4 |
2JZ-GTE
3072
Rep 4,022
What happened to the previous transmission?
06-18-2016, 05:51 PM | #5 |
Fool
1859
Rep 3,542
06-18-2016, 06:50 PM | #6 |
Rep 1,265
06-18-2016, 06:52 PM | #7 |
Fool
1859
Rep 3,542
When the engine is already up to temp?
06-18-2016, 07:31 PM | #8 |
Rep 1,265
tmdals0213214.50 |
06-18-2016, 07:47 PM | #9 |
Member
458
Rep 1,517
Only have 1000 miles on mine and it does the same thing. I found it strange
Previous: 2013 135i Space Grey w/Coral Red | 6 Speed MT | M Pkg | JB4 | AA Downpipes | AA Exhaust |
Previous: 2015 M3, BSM[/SO/CF | DCT | Adaptive M | 19" Black | CF Roof | Previous: 2018 M2, AW | DCT | Exec Pkg Current 2020 X7 50i |
06-19-2016, 12:22 AM | #12 |
Rep 64
Mine does it since day 1...it is a bit irritating...even when the engine is warm.
The Ultimate Driving Machine
2016 340i xDrive Premium package enhanced, M performance package, 624M |
07-07-2016, 10:10 AM | #13 |
Rep 548
Drives: 2011 E90 M3 ZCP
What is your current I-Step level? I'm at F020-16-03-501.
Mine always revs above 1k when starting, and then settles down. Seems to operate the same when cold/hot. |
07-07-2016, 12:51 PM | #15 |
Fool
1859
Rep 3,542
07-07-2016, 02:52 PM | #16 |
Rep 1,055
Drives: 2016 340i M Sport 6MT+RWD
It's a feature... to bless your surroundings with the B58 symphony
2016 Estoril Blue II 340i M Sport | ///MPPSK | 6MT | RWD | Fully Loaded
BM3 Stage 2+ 93 | B58TU HPFP | VRSF v2 Catted Downpipe | 550i Clutch |
07-08-2016, 05:15 PM | #18 |
Rep 7,047
My B58 does that as well.
Even if I've just driven 30 minutes on the highway, if I shut the engine off and fire it right back up it will go a bit over 1000rpm and then slowly drop to around 700-750rpm. The problem I have is that I have a distinct "shake" once the idle drops to around 1000rpm and the shake continues until around 850-800rpm. The shake feels like either a misfiring plug or a faulty injector. Once idle is below 800 and at normal, it's smooth as butter. However, that shake is annoying, and if I try to drive off before waiting for the idle to drop I will get an occasional stall as I give I it throttle. The cars moves a bit forward, cough - stall for a split second and then goes normally. The shake has been there for day 1. The stall has only started within the past month or two. I've reported the issue to my dealer and they have a case open with BMW. However, nothing yet because BMW needs to get more cars with same or similar issue in order to find a cure. However, I can push the issue and then BMW will have to send a field tech to look closer at my 340i. I'm waiting until around mid August and if I hear nothing from my dealer, then I'm going to have them call the BMW field tech/engineer. This is one very smooth and powerful engine. But, I'm getting very annoyed at it's "cold start" behavior, and now the stalling thing is bugging me as it feels like some old beater for the first few minutes after start or restart. BMW > |
07-08-2016, 05:20 PM | #19 | |
Rep 7,047
During the colder months cold start had the higher rpm idle go longer to help warm things. With the warmer weather cold start high idle drops quicker, and hot restart high idle drops quicker. I hope I didn't confuse you with what I just wrote. BTW, I believe my 335i w/N55 did this as well, except high rpm cold or hot start was smoother on the way down to base idle. I notice this mostly because of the shaky idle of my 340i on any start, cold or hot. Again, BMW > |
07-08-2016, 11:55 PM | #20 | |
BMW forever!
1395
Rep 2,428
2020 BMW X5
2019 BMW M2C 2014 BMW 335i 2009 BMW 328i |
07-09-2016, 10:05 AM | #21 | |
Rep 548
http://f30.bimmerpost.com/forums/sho....php?t=1259218 |
07-11-2016, 02:36 PM | #22 |
Captain Crunch
169
Rep 548
I was wondering if I was the only one experiencing the same behavior: high RPMs on start whether cold or warm, and the shake under 1k during warm up that makes it seem like the engine is misfiring. I haven't complained to the dealer yet, but I may if it helps resolve it.
On Order (in transit): BMW iX 50, Oxide Grey
Retired: BMW Welt Delivery 4/14/16: European Delivery - 2016 340i EBII/Saddle - ZMP | ZCW | ZDA | ZLP | ZTP | M Adaptive | Rear Shades | MPPSK Before and After Dyno Retired: 2011 335D Space Grey/Black - ZSP | ZPP | ZCW | 6FL | Sat Radio | Nav | $600 Base Audio Upgrade |
