10-14-2015, 02:04 PM | #23 |
Rep 477
You do realize that the lumbar support can also be adjusted vertically as well as horizontally, right? Makes all the difference in the world as most car seats that have only the horizontal adjustment tend to put it around your tail bone rather than the lower back.
01-16-2016, 08:53 AM | #24 |
Rep 4
Got my new 120i M Sport and found I was getting lower back pain even a short drive (couple of miles) - not happy.
Read the threads on here and realised I'm not alone. Anyway, by adjusting the seat to be flat (i.e. rocked forward not back) although possibly a little bit less comfy when driving - it fixed the back pain. Hope this might help someone else with similar issues. |
01-16-2016, 10:52 AM | #26 | |
Rep 31
E46 330d 2003-2006 | E90 330i 2006-2008 | E46 Alpina B3 2008-2010 | E90 335d 2010-2013 |F30 335i 2013- 2015 | F80 M3 2015 - present | E3 2500 Auto 2007-current
01-16-2016, 11:04 AM | #27 | |
Rep 31
I am a lot better now; but every time I change my car, or bed, or office chair; my back starts playing up. I knew my new M3 would set it off; and it did. However it normally settles again; I am just getting back to normal levels of background pain, 8 months later. Don't muck about with seat inserts, or indeed change anything about the seat. Set it up how you like it, and then let your back settle down. Give it time (months, not weeks), and don't keep changing things; as you will be back to square one again. Just find a comfortable position and get settled. Take you pain relief to get through it if you need to, but you will, just like I and almost everyone with back issues that are 'in remission' always do. Next time, buy another F30 with the same seats as this one. I hope this helps you; you will get through this, just learn about looking after your back.
01-16-2016, 07:34 PM | #28 |
Rep 391
Has anyone tried using a lumbar roll or pillow? Most of the ones I see online look too big.
The mckenzie roll looks promising, but I don't know how well it will stay in place. |
01-16-2016, 08:09 PM | #29 |
Rep 502
I see some talk in here about Chiropractors and the like. I also see a lot of talk about the car seat setup. I think you should focus more on your physical ailment and what it might actually be. More often than not, the issue with lower back pain is simpler than most think. Unless you have a pre-diagnosed spinal issue, your lower back issues are soft tissue related, and will almost certainly be dramatically improved with a combination of stretching and a foam roller. And if you can make it happen, proper weight training. But my main point is you should forget about focusing so much on the seat, and take care of your lower back. Use a foam roller on your lower back and I guarantee if there is any tightness in there it will feel tons better after doing it just once. Honestly, the first time I used one on my lower back I was amazed. If you do this, and stretch, you'll feel like new.
01-16-2016, 09:24 PM | #31 |
Rep 3,066
Thank you for the recommendation on turmeric! I've been using it for the past few months and feel great. On my third bottle of the organic version. Definitely helps with small pains.
01-17-2016, 12:43 AM | #32 |
Rep 3,870
I have the same issue...
Any trips over 25min and i start feeling my lower pain... 35yo mT driver Regular seat non sport with lumbar support. Base is as tilted as much as possible to replicate a sport seat. I dont think that is the problem... I just think the back support is just too firm. With My old e36, i never had such issue... Or is it due to my old age? But i dont think i am old... |
01-18-2016, 05:02 PM | #34 |
Rep 285
Interesting thread. I have had an E39 and E90 and never had a back problem with either. I recently got a new F30/340 with sport seats and almost immediately started having pain in the back and sciatic pain down the back of my legs. I have played around with all the seat adjustments and lumbar settings with little improvement. Some good suggestions in this thread so will try them.
01-18-2016, 08:11 PM | #35 |
Moon Parasite
654
Rep 1,336
I went for a spirited drive on some back roads a few weeks back and woke up the next day feeling 80 (lower back did). I'm highly confident it was the drive in the car that did it. Seat was adjusted down low with some rear leaning V angle vs flat. Will have to try some of the suggestions here.
2020 X4M Comp. (currently stock) - Was 2015 335 MSport -MPPK -Borla ATAK -Dinan Sport+ - E.R. Charge pipe / 2013 X1 35i Sport - Dinan tune / 2009 X6 50i Dinan badged |
04-28-2016, 11:15 AM | #36 | |
Rep 241
I'm in the exact same boat-loved the seats in both e90 and e39.The seat in the f30 has been hurting me for over a month already. |
04-28-2016, 01:37 PM | #37 | ||
Rep 3,066
04-29-2016, 06:49 PM | #38 |
Rep 3,066
received a 328xi LCI with saddle brown interior as a loaner - seats definitely felt different and firmer compared to black leather in my 340i. Definitely strange... maybe my mind is playing tricks on me.
04-29-2016, 07:44 PM | #39 | |
Rep 284
Drives: F30 335i EBII MPPK/BBK
Garage List 1999 Honda CR-V [0.00]
2013 BMW 335i [0.00] 1986 BMW 325e [0.00] 2014 Porsche 991 Ca ... [0.00] 2018 Audi SQ5 [0.00] 1971 Volkswagen Sup ... [0.00] |
04-29-2016, 11:30 PM | #40 |
Rep 310
Drives: 2018 EB F31 2018 LG F80
Garage List 2020 BMW M2 CS [9.83]
2021 Porsche 718 Sp ... [8.50] 2021 BMW R1250GSA [0.00] 2014 Boxster S [0.00] 2013 BMW R1200GS [0.00] 2011 1 Series M Coupe [10.00] |
