BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Jb Tune installed n55
European Auto Source
      01-29-2013, 11:30 AM   #23
NICKTENN
NICKTENN's Avatar
Drives: 340i M Sport
I saw Terry mention he was working on a new firmware and would post it in a new thread when it was ready for testers, but I never saw the new thread created, so I don't think it's ready yet.
Run on sentence what up!
2016 340i M Sport Alpine White, BMS Intake, JB4 Beta
2012 335i Sport Line, RIP
      01-29-2013, 12:03 PM   #24
bananachipz
Drives: F30 Mineral Gray 335i
LMFAO
      01-29-2013, 12:56 PM   #25
NateDog07V
Drives: '13 335i M-Sport BSM/CoralRed
Curious what the ideal shift points are with this tune... when Hartge 'demos' their tune, they seem to manually shift around 6k on the stock tune and around 6500 with their aftermarket tune for their comparison video.... obviously this car drops boost up top quite a bit, so once the Stage 1 is in, where is the best place to shift for fastest times?
      01-29-2013, 04:10 PM   #26
TreDirtyFive
Drives: X3 M40i
There are a few testing, including myself..you will all love it.
X3 M40i G01, M235i F22, 335 F30 MSport, 135 DCT, 335 E92, Audi A3
      01-29-2013, 04:33 PM   #27
bananachipz
You teasing mofo!!
more power? more features? reach-around?
      01-29-2013, 04:44 PM   #28
NICKTENN
NICKTENN's Avatar
Originally Posted by bananachipz
You teasing mofo!!
      01-29-2013, 04:47 PM   #29
NICKTENN
NICKTENN's Avatar
By the way, does this firmware require the solenoid plug to be plugged in? Currently mine is unplugged and everything works great.
      01-29-2013, 06:27 PM   #30
TreDirtyFive
Drives: X3 M40i
"some" cars that still have the pneumatic solenoid (non electronic) will be able to use the solenoid connector along with the new firmware for even more benefits. The newer electronic setup, BMW's change for emissions and or better mileage?, will still only use 2 connections but still have much improved tip-in and drivability on the update. More to come shortly.
      01-29-2013, 07:03 PM   #31
TreDirtyFive
Drives: X3 M40i
Originally Posted by bananachipz View Post
New firmware??? Looks like Ballz and I are going to have a firmware update/rear spoiler install meet!
ya baby!!!
I assume there is a link to it on n54tech?
not yet, it's in testing stages.
      01-29-2013, 08:20 PM   #32
buildbright
buildbright's Avatar
92
Drives: F80 M3 MG
You teasing mofo!!
Take that ATS! Reach Around!
      01-29-2013, 08:25 PM   #33
NICKTENN
NICKTENN's Avatar
When you say "some" cars, are you referring to pre-F30's, or are there some versions of the F30 with pneumatic diverters?
      01-29-2013, 10:01 PM   #34
TreDirtyFive
Drives: X3 M40i
F30s only...My car is a Sept 2012 build and uses a pneumatic (mechanical) solenoid. Most Nov 2012 and newer F30's have the electronic valve.
      01-29-2013, 10:23 PM   #35
NICKTENN
NICKTENN's Avatar
I see. I'm an April 2012 build, so it would seem mine is pneumatic. Is there anything I can look at to verify (under the hood, realoem.com)? Looking forward too any other deets you can provide us.
      01-29-2013, 10:51 PM   #36
rallybull
rallybull's Avatar
Drives: F30 335i w/PPK
If the published dyno charts for stock f30 n55 are correct, the hartage driver should not be shifting the stock car at 6000 rpm, but instead at 6500 rpm (unless the idea is to increase the time intentionally )
      01-29-2013, 11:16 PM   #37
NICKTENN
NICKTENN's Avatar
Is #9 what we're talking about? It would seem mine is electric (used last seven digits of my VIN to pull data from realoem.com). Or am I way off the mark?
Edit: this is not the waste gate actuator in question (per Terry).
      01-30-2013, 07:55 PM   #38
RollingLower42
RollingLower42's Avatar
44
Drives: 2012 BMW 335I
I love my Jb4 stage 1, BMS, whatever the hell it is called..
Has anyone else put in 100 Octane??
I can say for a fact, that mixing the 100 octane, with the tune, HFC DP and the exhaust, there is a HUGE difference in power..
Not sure exactly why the higher octane really is so much better for your engine, but it is pretty crazy!!!
      01-30-2013, 08:31 PM   #39
buildbright
92
Drives: F80 M3 MG
I know I cant wait for meth kits and or Flex Fuel wires for our N55.
      01-30-2013, 11:26 PM   #40
FotiosF80M3
FotiosF80M3's Avatar
Drives: 2015 F80 M3 AW/SO 2015 X5 Msp
I saw an article on turner motorsports about there car having the tune. Someone was doing an article on it and Said it didn't seem to make the claimed gains. Im glad I didn't get that, I almost did.
2018 M3 COMPETITION Mineral white, Black,
carbon roof, black 20's, Mperf splitters/Blade, carbon spoiler, mirrors, etc
      02-01-2013, 10:35 AM   #41
NICKTENN
NICKTENN's Avatar
Here's a pic of the pneumatic solenoid.
      02-01-2013, 04:54 PM   #42
Jadar
Jadar's Avatar
Serbia
1565
Drives: 2013 F30 335i MSport
Because 100 has higher activation energy. It also burns cooler and its density makes it more efficient and allows for the tuner to automatically adjust pull more timing hence more power. Higher octane, less chance of detonation a lot less.
I have seen guys with forced induction cars convert to E85 and make 80-100 more horsepwer then a car on 100 octane.
For example my 2004 cobra put down 614rwhp with the addition of a twin screw supercharger, and my friend with the same setup only difference was e85 made 701 to the tires snce I was on 100 octane and e85 is technically around 110. Hope that sums it up.
FBO-PS1 and stuff
      02-01-2013, 05:26 PM   #43
buildbright
92
Drives: F80 M3 MG
E85 is cool stuff but it has its cons too.
      02-01-2013, 05:58 PM   #44
Jadar
Jadar's Avatar
Serbia
1565
Yes it does. One thing to run it on a cobra and a whole other story running it on your 57k bmw.
I wouldnt do it, its a hassle to convert. Shitty fuel economy to say the least.
FBO-PS1 and stuff
