BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Coding cable and ESYS, psdzdata
Studio RSR
      12-06-2014, 04:14 PM   #67
shawnsheridan
shawnsheridan's Avatar
Originally Posted by gregi View Post
Hi Shawn,
have a 2012 f30 and my Bimmber Contractor just updated software two weeks ago Could you provide me with latest esys, code and data please. Thanks in advance!
PM sent.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
      12-07-2014, 05:11 PM   #68
chromatic
Drives: M3
Originally Posted by shawnsheridan View Post
PM sent.
Hi Shawn, Can you also please provide me with latest esys, code and data. Thanks a lot!
      12-07-2014, 09:37 PM   #69
shawnsheridan
PM sent.
      12-07-2014, 10:15 PM   #70
chromatic
Drives: M3
PM sent.
Thank you very much!
      12-12-2014, 09:15 AM   #71
M52013UDM
M52013UDM's Avatar
Drives: 2013 M5 SS
Need links to D/L all the coding S/W - Thanks Shawn
PM sent.
M52013UDM
      12-14-2014, 02:59 PM   #72
f30mvp
MVP
f30mvp's Avatar
Drives: BMW F30 XDrive
modify the read FA, VO Code
Hey Shawn,
Got the FA coding to work. I was missing the the apply button in bottom right.
Now I want to enable "Activate Enhanced Bluetooth" & "Activate iDrive Office"
This is the info I have for Bluetooth
MODIFY THE READ FA - Change 6NH to 6NK or 6NS from the vehicle FA.
VO CODE - CMB_MEDIA and HU_CIC/HU_ENTRY or HU_NBT
For this my question is how do I know if I should change it to 6nk or 6ns.
Also for the VO CODE part I am not sure what I should be coding.
As for the iDrive Office here is the info and questions I have.
MODIFY THE READ FA - Remove Country Controller code (SL8Ax) from the vehicle FA.
VO CODE - CMB_MEDIA and HU_CIC/HU_ENTRY or HU_NBT.
what if I don't see SL8Ax.
what do I VO Code?
Thanks in advance as always.
PS you have been very helpful and I would be happy to pay if forward. If any body has any questions I have successfully completed the following on my 2015 f30 xdrive
Coding
DVD in Motion
Enabled Rear Fog lights (shaved button)
Play Video from USB port
Change blinker from 3 to 4
Fog Lights while turning
Fogs on with Brights
Side Mirrors fold up w/fob or comfort access
Windows Go Up w/fob or comfort access
Activate Cameras while driving (side, top-view, and reverse)
Disabled initial 3 chime seat belt warning
Removed Camera Disclaimer
Removed initial iDrive disclaimer
Allow windows to be rolled up with door open
Physical
Led door sills kick plate
Blacked out kidney grill
Just so I am clear, you are in the Coding Module, FA is Activated, and you Read ECU and then Edit FDL, change a setting, and then the Save icon is still grayed out?
      12-14-2014, 07:12 PM   #73
shawnsheridan
what do I VO Code?...
Just follow my post here:
http://f30.bimmerpost.com/forums/sho...65&postcount=9
As written there, if Build Date is >=0713, I would use 6NS.
For U.S. car and Office, you do not need to remove country controller. L8A is for China spec car.
      12-14-2014, 07:48 PM   #74
f30mvp
MVP
f30mvp's Avatar
You are the Man!
Thanks for all your help!!! I now get text messages over bluetooth to my car. Thanks Shawn!
-2015 328i XDrive Sport-Black Sapphire Metallic | Leather Dakota Black/Red highlight
-ZSL | 7AC | ZCW | ZDA | ZDB | ZDH | ZLP | ZPP | ZTP | 688 | 8S4
      12-14-2014, 07:54 PM   #75
shawnsheridan
      12-14-2014, 08:32 PM   #76
f30mvp
MVP
f30mvp's Avatar
Code default Values
Ok this is a bad one.
While coding some how the dreaded "Code default Values" button was hit. for a little i freaked out as it seemed my system was bricked. I then noticed the code button was still highlighted so I clicked on it restored that data and thought everything was fine. I did not click the "code FDL" button.
Now when I attempt to connect via E-Sys it does not see my VIN. I have taken backups of the files as I want along each step. I really hope you might have a clue as to what to do because I am kinda back to freaking out a bit. Thanks for any suggestions you may have.
      12-14-2014, 08:43 PM   #77
shawnsheridan
Connection issue is not related to your Code Defaults issue.
Turn car off and wait 30 minutes and try connection again.
      12-14-2014, 10:27 PM   #78
f30mvp
MVP
f30mvp's Avatar
Activate High Beam Assistant (Anti Dazzle)
Just tried and you are correct it connected just fine (not sure what happened there).
Do you know of any negative side effects I might see from clicking on that code default button?
Also hopefully my last question. I want to code "Activate High Beam Assistant (Anti Dazzle)" it says it requires the vehicle to be equipped with High Beam Assistant. I have the camera on my review mirror if that is what they are referring to. I did not pay the $250 extra for "Automatic High Beams". So not sure
It says
MODIFY THE READ FA - Remove 5AP from the vehicle FA.
VO CODE - FEM_BODY and FLA/KAFAS2 (whichever you are equipped with)
I could not find 5AP in the FA but after removing 8S4 I VO CODE FEM_BODY and KAFAS2 just in case. Still don't see a difference. Please let me know if I am missing some thing. Thanks in advance.
      12-14-2014, 10:36 PM   #79
shawnsheridan
It says
So long as Code defaults did not corrupt any of your CAFD files, and you were able to VO Code all ECU's, then you should be fine.
In your case, without High-Beam Assistant, with the removal of 8S4 you would have only Variable Light Distribution, which is Anti-Dazzle of the Low-Beams. You would not have Glare Free High Beams, which is Anti-Dazzle of the High-Beams.
      12-15-2014, 06:40 AM   #80
phattbam
Drives: '17 Protonic Blue i3 REx
Hello Shawnsheridan,
I'm interested in getting the latest files as well. I will need to look at purchasing the cable soon. 2015 F30 335i
      12-15-2014, 06:44 AM   #81
shawnsheridan
PM sent.
      12-15-2014, 06:48 AM   #82
phattbam
PM sent.
thank you
      12-15-2014, 11:55 AM   #83
M52013UDM
M52013UDM's Avatar
Drives: 2013 M5 SS
Looking for all the coding S/W for my two 2014's (F10 M5 Comp & F30 335 xdrv)
Hey Shawn - sent you a PM and not sure if actually made it to your account???
Looking for all the coding S/W for my 2014's - I have a '14 F10 M5 Comp and a '14 F30 335 xDrive. Thanks and I appreciate your help.
M52013UDM
      12-15-2014, 12:32 PM   #84
shawnsheridan
No, I did not receive it.
PM sent.
      12-22-2014, 05:12 PM   #85
shuangsila
Drives: BMW F30 328 2013
This is very true. 3.25.2 was broke, and 3.25.3 works but has bugs, and until they are fixed, 3.24.3 is a wiser choice.
Hi Shawn, would really appreciate if you could pm a copy of 3.24.3...thanks a lot!!
      12-22-2014, 05:33 PM   #86
shawnsheridan
It's now 3.26.1 that you should use.
PM sent.
      12-23-2014, 07:16 AM   #87
SanMarino_F82
SanMarino_F82's Avatar
57
Drives: F80
I have 3.24.3 and PSD Lite V52.1
I need to code a new F80
Can you send me newest or will this work?
Thanks!
      12-23-2014, 11:28 AM   #88
shawnsheridan
Thanks!
PM sent.
