08-15-2020, 10:21 PM | #2 |
Rep 313
Drives: Like a hooligan
Looks killer. Which clay bar kit did you use?
2016 F30 340i M Sport | 2009 E92 328i 6MT |
08-16-2020, 12:13 AM | #5 |
David
786
Rep 2,009
I've seen a detailer say it's generally it's best to clay bar before a paint correction as you're just swirling your paint with the clay bar. Yes it feels smooth, but that does not mean a better finish.
08-16-2020, 05:58 PM | #8 |
Rep 1,911
clay bar's action is to lift / remove surface contaminants from paint, it has virtually no 'abrasive' action on painted surface.
08-16-2020, 06:03 PM | #9 | |
David
786
Rep 2,009
I saw it under a microscope with full clay lube being used.
BeerHerder250.50 |
08-16-2020, 07:16 PM | #10 | ||
Rep 1,911
08-16-2020, 07:40 PM | #11 |
Rep 2,212
Clay can cause some marring depending on your technique, how abrasive the bar is & how liberally you use the accompanying lube. It should not take 5 hours.
tex26702421.50 |
08-17-2020, 04:21 PM | #15 | |
Rep 849
Drives: BMW 435i
If you're lucky and use plenty of lubrication, the marring will be minimal. If you don't and/or the paint is really soft you can end up with some serious marring. Been there, done that. Seen the results under the lighting on my own vehicles and others. Like other have said, I'll never clay bar unless I'm prepared to grab my polisher and correct the paint. I do it at the same time as the pre-detail wash, so takes me about an hour to do both All that said, your car looks good!
08-19-2020, 09:32 AM | #16 |
Rep 126
Drives: 2024 BMW 228i Gran Coupe
You can also clay bar using your car wash solution for lubrication. I have done this for years. I foam cannon the entire car, then rinse. I then use the Clay bar with soapy water solution. it provides lubrication a lot easier than detail spray. I have done this for years on several Porsches that I owned and, for which, I received a lot of compliments. Black, Mahogany Metallic, and Dark Blue Metallic colors. I now have done it on my blue F30.
Pittcrew34.00 |
08-19-2020, 03:44 PM | #19 |
Rep 370
Drives: 2013 AW 335i
Nice work! It looks great
2013 Alpine White 335i -M Sport/// Akrapovic Catback Exhaust/// KW Street Comfort Coilovers/// BMS intake/// JB4/// ER front mount intercooler/// ER Charge pipe/// ER catless downpipe/// 18" Apex Arc-8 in Anthracite/// Michelin Pilot Super Sports
08-19-2020, 07:34 PM | #20 |
Rep 14
Do yourself a favor and drop the clay bar and get a speed clay. I do a foam canon spray and then a wash and then I use the wash solution as a clay lube. I just drop this thing in the bucket and then use it after every small section I put it back on the bucket and rub the face with my hand to make sure it's clear.
08-20-2020, 01:18 AM | #21 |
2JZ-GTE
3064
Rep 4,011
The reflection was so good in one pic the hood appears f80 bulge
08-20-2020, 06:08 AM | #22 |
Rep 1,699
Drives: 2014 428i and 2018 X5
How the hell did it take 5 hours?????
___________________ 2014 F32 428i M-Sport 2018 F15 M-Sport |
