05-29-2015, 04:47 AM | #1 |
Gettin It Figured Out
1820
Rep 2,669
BimmerTech Audiotec Fischer PP82DSP AMP Retrofit
Thoughts? Are they utilizing Technic harness? Decent amp retrofit?
Can be found HERE Edit: I have Standard S676A HiFi .
05-29-2015, 06:13 AM | #2 | |
Rep 12,997
BimmerTech/Helix PP82DSP uses a custom designed Technic PnP HiFi harness.
As the HiFi OEM amp direct replacement, the PP82DSP provides about 4-5 times the output power, a 56-bit fully user-adjustable DSP, subwoofer outputs and remarkable sound quality, volume, clarity and stereo separation improvement over the OEM amp, even with OEM speakers. And obviously, 100% PnP. Quote:
05-29-2015, 09:18 AM | #3 | |
1820
Rep 2,669
05-29-2015, 12:48 PM | #4 | |
Rep 1,201
In your opinion, would this amp + bavsound speaker perform better than the factory Harmon Kardon setup?
2022 X7 M50i Phytonic Blue
2019 M5 MBB (wife's DD) |
05-29-2015, 03:06 PM | #5 |
25cent millionaire
252
Rep 1,220
Drives: 2020 m4 comp vert
guys I have been using this product for over two yrs. now.. its is so easy to install and makes a huge difference. if you don't want to upgrade your speakers but want kick but sound, this is your device. Even upgrading your speakers and this is killer. Kills the junk hk , and the even worse alpine upgrade.. Patryk will be more than happy to sell you one.
05-29-2015, 03:27 PM | #6 | |
1820
Rep 2,669
You know, now that I think about it, he did seem rather pleased when I purchased their MultiMedia Interface and SmartView... .
Westsider4513.50 |
05-29-2015, 07:38 PM | #7 | |
Rep 378
Drives: G30 540i xDrive
05-30-2015, 01:31 PM | #10 | ||
Rep 12,997
The best HiFi upgrade still is replacing both the OEM speakers and the OEM amp. Quote:
05-30-2015, 07:03 PM | #11 | |||
Rep 1,201
05-30-2015, 08:10 PM | #12 | |
Rep 32
BTW, where's the amp located in the F31 wagon? Is it under the cargo floor? The BimmerTech site says compatible with F3x so I assume the wagon has the same amp mounting even if it's in a different site than the sedan. |
05-30-2015, 09:11 PM | #13 | |
Rep 12,997
05-31-2015, 05:54 AM | #14 | |
Rep 51
05-31-2015, 06:34 AM | #15 | ||
Rep 1,126
05-31-2015, 07:04 AM | #16 | |
Rep 12,997
- http://www.audiotec-fischer.de/files...Guide_Vol1.pdf There is no aftermarket unit in the market that changes the iDrive OEM software at all. Never been. |
06-01-2015, 05:27 PM | #17 | |
Rep 1,201
I am very pleased with the BSW speakers but I am now wishing for more bass. I don't need whole lot more but just a little more. In your opinion, would adding the Bimmertech amp help with that and provide some more bass, or should I just look into replacing the underseat subwoofers? Are there any on the market that are a direct swap with the stock ones?
06-01-2015, 06:13 PM | #18 | |
Rep 12,997
Real bass only comes with power. The OEM amp lacks power. No OEM woofer replacement will give you the bass that you want with the OEM amp.
The PP82DSP provides that power. Quote:
06-01-2015, 06:18 PM | #19 |
Rep 1,201
Great! Thanks for the advice and it looks like I'll be ordering the PP82DSP!
08-09-2015, 01:21 PM | #20 |
Rep 41
Well from all comments above I decided to buy PP82DSP I have F30 HiFi I will see installing the amp first I hope I will be satisfied if not replace oem speakers with BSW speakers ? or any other speakers you guys suggest?
08-09-2015, 02:27 PM | #21 |
Rep 919
Would the JBL MS8 provide power like the PP82DSP AMP? I have the MS8 and Bavsound Stage 1 speakers sitting in my living room already just wondering if I should sell the MS8 and buy the PP82DSP instead...
08-09-2015, 10:09 PM | #22 | |
Rep 29
Another thing, When I was reading other review in the forum. It mentioned that for the M4 with BSW speaker and bimmertech amp/dsp, it needs to have "ASD" off. is this the same case for my F30? And where can i turn it off? Thanks. Last edited by anleizhang; 08-09-2015 at 10:37 PM.. |
