06-03-2013, 04:38 PM | #3741 | |
Rep 1,130
Drives: '16 340i AW MSport
What do you think the option Tagfahrlicht (DRL) does? ONLY the DRL are on and the Xenons never turn on period in Auto mode?? Last edited by kromix; 06-03-2013 at 06:50 PM.. |
06-03-2013, 06:11 PM | #3742 |
Rep 1,027
Help...
NO ZGW available. will not pull my vin. I was connected and coded fine yesterday and chose disconnect last night. now I try to connect and no ZGW and no VIn shows.. tried restarting car and laptop.. I have the DIST folder in all directories.
M Sport Line Estoril Blue
06-03-2013, 10:07 PM | #3743 |
Rep 1,976
Drives: 2020 G20 320i M Sport
Might sound dumb but is there a link and connectivity light on the ethernet cable? I was an idiot and it turned out that the plastic slacks on the RJ45 cable were bent and weren't providing a proper connection to the NIC on my laptop.
06-03-2013, 11:18 PM | #3744 |
Rep 1,892
06-04-2013, 01:55 AM | #3745 |
Rep 16
Just lock the car and wait until it sleeps. Then try again.
06-04-2013, 07:17 AM | #3746 |
Rep 1,027
Yep i have link light and the Nic searches for ip like normal. I will try again shortly.
06-04-2013, 10:27 AM | #3749 | |
has left the building
90
Rep 3,359
Can I just double check something regarding backups before I do anything major?
Is this still valid? Quote:
06-04-2013, 10:36 AM | #3750 |
Rep 1,027
Yep ..didn't change a thing and it worked fine this am..
I cant find in the google doc. Where is the timeout for mirrors and doors to make it zero press and hold?
06-04-2013, 11:51 AM | #3751 | |
Rep 1,892
Value is in 100ms (0.1 sec). Default value is 0x0F = 15 * 100ms = 1.5 seconds. If you set it to 0, the mirrors will fold every time you lock the car. Some people want this, but I don't. I have mine set to 3 (300ms). I keep it pressed (fob or CA) another heartbeat and they fold. |
06-04-2013, 11:55 AM | #3752 | |
Rep 1,892
But, since you can easily VO code an ECU back to the factory defaults, I've stopped worrying about having backup copies of the original .ncd files. I think it's actually easier and safer to VO code to defaults than trying to restore from a backup .ncd file. |
06-04-2013, 03:38 PM | #3754 |
Rep 3
Drives: 2013 BMW 328i Sport Sedan
Which part PsdZData download?
Hi,
Does anyone knows which PSdZData should I select. When opening the link for download, it shows several options. From part 1 to part 19. I cant make E-Sys work because I believe I am selecting the wrong File. I appreciate your help guys. |
06-04-2013, 04:02 PM | #3755 |
Yr1OfD1
107
Rep 900
download everything then unzip it to your hard drive.
06-04-2013, 04:04 PM | #3756 |
Rep 1,130
i think you mean the .rar files, you need to download WniRAR and extract the file.
06-04-2013, 06:10 PM | #3757 |
Rep 1,892
06-05-2013, 09:17 AM | #3758 | |
Rep 1,130
Between frogman and Shawn they have all the answers |
06-05-2013, 10:03 AM | #3759 |
90
Rep 3,359
Bundled into the back of a black 7er and taken to the woods just outside Munich. After he'd made their windows roll up with the doors open and turned off the stop/start for them they tied him to a chair and shone a lamp in his face.
06-05-2013, 10:10 AM | #3760 | |
Rep 1,027
Also for the idrive mlogo where is that located
06-05-2013, 10:13 AM | #3761 |
Rep 304
06-05-2013, 11:08 AM | #3762 | |
Rep 40,837
I think though this is a function of the Welcome Lights. In F10, I would look at WL_FUNKTION_POL and see what my options are, and other "WL" settings. Inherently, what you are asking represents a conflict. By putting the switch in Position 4, you are disabling DRL, yet wanting DRL's as welcome lights, so this may be a lost cause.
