07-16-2013, 05:35 PM | #420 | |
Rep 1,044
$1800 for labor??? Is that not too high? How many hours of work did they mention? |
07-16-2013, 10:29 PM | #421 |
Rep 349
I find out tomorrow. If it's anything more than 6hrs I'll consider doing it myself or take it elsewhere. If you have an M-Sport, this is a straight forward swap. Assuming you have the tools and a spring compressor.
If I have to do it myself I'll probably just take the struts to a suspension shop and pay them $20 bucks to do the spring work. last time I did suspension work I about lost my head with the cheap loaner I got from autozone. |
07-17-2013, 03:27 AM | #422 | |
Rep 357
"The front and rear sway bars are located between the body and respective subframes. In order to replace/swap the sway bars the subframe has to be partially or almost completely removed. To facilitate this, the engine has to be supported from above for the front subframe and the exhaust and drive train need to be partially removed for the rear subframe in order to allow enough clearance between the body to allow for part removal. The swapping and disassembly of the struts is also somewhat labor intensive as well. I looked up the normal labor time to do these repairs and it shows about 17hrs so the 13-14 is actually lower then what is normally charged. I hope this answers your question." |
07-17-2013, 01:42 PM | #423 |
Rep 357
I think it depends if you're going from MSport --> Performance suspension or Stock Suspension --> Performance suspension (like I'm doing). My understanding is that you already have the correct sway bars if you have MSport, so this portion wouldn't need to be done. Can someone chime in and let me know if this is correct?
07-18-2013, 10:47 AM | #424 |
Rep 349
I was quoted 6hrs on an M-Sport + alignment.
Bl@ster's response saddens me. It's hard to believe you have to go through all that just to get to the sway bars. If it were me, I'd trade in for an M-Sport rather than have them tear apart my car like that. |
07-19-2013, 06:00 PM | #425 | |
Rep 4,323
The BULK of the time (something like 4-5 hours) was the sway bars. BUT well worth it...the springs and struts don't take too long, BMW was kind in that manner...
07-20-2013, 07:15 AM | #426 | |
Rep 4,323
that's with free springs (dealer covered) and $170 alignment....it's definitely a lot, but the sway bars made a world of difference on the track, and the fact that I could pass 4 door M3's on the track (and nip at their heel; independent of driver skill), surely must demonstrate the strength of the setup.
07-23-2013, 02:00 PM | #427 | |
Diligentia Vis Celeritas
558
Rep 1,477
Drives: 335i
I just ordered a 2014 M Sport w/ DHP, and while I'm planning on sticking with the EDC dampers for the time being, I am considering shorter/stiffer springs...either the M Perf springs, or maybe H&R Sport. But any other suggestions for fairly inexpensive suspension mods to tighten things up would be appreciated.
07-23-2013, 02:20 PM | #428 | |
Rep 4,323
Spring wise, you can always try the M Performance ones, but I believe there are more people that have used the H&R springs on the DHP setup...
07-25-2013, 04:53 AM | #429 |
Rep 1,093
Took the time to read the 20 pages on this thread but totally worth it .
So I'm on a baseline 328i with 17 inch wheels. I may get some money back from the previous cars extended warranty refund (that was a loaded e90 335i) so I'm thinking ill spend it + a bit more on making this car handle well. So my question: if I get this m performance suspension upgrade but keep the stock wheels and tires, will that make much of a difference? Looks like I can either upgrade wheels and tires or the suspension kit, I'm leaning towards the suspension. What do you think? Anyone done this with a base 328i and 17" wheels? Thanks in advance, and thanks for sharing all your experiences shivaswrath, bananachips and others! |
07-25-2013, 07:29 AM | #430 | |
558
Rep 1,477
Drives: 335i
Depending on what tires you have (run flats?), upgrading may have a significant improvement here as well. Larger wheels are primarily for looks, but tires can make a huge difference in handling.
07-25-2013, 07:57 PM | #432 |
Rep 1,093
Just curious if anyone did this on the 328i, especially base 328 with 17" tyres (I see a lot of 335is in this thread). Anyone from California? If you can share what deal you got for this installation, any reviews on which dealership did a good or bad job, would be nice.
Also curious - people who started out with baselines replaced the suspensions - did you do anything to change your steering wheel? Does that make a difference at all? My dealer quoted around 2500 for the steering wheel , apparently because you need to replace airbag and buttons too. Definitely not worth it imho. What do you think? |
07-26-2013, 08:36 AM | #433 | |
Rep 4,323
07-28-2013, 03:50 AM | #434 | |
Rep 357
07-28-2013, 04:00 AM | #435 |
Rep 1,093
That's nice, bl@ster! What is it costing you for parts and labour?
Are you keeping the stock 17" wheels and tyres? I'd really appreciate if you could provide detailed "before" and "after" driving impressions. I'm still wrapping my mind around what's a suspension limitation and what's a tire limitation with the stock setup's handling. Only getting more confused the more I think about it . Looking forward to your update. Thanks in advance.
Has a bad car addiction
07-28-2013, 07:56 PM | #436 |
Rep 1,093
Hey shivaswrath / bananachipz / others,
What wheel and tire combo do you have with the m perf package? Specifically, is that engineered to work only with OEM BMW tires / wheels, or is aftermarket ok? If you were in my situation, which would you do first in order of installation - install aftermarket wheels + tires from a third party shop, get it aligned and the take it to BMW for the mperf? Or the other way round- install mperf suspension, then take it to third party for wheels and tires? Just wondering which of the two has less likelihood to screwup alignment and other settings.. Also will bmw refuse to do mperf suspension if I change to non-oem wheels and tires?
07-29-2013, 05:20 AM | #437 | |
Rep 357
I can provide before and after driving impressions, sure. Others have reviewed the new setup as well. I was initially quoted $2600 for parts and $1850 for labor but I am getting them to give me a discount since I balked at that quote. What's your local dealership quoting you? |
07-29-2013, 10:04 AM | #438 | |
Rep 4,323
The tires matter, only really if you're tracking, as I had my M Performance Suspension installed during the winter, and had the winter tires on
07-29-2013, 10:43 AM | #439 |
Rep 349
I humbly disagree. most drivers can easily reach the limits of the stock tires on the street...if you try. Don't get me wrong. It's not going to be a safety issue per-se, but under the right conditions you can get them howling real good. That said, being at the limit just adds to the excitement
07-29-2013, 12:06 PM | #440 |
Rep 1,093
Apparently under stock 17"s it doesn't take much- just throttle into any regular U-turns (that too on a dry road). I will be very, very careful driving this in the rain.
However the question in my mind is more about reducing the body roll and "tight" BMW feel. Looks lik I'll hav to get the suspension upgrade and decide for myself whether that gives the feel or not. I'll be a first on this forum with that combo .
