BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Super Cheat Sheet - PDF Attached! [Updated July 1st, 2015]
proTUNING Freaks
      10-20-2014, 02:59 PM   #89
Halsifer
Halsifer's Avatar
Drives: 2018 Audi RS7
Originally Posted by mbfanos View Post
For my car, to watch videos from USB, I had to add this code, otherwise it won't work
ENT_MC_VIDEO_SUPPORT ->Change to Aktiv
Interesting, I thought it was only for importing videos to the internal HD, which didn't function. I'll make note of it next update, thanks!
2018 Audi RS7 4.0T
2006 BMW e46 330Ci Convertible ZHP
2010 Audi S5 4.2L [Sold]
2014 BMW 335i xDrive M-Sport [Sold]
2010 Audi A6 3.0T [Sold]
      10-22-2014, 11:04 AM   #90
beppeM3+123d
beppeM3+123d's Avatar
203
Drives: bmw m3 dct + 123d e81
I want to share that eco pro mode default coded in icm modul will disable start stop memory function!
It work only until you will not close the car.
If added in the notes could be useful!
      10-28-2014, 12:46 PM   #91
YMB-M3-J2
YMB-M3-J2's Avatar
Drives: YMB M3
Originally Posted by botho View Post
Hi,
Another question for experts
I wish decrease the speed for Active Blind Spot Detection activation.
Anybody can tell me what code to di that tweak ?
Thanks in advance
Best regards
EDIT : thanks shawnsheridan post on another forum, i found it !
ICMQL => 3000 => C_ZSW_Aktivierunggeschwindigkeit_Funktion_low : default value 20 km but can set 10 km :-)
Edit2 : this is working but active blind detection goes to off with fault in module.. Reverted back
Did you ever get this working at a lower speed?
      10-28-2014, 01:18 PM   #92
beppeM3+123d
203
very interested in this function, i had acc on my f32 and i hope to reduce speed very soon if i have to try any coding just tell me
      10-28-2014, 01:39 PM   #93
beppeM3+123d
203
question for expert people about DRL:
instead of changing each parameter about rear tail light to turn on, what do you think about add to vo this SALAPA code S8TLA and S8TNA to have menu on the 609?
thanks in advance for reply...
      10-28-2014, 04:19 PM   #94
botho
France
Drives: 2014 F31 330d xDrive Luxury
Nope. As i said, activating this function at 10 km/h make the module going to fault and deactivated.
I reverted back to the default settings : 20 km/h
      12-23-2014, 01:49 PM   #95
Halsifer
Halsifer's Avatar
Updated to v1.6 (12/23/2014 11:45AM PST): (Download in the original post as an attachment)
  • Added Code: 'CLM_TIMEOUT_HK_SMO' - Change the Comfort Access trunk opening delay time.
  • Added Code: 'CLM_SMO_INDICATOR' - Turn off taillight flashing when opening trunk via Comfort Access.
  • Added Codes: Enable LIM Function. (It will change Cruise Control's 'SET' button on the steering wheel to act as the 'LIM' button)
  • Added Codes: Show Active Cruise Control iBrake Distance in HUD.
  • Verified Code: ENT_MC_VIDEO_SUPPORT -> Moved to 'Video In Motion & Playback Features' (Does not save videos to internal HD)
If anyone decides to test out the codes in the 'TO BE TESTED' section, and finds out if it works or not, please let me know! :thumbup:
2018 Audi RS7 4.0T
      12-23-2014, 03:12 PM   #96
YMB-M3-J2
YMB-M3-J2's Avatar
Drives: YMB M3
what does this do to the SET button when you activate the LIM?
      12-23-2014, 09:24 PM   #97
azwillnj
Drives: 2023 M340i xDrive
It makes it set and cancel the speed limit and thats it. To set cruise you use the resume button.
Current: 2023 G20 LCI M340i xDrive
History: 2005 E90 325i > 2008 E90 328xi > 2011 E90 LCI 335i xDrive > 2013 F30 328i xDrive > 2016 F30 LCI 340i xDrive > 2020 G20 M340i xDrive
WE ARE!
      12-27-2014, 06:45 AM   #98
andre42k
Drives: F31
Lim function works great
      12-27-2014, 11:29 AM   #99
KGB_123_99
Drives: '17 330ix M-Sport, '09 528ix
Cool, but what is the purpose of the LIM? Maybe I am just a bit slow today...
      12-27-2014, 12:19 PM   #100
tboooe
tboooe's Avatar
925
Drives: F36 428i GC, E36 M3 - gone :(
HA HA. I had to read up on it too. I guess you can set an upper speed limit that your car wont go past.
      12-27-2014, 12:49 PM   #101
Ganxxta
Drives: F32 4er Coupé
I only have the SET Button but I remember I was able to set a limit to where the car does not go faster.
So what the difference to the actual LIM button functionality?
      12-28-2014, 12:00 PM   #102
Halsifer
Halsifer's Avatar
Sorry, let me clear this up. The LIM function is a feature they removed from the U.S. vehicles and some other vehicles. It is used to set a speed limiter on yourself in the case that you did not want to use cruise control but there is a certain speed you do not want to go over.
So basically, you can turn it on whenever, set the speed, and it will restrict you from going past that speed. The difference between LIM and cruise control is that with LIM, you are in full control of the throttle and maintaining speed. It's mostly used wherever you will have stop and go driving and highly enforced speed limits.
2018 Audi RS7 4.0T
      12-29-2014, 05:37 AM   #103
teaston
Drives: X3 M40d
This cheat sheet is great! I'd just like to let you know of some mistakes in it:
Under safety features and precautions, for seatbeltreminder_SBR_fahrer & seatbeltreminder_SBR_beifahrer you have got driver and passenger the wrong way round in the comments.
Under Enable Taillights as Day-Run Lights & Activate Rear Fog Lamps, you have written MAPPING_TAGAHRL_H2_L_OUTPUT and MAPPING_TAGAHRL_H2_R_OUTPUT but there should be an F in TAGFAHRL
      12-29-2014, 05:52 AM   #104
vinniem
Drives: 316i family member & 430i
Halsifer, thanks for the list.
for the f30, do you know if you can decrease the speed for Active Blind Spot Detection activation? current default 50km. i see it on F10, but no-one has any info on f30. any ideas? thanks
      12-29-2014, 06:59 AM   #105
botho
France
ICM > 3000 > C_ZSW_Aktivierunggeschwindigkeit_Funktion_low : 20 km / Werte=01
Do not test under 20 km, i tried and fault error occurred
      12-29-2014, 02:19 PM   #106
vinniem
thank you
      01-07-2015, 04:56 PM   #107
stonefocus
stonefocus's Avatar
28
Drives: 2013 ActiveHybrid 3
Thanks!!!
      01-07-2015, 05:40 PM   #108
Halsifer
Halsifer's Avatar
Thank you very much! I'll be sure to fix those next update!
botho, wait, did you lower it, while still being above 20km/h, and does it through no error codes?
2018 Audi RS7 4.0T
      01-07-2015, 08:00 PM   #109
cryptz
Drives: 2015 m4
I wanted to mention I just got updated by my dealer yesterday. on my 435i with msport package the M performance kombi logo does in fact display properly. also disabling the auto stop notification on the kombi was moved from section 3000 to 3003. I was able to search for it by the same name and found it though.
      01-08-2015, 12:05 AM   #110
mfranco42
Drives: 2014 320i XDrive Sport Line
Sports AT Active?
Thanks, Halsifer. The list was super helpful.
Quick questions for anyone who's coded Sports AT.
I coded SAT into my MY14 320i (w/ sport pkg, no other packages), but I haven't noticed any difference at all in performance. Is there any way I can verify in the car that it actually is active?
Also, since I have the Sport Line pkg, does that mean that Sport+ mode is already active? I'm already able to select it in the car, but on the BMW site it apparently only comes with the tech pkg. The other strange thing is that when I looked into coding it (ICMKOD_B_SPORTLENKUNG), it showed as nicht_vertaur (or something like that). Is this Sport+ mode different than the one that is already available. Any ideas? Thanks in advance!
