02-20-2020, 07:54 AM | #1 |
Rep 20
Could I run BM3 STG2 with just a dp?
I'm on BM3 STG1 right now with a catless downpipe, for stage 2 you need a downpipe, intercooler, and chargepipes (but those are optional). I'm in Florida so it's normally hot and humid but when it does get cold outside could I theoretically run STG2 without the intercooler or would that be bad?
2014 F30 320i | BM3 Stage 2 | xHP Stage 3 | Euromotive Catless Downpipe | GPlus FMIC | MAD Chargepipe | GFB DV+ | 335i Muffler & Resonator Delete
02-20-2020, 07:55 AM | #2 |
Rep 3,680
You can, but you really shouldn't especially in Florida.
02-20-2020, 03:12 PM | #3 |
Rep 20
That's what I mean. But some days in winter it does get cooler and I was wondering if I could on those days
02-20-2020, 04:26 PM | #4 |
Rep 182
You're going to blow the stock chargepipe on stage 2 because of the added boost.
The stock chargepipe is plastic and blows on stock boost pretty frequently. Be ready |
02-20-2020, 05:20 PM | #5 |
Rep 3,680
You can, but you really shouldn't. You'll run into heat soak problems and increase knock risk.
CandyRedRC46242.00 |
02-21-2020, 10:06 AM | #6 |
Rep 20
Yeah that's fair enough I'll just wait until I can get the 2 together
02-21-2020, 02:49 PM | #7 |
Noob
Rep 13
It looks like you own a 320i so I strongly recommend you against going stage 2. The engine is more fragile that the low compression version, and the boost target and torque of stage 2 will cause issues. Stage 1 is maximum.
I think the forum already had some N20s with BM3 that blew. |
02-22-2020, 02:08 PM | #8 | |
Rep 191,503
Your car will not be making more power since ECU will lower ignition timing to keep the temp in check Your stock charge pipe will not last long with that kind of boost either
