BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > Cleaning your intake valve's carbon buildup
      07-02-2014, 09:49 AM   #1
utenigma
Drives: 2013 F30 335i 8SA M-Adaptive
For the N54, but basically the same for ours
Crazy amount of buildup at ~35k miles
      07-05-2014, 11:50 AM   #2
Drjsuh
Drives: 328xd wagon
Very informative. I had heard of similar issues with audi direct injection cars. Does anyone know if the diesel bmw's have the same issues since they are direct injection too?
      07-05-2014, 01:31 PM   #3
floydarogers
Curmudgeon and Pedant
floydarogers's Avatar
Drives: 2010 335d, 2014 328d
They have the same issues (check the E90POST\M47 M57 diesel forum); however the root cause is considerably different - on diesels the cause is EGR. The solution is also different due to the different head and intake design
It's hard to say how many diesel owners are having problems, as BMW doesn't say and these forums are not representative at all. Also, many people aren't having problems (like me) apparently due to driving regimes. The X5d's don't seem to be having as many problems, possibly due to higher engine loads (heavier, bigger car) and the presence of the low-pressure EGR in addition to high pressure.
      07-08-2014, 02:25 PM   #4
utenigma
All pure DI engines have this issue - oil vapors from the crank case ventilation system are piped into the motor's intake and ingested by the motor. On a non-DI car, fuel is injected above the intake valves, constantly cleaning them. On a DI car, fuel is injected directly into the cylinder, behind the intake valves so they're not cleaned.
Toyota uses a hybrid DI/port injection system where fuel is delivered by both mechanisms - the fuel injected into the intake port cleans the valves and prevents this problem. Interesting enough - that system was not designed to fix this issue but rather to address the fuel delivery problems at high RPM operation they had with older injectors. The clean valves were a welcome unintended side-effect.
      08-05-2014, 09:31 PM   #5
G80indy
Save the Manuals
G80indy's Avatar
Drives: Z3, E46, G80
I hope BMW goes the dual fuel-into-cylinder delivery route (DI and PI) in the B58 series.
Wishful thinking
2023 G80 6MT, CCBs
2002 330i Dinan, 5MT
2000 Z3 Conforti, 5MT
      08-07-2014, 10:14 AM   #6
SergioK
Drives: F30 328i
17 minute DIY video which probably translates to at the bare minimum 4-5 hours for a weekend mechanic.
      08-07-2014, 10:23 AM   #7
G80indy
Save the Manuals
G80indy's Avatar
Yeah
Can you imagine how bad it would be to not exactly get those valves tightly closed off, and getting a few walnut shell fragments stuck in a cylinder or cylinders.
This job is NOT for the faint of heart.
The whole carbon buildup thing is cause for pause in considering purchase of any DI car
2023 G80 6MT, CCBs
      08-13-2014, 04:30 PM   #8
tntsE90
Drives: e90
All you need is a bottle of:
CHEVRON COMPLETE FUEL SYSTEM CLEANER
      08-14-2014, 08:15 AM   #9
335i_4D
Now in the dark side !
335i_4D's Avatar
Drives: 2011 911S 997.2 Cab
Not sure.
When I used to be a mechanic, we had a lot, and I mean a lot of presentation of supposed miracle in a can.
After customers bought and used the product, the car always came back the same way a car without this put in the system ended up.
Not so much a believer of "mechanic in a can", sorry.
Present: 2011 Porsche Carrera S Cab, white (Now on the dark side!)
BMW X3 M40i (wifey)
Past:2012 335i Sport Black, 20" 356 wheels, M Sport Aero, MPE (Sold -kinda missed)
2010 X5 35d Black fully loaded (Sold)
2007 335i sedan Antracite (Sold and missed !)
      08-14-2014, 09:41 AM   #10
Orion4
Neither CHEVRON COMPLETE FUEL SYSTEM CLEANER, Techron or BMW's Cleaner (which in Techron) have any impact on the carbon issue since they are added to the fuel system which is then injection directly into the DI chambers, not touching or "washing" the valves and seats. I had a 08 335i and now a 13 335i and use Techron regularly to keep the injectors clean, I had the 08 cleaned at 40K miles and was surprised at the amount of carbon was built up in the valve area. Really mess.
      08-14-2014, 02:59 PM   #11
utenigma
This - fuel system cleaner in a DI engine does absolutely nothing to clean the intake valve train (does help the injectors stay healthy though). Detergents can't clean something they never come into contact with.
      08-14-2014, 03:04 PM   #12
utenigma
Originally Posted by 330indy View Post
Yeah
This part isn't scary - intake valves are closed for at least 75% of a 4 stoke motors rotation. You would have to be daft to not get the valves completely closed.
You might end up with some media residue around the valve seats that the vacuum doesn't take care of, but that's why you use walnut and not soda or glass or aluminum oxide or silicon carbide etc. If the engine eats a little walnut dust it's not going to hurt it.
      08-28-2014, 01:17 PM   #13
tntsE90
Drives: e90
http://www.techron.com/techron-concentrate-plus/
http://www.techron.com/images/img_in...rf_tab_sml.jpg
      08-28-2014, 04:02 PM   #14
Orion4
the pictures of the Intake Valve that show the buildup on the valve stem and back of the valve face being cleaned by the concentrate does not apply to our DI engines. The cleaner never touches these areas. The valve face will be cleaned which is better than nothing
      10-05-2014, 08:03 AM   #15
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
What interval are people seeing with the N55? I understand this engine has an improved CCV design over the N54 which were problematic.
      10-05-2014, 09:22 AM   #16
m6pwr
m6pwr's Avatar
48
Drives: '14 335i M sport
Th N55 does have a different and, BMW says, improved ccv system that should do a better job of separating or removing oily vapors before the air is sent on to the intake tract.
There are a couple other things that could mitigate intake deposits -
I think the current f30 n55 does a better job of controlling oil temps and keeping oil temps down, particularly when you start to "exercise" the engine.
BMW will be switching to Shell as its lubricant partner starting in 2015. One reason for the switch may be (and I'm guessing) is that Shell is way, way ahead of other oil companies in refining "gas-to-liquid" lubricants. These GTL lubes made from natural gas are very clean and have low deposition rates, and more to the point, have very low volatility (less oily vapors) compared to more conventional synthetics.
Finally, there was a thread on the BITOG oil forum about intake deposits and Doug Hillary (a very experienced lubricants engineer who has worked for Castrol and Exxon/Mobil) made this observation: "As for OCIs - I recommend following the Warranty requirements to the letter! When in Germany this year I was given some data from very reliable sources that suggests that shortening the OCIs and/or using non-Approved lubricants may affect intake deposits in a negative way." What he is saying is that the most deposition from an oil occurs when it is new or fresh. So, more frequent oil changes just feed or replenish deposits and accelerate intake deposits. Just one more reason to avoid unnecessary frequent oil changes. Stick to BMW's recommended oil change interval. Here's the thread http://www.bobistheoilguy.com/forums...72#Post2082572
'14 328d, '13 M3 ZCP, '12 535i, '11 335d, '09 Z4 DINAN Stage II, '05 330i ZHP, '05 M3 ZCP, '02 M3, '91 328i, '90 535i, '88 528e, '88 M5, '87 M6, '95 Z3, 95 M3, '93 M5, '87 325e, '89 535i, '86 635i, '73 Bavaria.
      10-05-2014, 07:05 PM   #17
Labeef
Labeef's Avatar
271
Drives: 320I Sport/Xenon
This is why I lease. All DI engines have this issue. The only way to solve it, is to use a secondary fuel injector in the intake to run a maintenance cycle. But like fuel injection 30 some years ago, it will have it's issue and get resolved.
Side not, to help with carbon build up. You need to ream your car once in a while to get the heat up and push the engine at high revs. BMW need to be driven hard, everyone with issue is usually pussy footed around town.
      10-07-2014, 01:01 PM   #18
johnofcross
johnofcross's Avatar
Drives: Superman 2013 F30 335i M Sport
Wow, very interesting find!
2013 BMW 335i Sedan Estoril Blue II M Sport 19" 403M|6MT|Dynamic Handling|Tech Package|Coral Red Leather|Park Distance Control|Harmon Kardon
      12-19-2014, 12:00 AM   #19
david51
david51's Avatar
France
576
Drives: bmw M3 F80
hello
I have a BMW F30 330d 2012 model 258ch totaling 116000kms
As with all my bmw I removed the intake manifold and agr valve to see if it was dirty and surprise
this is the first time I see such a fouling on 1.5cms intake manifold calamine
So dismantling and cleaning karcher
Piece that connects the intake manifold and the arrival of the exhaust gas
before
after
Entered the intake manifold
Intake manifold and disassemble plastic flap
To remedy to this problem I decided to buy oil recuperateur
Setting up the oil separator
Finally I have more oil in the air supply system
here is the kit bought on Ebay
Exhibit 19 has a flush cut on part 2
Attaching the quick coupling Ø12 (not supplied in the kit) to the cylinder head cover part
Attaching the quick coupling Ø12 on the part of air hose
Attaching the front of the radiator tank and installation quick coupling Ø12 in place of the original ones
Air inlet section view
View part cylinder head cover
View of the reservoir and oil level
Solidjake1037.00
      12-19-2014, 10:20 AM   #20
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
David51,
Do you plan on having the carbon cleaned off the intake and the intake valves?
      12-19-2014, 11:19 AM   #21
david51
david51's Avatar
France
576
Drives: bmw M3 F80
Originally Posted by F32Fleet View Post
David51,
I already cleaned karcher the intake manifold which is now like new
and I removed a section on the valve conduits scraping and sucking
but as I do not have the camera as the video there is some dirt to
valves
      01-04-2015, 09:07 AM   #22
DrivenByE30
DrivenByE30's Avatar
France
605
Drives: '12 F30 Lux 335i 6MT
For those in the US, do you think my dealership would do this task if I ask them before my car turns to 50k
