THE LARGEST BMW 2-SERIES FORUM ON THE PLANET
2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Wheels and Tires -- Sponsored by The Tire Rack Tire pressure
      07-06-2014, 03:17 PM   #1
lichenlt
Drives: M235i
Tire pressure
The dealership or VPC, not sure which one, set my tire pressure at 28/35. However, I see the recommended tire pressure on the side of the door says 32/38.
The front tires look a little under inflated when I asked my GF to test drive it. Is it because it's summer the pressure should be lowered to compensate for the high temp? or should I stick to the factory recommendation and add some air?
      07-06-2014, 03:37 PM   #2
zkeeper
zkeeper's Avatar
Drives: 2017 M2 & 08 Z4 si
This may sound slightly cynical, but the tire pressure may not have even been adjusted after arriving. Mine was low as well. I set it at the recco'd and its been great. They can loose a pound or so after some weeks--depending on the wheel config--so set it correctly, drive it, and then re-check once a month. Lower inflation is hard on tire wear.
      07-07-2014, 09:29 AM   #3
wmo168
Drives: Need one!
tire pressure depends on weather and cold and hot tire.
CurrentNone! RETIRED [15' GLA250][14' M235i F22 AW-ED 06/16/14][12' 335i F30 AW-ED 05/01/11 PCD 07/01/11] [11' M3 E93 MW-ED 08/13/09 PCD 10/14/09] [09' 135i E82 AW] [07' 335i E90 SB]
[ED Photo 12'] [ED Photo 11'] [ED Photo 09'] [PCD Photo 09']
      07-07-2014, 09:31 AM   #4
BEM-S4
BEM-S4's Avatar
Drives: Dinan M235, Dinan Sport Wagon
+1 get them warm then check.
2022 Macan S
2016 F31 328i xDrive Sport Wagon
2006 E46 330ci ZHP Convertible
      07-07-2014, 12:02 PM   #5
lichenlt
Drives: M235i
so the recommended pressure settings are for warm tires?
edit: According to TireRack, the tire pressure recommended in your vehicle's owner's manual or tire information placard is the vehicle's recommended cold tire inflation pressure.
      07-07-2014, 12:05 PM   #6
alz0rz
What goes here?
alz0rz's Avatar
450
Drives: 2019 G30 M550i
The pressures on the door jamb are for when the tires are cold.
When I picked up the car I had one of the front tires reading 53 psi (!!), 2 reading 43psi and 1 reading 38psi when hot.
2019 G30 M550i
GBNF:
2021 G80 M3, 2019 F90 M5 Competition, 2016 F80 M3, 2014 F22 M235i
      07-07-2014, 12:05 PM   #7
pikcachu
pikcachu's Avatar
1399
Drives: M235i (F22 Red angel)
no... recommended pressure is for cold tires....
you might get 34-35 and 40-41 when hot or more
      07-07-2014, 12:12 PM   #8
lichenlt
Drives: M235i
Thanks guys. I just corrected them to the cold tire pressure settings.
      07-07-2014, 12:18 PM   #9
BEM-S4
BEM-S4's Avatar
That's right I was thinking back to having so much trouble in the winter with my TPMS and having to warm them up. For lack of a better term there's frigid (ie winter), cold and warm.
2022 Macan S
      07-07-2014, 12:38 PM   #10
2msport
Drives: '14 228 MT
Are you guys putting N2 or O2 in your tires?
      07-11-2014, 09:53 PM   #11
Ramos
Ramos's Avatar
Drives: G20 2020 M340
Are the tire pressure reading in vehicle status accurate and do they adjust real time while you are driving? That would be awesome for track days!
      07-11-2014, 11:04 PM   #12
velopod
Drives: X5 50e, BMW R1250RT, Porsche
Just out of curiosity, what do you think the air you are breathing right now is mostly ...
      07-11-2014, 11:33 PM   #13
2msport
Drives: '14 228 MT
Just out of curiosity. What does the stem cap say on your car? If you're not aware of why people would fill their tires with pure n2, go google it.
      07-12-2014, 12:44 AM   #14
pikcachu
pikcachu's Avatar
1399
I use O2
      07-12-2014, 08:08 AM   #15
tccox
tccox's Avatar
Drives: 2014 228i Msport
I use a mixture of 78% nitrogen, 20% oxygen and some other trace gases. Has been working real well for me for over 45 years
http://www.edmunds.com/car-care/shou...-nitrogen.html
A peasant and proud of it
Save The Manuals!!!
      07-12-2014, 08:17 AM   #16
overcoil
Drives: M235i 6spd
Do the cars come from the factory nitrogen filled?
Do you think gas station or garage air-compressors contain too much moisture?
Does that moisture corrode tire pressure transmitters or interior wheel metal, I think TireRack said even tire wound steel belts can corrode frm moisture.
      07-12-2014, 09:22 AM   #17
pikcachu
pikcachu's Avatar
1399
I think they came with just air.... the advantage is that N2 has bigger molecules so it's harder for them to escape or leak....
imagine like filling it with golf balls against tennis balls... difference is just about 0.3 times so not really huge....
      07-12-2014, 10:35 AM   #18
2msport
Drives: '14 228 MT
That mixture has been working well for me for over 29 years. But it's always fun to try new things. Unless you're set in your ways.
      07-12-2014, 10:36 AM   #19
2msport
Drives: '14 228 MT
Yup. Doesn't leak as fast which sounds nice to me.
      07-12-2014, 10:38 AM   #20
2msport
Drives: '14 228 MT
They probably didn't. Ha. I have no idea though. Thought it would be nice to try it out. I'm sure the air from gas stations is just fine though
      07-12-2014, 07:34 PM   #21
phoenixbmwlife
phoenixbmwlife's Avatar
Drives: M235i & G30 540i
2014 BMW/M235i  [0.00]
Nitrogen in tires are a waste of money. The difference is so small that it does not warrant the cost or the inconvenience of refilling.
Yeah yeah yeah it's supposed to keep the air pressure more stable than air. There have been multiple tests out there to prove both sides so not worth it in my opinion.
Lack of money is not the problem. It is merely a symptom of what's going on inside of you! - T Harv Eker
Follow me on Insta
https://www.instagram.com/bmwm_life_/
https://www.instagram.com/autogiftua/
https://www.instagram.com/phoenixbmwlife/
      07-12-2014, 07:57 PM   #22
pikcachu
pikcachu's Avatar
1399
as long as its top tier air you are good to go :-)
2addicts
