07-08-2014, 11:12 AM | #1 |
Rep 34
Suspension very bouncy, normal?
took some photos of the rear suspension, is the yellow part supposed to be there? rear passengers complained the car being too bouncy (like a boat), i feel a bit too at the driving seat. any advice?
07-08-2014, 11:32 AM | #3 |
Rep 34
07-08-2014, 11:41 AM | #4 |
Rep 2,010
What mode are you using? There's a significant difference in ride quality (firmness) between the Comfort mode and Sport modes. And then there's the road surface itself
///M235i | Mineral Grey Metallic | Premium Package | Technology Package | Driver Assistance Package | Dakota Coral Red/Black Leather | Harman/Kardon Premium 360 watt sound system | 8-speed automatic
When writing your life's plan, use a pencil with an eraser |
07-08-2014, 11:55 AM | #6 |
Rep 6,926
Drives: 2018 M2 AW DCT
07-08-2014, 04:48 PM | #8 |
451
Rep 4,592
07-08-2014, 06:36 PM | #9 |
Rep 4,128
Drives: M235i & G30 540i
I would get your car checked. It's not supposed to feel like that at all.
Lack of money is not the problem. It is merely a symptom of what's going on inside of you! - T Harv Eker
Follow me on Insta https://www.instagram.com/bmwm_life_/ https://www.instagram.com/autogiftua/ https://www.instagram.com/phoenixbmwlife/ |
07-08-2014, 07:07 PM | #11 |
***** noob
1368
Rep 10,479
Drives: 325xi>M235i>428GCx Mspor
But u have a m235 so you have adaptive susp...did u order with rfts?
2006 325xi (Sold)
2014 M235I (Current) 2015 428xi Gran Coupe (STB) |
07-09-2014, 12:34 AM | #13 |
Rep 5
Hi, I am Dennis from HK too.
The M235i suspension is a bit stiff on bumpy road in HK, you will feel very strong force to pull you up and down, but the shock absorption of the damper is very good, you will not feel very hard landing. It is not feeling like a boat, just may feel the car make you strong shaking up and down. May be the road in HK is too bad. In general, it is OK and acceptable to me. It is quite close to my previous KW DDC suspenson in sport mode. |
07-09-2014, 02:52 AM | #14 | |
Rep 1
Schumy, keep us (in HK) posted once you have your car checked. I also find my M235i a bit bumpy compared to my previous 335i. |
07-09-2014, 02:57 AM | #15 |
Rep 1,053
If your 335 was an e90 with sport package, that car had a very rough suspension and the difference is huge between the m235 and that. IMO the suspension on my 335 was terrible and too rough on city roads
07-09-2014, 05:51 AM | #16 |
Rep 34
I want to clarify the m235 suspension bounces and swings (ie not just jumps up and down but from side to side too if say just one side of the wheels go over a bump).
It is however not stiff (unlike the A45 for example). The best way I can describe it is that it feels sort of like riding in a boat. |
07-09-2014, 07:11 AM | #17 |
Rep 5,577
Could be a lose suspension or weld if your description is accurate.
Dealer tech will put car on lift and check suspension joints near the wheels and then work his way up to the body attachments. They will then probably put on an alignment machine and chk for specs. At some point they will test drive and maybe even load car with additional techs to chk loaded suspension. Also may get bmw involved - do take car in as soon as possible. |
07-11-2014, 06:17 PM | #19 |
Rep 34
i tested my friend's 235 last night which feels pretty much the same so i think it is not unique to my car.
tried to play around with the tire pressure, which turns out that my tires were underinflated (less than 31psi). i changed to 34 front and 35 rear and the car now feels more "solide" and less bouncy. |
07-11-2014, 07:20 PM | #20 |
Lucky13
211
Rep 1,762
The rear should be 38 minimum if they are Michelin Pilot Super Sports and front and rear should be higher if you drive over 100 which might be hard to do in Honk Kong ( been there about 20 times).
1995 325i, 1996 328ci, 1997 528i, 1997 Z3 2.8, 2000 528i, 2001 X5 3.0, 2001 330i Convertible, 2002 M3 Convertible, 2003 M3 Coupe, 2004 M3 Coupe, 2004 Z4 3.0, 2004 X3 3.0, 2007 X3 3.0, 2007 335i Convertible, 2013 X1 28 sdrive, 2014 M235 manual, 2020 X3 30i Xdrive
07-12-2014, 12:55 PM | #21 | |
***** noob
1368
Rep 10,479
glad u got it sorted out, but i thought underinflated would give the car a more planted feel?
2006 325xi (Sold)
09-23-2014, 10:55 PM | #22 |
Rep 193
Randy Probst said this was the best bmw in 10 years. His only real criticism was that the suspension has "too many secondary motions".
It kind of bothered me at first too, but I'm used to it now. The car is so fast, well balanced and confidence inspiring that I can deal with it. |
