07-31-2014, 02:10 AM | #1 |
Rep 607
NBT iDrive controller with CiC.
During a cyberslacking session at work a couple days ago, I bought one of these:
I was momentarily seduced by its sexy German techie look. My question is, can this be used on a CiC car? My car is a 2012. If I unplug the old iDrive controller from the car, would I get a error code? Sorry for being a noob with BMW electronic, never had a mod bug but it is here and growing now *UPDATE 1* This is NOT a plug-and-play swap It's not simple like the good ol' days where the CiC controller plugging into the old CCC nav and voila While here everything physical bolt up perfect, upon installation, as soon as I switch the ignition on, the air con start to turn on and off erratically, and none of the input from the NBT controller works. 15 sec later my mechanical sympathy kicks in and I turn off the car as quickly as I can. I will continue to seek for solutions and post them here, as I really like this NBT knob. I am such a mod noob haha ps* no error code so far after this endeavor
08-01-2014, 09:53 PM | #3 |
Now in the dark side !
65
Rep 1,136
Present: 2011 Porsche Carrera S Cab, white (Now on the dark side!)
BMW X3 M40i (wifey) Past:2012 335i Sport Black, 20" 356 wheels, M Sport Aero, MPE (Sold -kinda missed) 2010 X5 35d Black fully loaded (Sold) 2007 335i sedan Antracite (Sold and missed !) |
08-02-2014, 03:28 AM | #4 |
Rep 607
Thanks for the bumps, really hope to find a solution to this. I am sure I am not the only one who likes the look of the NBT knob but not ready to dive into a $2000 CiC-to-NBT project
08-02-2014, 11:37 AM | #5 |
Rep 286
The issue is your Factory iDrive controller and CIC is communicating on KCAN1 bus. Your NBT/ZBE3 (touch iDrive controller) is for KCAN2 bus. You have to do a few wiring mods to get it working.
08-04-2014, 04:55 AM | #6 |
Rep 48
I had mine installed, was told that a additional wire was needed from CIC to the knob. I got mine installed at a workshop and its working fine, no error thrown.
08-04-2014, 09:57 AM | #7 |
Rep 1,573
props for letting your curiosity get the best of you and trying the modification. looking forward to seeing what happens next
2015i Cadillac Escalade ESV
08-22-2015, 02:50 PM | #8 |
Rep 3
Hi, interesting topic :-)
Double checking with you gents; -Overall dimensions and 4pin connector are identical to the 2012 CiC controller. -Does this retrofit involves more as swapping the original attached K-can lines with new K-can 2 lines taken from our OEM ZGW ? Or does it needs also a new+code ZGW to have K-can 2 on pins 48-49 ? Thanks to all for the feedback and/or input on this topic :-) Cheers ! |
08-25-2015, 08:33 AM | #9 |
Rep 1,976
Drives: 2020 G20 320i M Sport
You can use it on CIC but you will need to splice into the BODY CAN L and BODY CAN H lines on the block connector of your CIC as it uses a different BUS.
The writing functionality won't work but you should be able to use it as a controller knob.
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs |
10-17-2015, 04:24 PM | #10 |
Rep 12
Hello dear Friends
I need a help with installation of touch iDrive (NBT) controller to the E60 530i 2009 with CIC system. I don't need touch function of controller, all that i need its working controller with big knob in my car. Thanks a lot in advance |
10-21-2015, 12:04 AM | #11 |
Rep 29
[QUOTE=Aritaurus;18472588]You can use it on CIC but you will need to splice into the BODY CAN L and BODY CAN H lines on the block connector of your CIC as it uses a different BUS.
The writing functionality won't work but you should be able to use it as a controller knob.[/QUOTE thanks for the tip! where is the block connector of the CIC unit? |
10-21-2015, 12:28 PM | #13 |
Rep 312
There is this if you want the look on your CiC unit...
http://www.ebay.com/itm/BMW-F20-F30-...dVBM~P&vxp=mtr |
10-23-2015, 12:11 AM | #15 |
Rep 1,201
Why would you want the NBT controller on CIC? The touch function won't work anyway. Why not just stick with the smaller CIC knob and make life simple?
2022 X7 M50i Phytonic Blue
2019 M5 MBB (wife's DD) |
10-25-2015, 01:45 PM | #17 |
Rep 578
the only reason i would want to do this mod is to be able to draw the letters instead of scroll on the wheel. Is there not a scenario with CIC this function would work?
10-31-2015, 06:31 PM | #18 |
Rep 345
Question, did you buy the knob only or the complete controller? If you only bought the knob, can you indicate the part number? Will like to do the swap, the plastic one is a good choice put if the ceramic one can be bought will prefer to go that direction.
Black Sapphire Metallic / Premium Package / Technology Package / Cool Weather Package / Lighting Package / Harmon Kardon surround sound system / Vossen VSF/1 Matte Graphite
11-15-2015, 12:13 PM | #19 |
Rep 12
Hello
The only knob can not be fitted to the standard iDrive (CIC), it is a simple solution to install NBT iDrive to CIC system. Last edited by rustamgtx; 11-15-2015 at 12:21 PM.. |
12-07-2015, 08:43 PM | #20 | |
Rep 345
[QUOTE=simplecomplexity;18780223]
12-14-2015, 03:57 AM | #21 |
Rep 12
[QUOTE=jrortiz;19030087]Check this, it is all clear. But if you have CIC you need adapter to be install.
12-14-2015, 01:49 PM | #22 |
Rep 345
rustamgtx
Thanks. What is the adapter you mention?
