08-30-2014, 04:39 PM | #1 |
Rep 398
[UPDATE 11/17/2016] *SQUEAK* and the 'Teflon' tape deal explained with pictures.
[UPDATE 11/17/2016] This is an update since I had it reapplied last year 08/27/2015. Still no squeak has returned. Confirm this is the best long-term fix in my opinion. It has been almost 15 months since.
[UPDATE] After a year (almost exactly), the passenger side started to squeak again while turning onto uneven driveway, and slow turns and bumps. Driver side was still solid. Went back to the same dealer with my service report from back then. They were very helpful with me and ended up re-applying the teflon tape on both sides. Of course the car feels good again. I don't care if I have to go every year to get this done. This is by far the best method that has been done and it does make the car feel so much different (if you had the same squeak problem). Lasted a year. It is way better than keep having to clean to keep the squeak out for a few weeks or even a few days. So I still strongly recommend the teflon tape method. 08/27/2015 Hello forum!! First of all, I KNOW there are threads already on the infamous squeaks. It has been addressed here and other BMW model forums. Seems like there are alot of us who have this issue and tried Gummi Pflege, wax, no wax, no silicon, yes silicon, don't wash, do wash, etc methods have been gone over. Yes, there is a mention about the Teflon tape here also with service bulletin on it, but it is just a part of a thread that can be missed by people. So here, what I wanted to do was to make a thread on the Teflon tape alone, with what my dealer wrote on the worksheet along with pictures of the work they did on my car. There were some members who wanted actual pictures of the work done. So I decided to take some pictures, try to connect this damn phone on my computer to transfer files. Here we go: Here is what dealer wrote on the worksheet after I picked up my car. I went to dealership three times for this. The first time was a different dealership and they could not find out what the squeak was for at all. At that time, it was before I looked at this forum for it, so I didn't know either the squeak was coming from door seal. I thought it was suspension that was doing it. Second time, I tried a different dealer, and they sorted out the squeak was from door seal. But they didn't apply teflon tape. Here is what they wrote on the worksheet: (**** replaced mechanic's name for privacy) "A client states there is a squeaking type noise heard from the rear of the vehicle - see **** // verified on road test 1 Found noise to be coming from the door seal / cleaned affected area and reinspected - all checks ok after road test ,,,, **** verified rear door seals were causing a creeking noise. Cleaned rear door seals and re-test drove vehicle. No creeking noises were heard after." Ok, so I did not hear the noise when I picked up the car and I was happy. But the following weekend (not even a week), I was driving on some bumpy road around @ 25mph and the noise came back somewhat. It was not as bad, but it did. Then I gave it a car wash and wiped all door seal, etc areas with water, and it did get rid of the noise for short period of time. I almost had to clean the area every few days to do something with the noise that was keep coming back. I wanted to try the dealer one more time. So, the third time at the same dealer, I addressed that the squeak came back. I got the car back after 3 days, and the worksheet this time, I clearly saw they used teflon tape. Here is what the worksheet says: "Client states there is a creaking type noise heard from the door seals while driving over uneven drive ways Cause: Teflon Tape 5116345 Applied teflon tap(e) 238 WC 1 83-19-9-407-798 Film tape: 832518 3799 Door seal making contact with roof, dirt and silicone causing noise. Verified noise coming from door seals. As a reference of SIB 51 28 10. Applied silicone remover to both rain gutters and applied transparent teflon tape. Noise is now gone." When I picked up the car and drove around, I could feel that the car didn't feel the same. I mean, I could somehow feel that the car felt more 'rigid' and felt like this time, the squeak might be really gone at least for a very while. It has been only less than a week so far, the car is dead quiet from squeak, and I do feel difference somehow while going over bumps at slow speed, or going up the drive way (when the car goes up diagonally it used to squeak like crazy, like the car was going to twist). So here it is. Pictures, I tried to resize for you guys. Hopefully everything works here. I drew some lines on the pictures to show you little better of what they have done. The tape is not visible at all once the doors are shut. The ends had little voids, but I tried to smooth it down with my nails. Anyways, hope this helps any of you guys looking to get your car in for service to get this fixed. Good luck to you all **Edit** sept 02, 2014 Here are 2 links which might help those who want to try a little different method if all fails. One is for the material, and the other one is how to apply. How to apply: http://www.540i6.com/doorseals.html Material: http://www.tintprotector.com/strips/index.htm Last edited by aksi; 11-17-2016 at 11:46 AM.. Reason: To update the report |
08-30-2014, 08:18 PM | #2 |
Rep 341
Haha. The irony of this is that I just did this fix myself today. Although I applied felt tape instead Teflon. My car it's barely 2 months old and the issue started 3 days ago and it was disappointing to hear such sound. From the inside of the car it sounded like rattles but it was just muffled squeaks. On my 2014 there is a felt tape already applied on top of the seal on the door. I originally thought that's how bmw fixed the squeaks but apparently not. In my case the felt tape was making the squeak when against the black shadow trim. As with every new car I get the wash the car syndrome so washing the car 2 a week must have dried up the felt. I had someone press on the door from outside while I was inside the car listening and it was the same sound. I used masking tape to outline the end of the door over the black trim and then applied the felt tape and I'm squeaks are gone at least the ones in the back are gone. Ones in a while I will hear a squeak from the front driver door but for now I won't apply any felt tape. I want too see how long the felt tape holds. Btw thanks for the pics I'm sure it will help a lot of other people.
08-30-2014, 08:32 PM | #3 | |
Rep 398
My noise was almost like that squeak you hear when walking on old wood flooring. Mine is also 2014 and i got my car in April this year. So we are pretty close. Good luck on your squeak!! |
08-31-2014, 08:52 AM | #4 |
Rep 3,341
Drives: 2022 M3, 2022 X5 40i;
This was a known issue with the e90s and the gloss black trim
08-31-2014, 10:19 PM | #7 |
Rep 398
09-01-2014, 01:05 AM | #8 |
First Time Bimmer
30
Rep 617
thanks for the note, i had experienced that squeaky annoying noise on bumpy road in normal suburban road in Australia in normal speed (40-70kph), the noise is definitely gone when the road is smooth. Took my car to dealer during the first service, didn't identify anything (which i couldn't get it coz the road to the dealer is not smooth, and i did enjoy the squeaky noise), so will bring up this thread to the dealer and ask to check the tape!
I do have the M sport package with the glossy swirl easily trim...
2013 F31 328i M Sport Touring EBII
Ordered Due August 2017: 2017 Audi A4 AVANT 2.0 TFSI Quattro MY17 S-Line, Exclusive Nogaro Blue |
09-01-2014, 01:32 PM | #9 |
Rep 1,267
Thanks for the pics. I do have the squeak and my fix so far was to apply sealant, but it doesn't last. I was thinking of actually just installing the tape myself. Looking at your pics I feel that I could do a better job than the dealer since it doesn't look straight at all. Hopefully this is not an expensive tape.
09-01-2014, 02:17 PM | #10 |
Rep 766
Keeping the black gloss trim clean and waxed has been enough for me. The squeak is actually your car telling you to wash it
Its a feature not a bug
Well weathered leather, hot metal and oil, the scented country air.
Sunlight on chrome, the blur of the landscape, every nerve aware! 2014 328ix EBII - Sport AT, Light Pkg, Blk Dakota, Moonroof, Navigation, Heated Seats, HK Audio, Driver Assist, Sport Pedals, Dinan Springs, Bilstein B8s, M-Performance BBK |
09-01-2014, 09:52 PM | #12 | |||
Rep 398
This is such a long area that has to be covered, that itself would make it tough to apply right. I thought it was 3m scotch tape they applied because it does look awfully similar by looks lol. Good luck! Quote:
Wow that is expensive! I found a thread somewhere outside of f30 that someone posted a website of where to get this kind of teflon tape. When i get to my pc(i am on my phone right now) i will try to find it and edit my original post and mention on it. |
09-02-2014, 07:36 AM | #13 |
Rep 6,987
Weird that I've not experienced this problem in the 18 months I've owned my 2013 F30...but glad to see someone finally discovered the fix!
09-02-2014, 11:51 AM | #14 | |
Rep 398
Knock on every piece of wood there is around you and hope you do not get it. You do not want to find out about it |
09-04-2014, 10:07 AM | #16 | |
Rep 398
Good to hear it hasnt come back for a month. I used to wipe with just water but it came back too soon lol |
05-13-2015, 07:46 AM | #17 |
***** noob
1368
Rep 10,479
Drives: 325xi>M235i>428GCx Mspor
I had my 4gc for a month and now I hear a squeak everytime over bumps...its around the passenger rear
Is this it??
2006 325xi (Sold)
2014 M235I (Current) 2015 428xi Gran Coupe (STB) |
07-27-2015, 08:51 PM | #18 |
Rep 398
07-28-2015, 09:19 PM | #19 |
Rep 1,366
I wish teflon and scotch tape were the same since scotch tape is $2 a roll and teflon tape is $200.
Teflon tape has industrial uses including using on rollers to create a near frictionless surface. I've seen it as low as $75 a roll but that was a 'smoke' colour. Anyone find a good supplier for this application? I don't know why BMW doesn't do it at the factory. It would be a lot easier to apply a teflon coating on an industrial scale |
07-31-2015, 10:12 AM | #20 |
Rep 294
Got my car back yesterday with this and some "grease" done by the dealer - NO squeaks... Also fixed the steering column rattle and the door lock pin rattle myself last night. My car is now a JOY again!!
07-31-2015, 10:23 AM | #21 | |
Rep 693
And I'm the only one to make the smartass comment? LOL
2018 M240i X-Drive | Sunset Orange Met
2015 328d X-Drive Touring M-Sport (Traded) 2015 Audi S4 Sepang Blue P+ | DSG | Tech Package | Adaptive Suspension | B&O 2015 Audi S3 Misano Red | 19" Sport pack w/Mag Ride | B&O 1983 Porsche 944 All stock |
