Pandora Car Alarm System
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Suspension | Brakes | Chassis
      10-07-2014, 02:42 PM   #1
Sean@PSI
Sean@PSI's Avatar
Drives: 2021 IOMG M3 Sedan
KW Releases F80 M3 / F82 M4 Clubsport Coilover Photos!
BIMMERPOST
     Featured on BIMMERPOST.com
We were thrilled when KW announced their impressive new Clubsport coilover system for the F8x M3/M4, as their suspension products have become known in the enthusiast communities for their world-class quality and performance. Recently KW released the very first photos of the new Clubsports, and we wanted to share them with everyone here.
From the KW press release:
The KW Clubsport coilovers give BMW drivers who want to extract the maximum potential from their new M4 Coupé and M3 sedan on racetracks and on the street. KW Clubsport coilovers have been developed on the Nürburgring Nordschleife and allow separate adjustment of the rebound and compression similar to our Competition racing dampers. KW Variant 3 coilovers also offer a similar level of adjustment too.
With so much adjustment available for the BMW M4 and BMW M3 suspension it allows fine-tuning for additional upgrades such as modified brakes, semi-slick tyres or increased engine power.
With the rebound adjustment on the upper end of the piston rod the V3, Clubsport 2-way and 3-way coilovers can be adjusted with 16 clicks. With less rebound force the comfort will increase, whereas with increased rebound force the handling will improve and the bodywork roll reduced. Due to this, the steering precision will be improved when driving fast.
The damping force in KW V3 and Clubsport 2-way can be adjusted manually with 12 clicks, with KW Clubsport 3-way offering further adjustment.
Compression damping can be adjusted independently in the high and low speed range. High-speed compression adjustment can be varied between 14-steps and low-speed compression can be varied with 6-steps. A harder low-speed adjustment will cause a more direct steering behavior on the front axle and reduce oversteer at the rear axle.
Furthermore, KW Clubsport top mounts improve the grip of sport and semi-slick tyres thanks to adjustable camber providing an optimal seating while driving through corners. No top mounts are available for Variant 3 coilovers, and the damping/spring rate is also different between the two coilovers. For those who want maximum performance on racetracks Clubsport is the ultimate solution. For sporty driving on the roads Variant 3 suits the M4 and M3 perfectly.
Just like Variant 3 coilovers, KW Clubsport have a German TÜV Certificate meaning you can easily drive home with your M4 or M3 after hitting the track in total safety and control – simply change the settings to a more comfortable ride!
A stainless steel threaded strut allows a German TÜV tested lowering range between 15-40mm on the front and rear axles, while KW adjustable lowering springs allow a continuous lowering of 5-25mm.
Enjoy!
      10-07-2014, 03:19 PM   #2
RingMeister01
Croatian
RingMeister01's Avatar
Drives: PORSCHE
This is the @&*# !!
NARDO GREY '18 PANAMERA TURBO
Ducati V4 S Corse (track only)
Husqvarna FS450 (track only)
Looking for an SUV
      10-07-2014, 03:55 PM   #3
rubber_ducky
rubber_ducky's Avatar
386
Drives: roach coach
That's some good-looking hardware.
      10-08-2014, 12:12 AM   #4
///M ARMY
Drives: F90
2022 RAM TRX
2021 Ford Bronco
2022 BMW M3
      10-08-2014, 01:02 AM   #5
MischiMischi
MischiMischi's Avatar
Drives: M4 F82 Performance
This is really great - and I am lucky that I have it already installed!
The setup and the performance of the CS in the M4 is really impressive until now. The car feels amazing - I am looking forward to be on the track for the first time with my M4
      10-08-2014, 06:45 AM   #6
/// M sa
/// M sa's Avatar
240
Drives: F80 MG
How does it affect the adaptive suspension?
      10-08-2014, 07:16 AM   #7
MischiMischi
I have ordered the car without, as I wanted to change to the KW.
But if you have adaptive, you need a deleter kit for the edc.
      10-08-2014, 12:55 PM   #8
Sean@PSI
Sean@PSI's Avatar
Correct, EDC cars need the delete to get rid of EDC errors.
      10-09-2014, 07:43 PM   #9
tooch
Drives: F82
When are they due out? I want and need them!!!!
96 E31 JB
07 E92 AW
F82 BSM
      10-10-2014, 08:21 AM   #10
Sean@PSI
Sean@PSI's Avatar
Systems are shipping mid to late October.
      10-10-2014, 08:41 AM   #11
(H)
(H)'s Avatar
Drives: F80 M3 (after F10 M5 ;-)
Would love to test them in comparison to stock adaptive suspension. Can you elaborate on the handling difference in comparison to sport+ mode?
IG: hartmutkraft
FB: seventeenjewels
      10-10-2014, 09:12 AM   #12
StealYourFace
Drives: F30 328i M 6mt, E36 M3
A part I would love to order for a car I wish I had Love the minimal lowering.
      10-10-2014, 09:33 AM   #13
RingMeister01
Croatian
Drives: PORSCHE
Adaptive suspension and Clubsports are not comparable. They exceed the handling characteristics of the stock spec by far on track but are not as compliant to street conditions as the stock suspension is designed for.
Looking for an SUV
      10-10-2014, 10:34 AM   #14
kevinlevrone
Drives: 335i
You can install the KW DDC, when they are released. These replace the EDC but still remain electronically controlled.
      10-10-2014, 11:21 AM   #15
CSanto
Drives: 2015 BSM/SO M3
I'm going to need a ride once you get these installed.
      10-10-2014, 11:34 AM   #16
RingMeister01
Croatian
Drives: PORSCHE
This is going to be an awesome Spring season bro
Looking for an SUV
      10-10-2014, 11:41 AM   #17
M4isKing
Drives: no torque
yum
      10-10-2014, 12:58 PM   #18
dtea604
dtea604's Avatar
Drives: 06 E90 325i
Love kw products
      10-10-2014, 01:03 PM   #19
Diver
Diver's Avatar
Drives: Black '12 135i - Sold
Looks like a nice upgrade.
      10-10-2014, 04:50 PM   #20
bradleyland
TIM YOYO
Drives: 2013 M3
The adaptive suspension will continue to work fine... in a box... in your garage
Seriously though, this is a complete spring and damper replacement kit. You're literally taking the factory adaptive suspension off when you install this, so in terms of "affect", it completely eliminates it.
Most people who want to go the aftermarket suspension route don't equip the car with adaptive suspension to begin with. If you do equip your car with adaptive suspension, you have to either buy an aftermarket suspension that supports it, or abandon adaptive altogether.
His: 2019 R1250GS - Black
Hers: 2013 X3 28i - N20 Mineral Silver / Sand Beige / Premium, Tech
Past: 2013 ///M3 - Interlagos Blue Black M-DCT
Past: 2010 135i - TiAg Coral Red 6MT ///M-Sport
      10-11-2014, 12:13 AM   #21
cartaa100
cartaa100's Avatar
Australia
36
Drives: 335i, 640i, X6M50d, X3M40i
That M4 is where its at!
      10-11-2014, 04:24 AM   #22
hwelvaar
Belgium
112
Drives: BMW M135i MT
I think the text should read "German TUV approval" instead of "German TV approval" ;-)
bmw, coilover, kw suspension, precision sport, psi
f80post
