BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > F30/F20 TPMS Retrofit
European Auto Source
      03-19-2015, 02:05 AM   #1
Coolala
Japan
19
Drives: 2013 F30
Hi,
Is there anyone retrofitted TPMS (RDC) with successful story and don't mind to share? I can't find something about this retrofit in this group.
Any help gratefully appreciated!
      03-19-2015, 09:41 PM   #2
lukash
Drives: 2014 F30
I'm no expert but was just looking it up for my car too and found this:
http://www.bimmerretrofit.com/store/...product_id=110
and a story here: http://www.bmw-sg.com/forums/elebest...trofitted.html
-Lukas
      03-20-2015, 01:58 AM   #3
Coolala
Japan
19
Drives: 2013 F30
-Lukas
Looks good but actually I'm looking for DIY information/story instead of finding a shop to retrofit this for me.
Thanks!
      04-24-2016, 04:25 AM   #4
gribouille1210
Drives: BMW F32 430D M performance
Hello everyone,
i have tried to retrofit the TPMS on my car bmw F32, production 11/13 (i have RPA).
I have bought:
4 sensors for wheel ref number: 6855539 and install it.
1 control module TPMS 6855180
i have created and installed harness like this
pin 1 to pin 51 A173*8B
pin 2 to Fusible F147 ( I don't have F132)
pin 3 to pin 52 A173*8B
pin 4 to ground
I have installed TPMS and i have seen ECU RDC with Esys.
I have VO coded 2VB and coded ICM, KOMBI, HU NBT, DSC.
i drive with my car, tpms says that TPMS resets and afterthat on NBT, it says that tpms is not working.
I think i have to reset the 4 sensors with rheingold but i don't know how to do.
Do you have any idea?
      05-05-2016, 06:06 AM   #5
gribouille1210
up
      05-06-2016, 12:01 PM   #6
atzebmw
Drives: BMW 335XD F30 LCI
So, now that my account is unlocked, I can help you finally.
I retrofitted the tpms on my F30 from 02/2014 successfully.
I tried many things.
But on the end only one combination worked.
I installed the control unit 6876227 together with the sensors 6856227.
The connection of the cables and the codings are the same for me.
In my attempts I also tried the sensors 6855539, but it also didn't work.
These sensors are for cars after 03/2014.
I hope this is helpful.
      05-06-2016, 05:22 PM   #7
gribouille1210
Thanks you So much.
Do you go to BMW for activate the 4 sensors ? Or it activates alone when we drive or we make a reset on idrive?
      05-06-2016, 10:10 PM   #8
atzebmw
It activates alone after a little drive.
You only have to reset the tpms in the iDrive.
      05-07-2016, 03:16 AM   #9
gribouille1210
About the control unit i have bought:
Do you think i have to buy a new one like yours ?
Best regards
      05-07-2016, 01:42 PM   #10
atzebmw
Best regards
I think there are now 2 possibilities.
You can buy 4 new sensors 6856227 and a new control unit 6876227.
This worked for me and i think it also should work for you.
Or you further use the control unit 6855180 and buy new sensors 6798872.
These sensors should work together with your control unit like i just saw in the parts catalog.
But i didn't test this combination.
6855180 + 6798872 are for us-cars, which can cause new problems , but it must not .
      05-07-2016, 04:04 PM   #11
gribouille1210
thank you so much.
I will buy buy 4 new sensors 6856227 and a new control unit 6876227.
I keep you in touch.
Best regards
      05-11-2016, 01:53 PM   #12
BMW3291
BMW3291's Avatar
Thailand
Drives: F30 Active Hybrid 3
Can you explain about wiring and where do you set up the control unit?
Do I need to coding?
I want to try this retrofit on my car F30. It has FTM, production 04/13.
Best regards.
      05-11-2016, 04:44 PM   #13
atzebmw
Best regards.
The wiring has been already described above. But here again the diagram.
The 2 cables orange/green and green must be pinned in FEM pin 51 and 52.
If you have a trailer coupling, then you can go the short away and wear the cables off in the trunk behind on the right.
The TPMS control unit is attached on the bottom of the tank by the holder 36206852245.
After the installation the coding is needed.
      05-23-2016, 04:03 AM   #14
larry_bml
larry_bml's Avatar
Romania
31
Drives: BMW F30 Sport Line 320ded
thank you so much.
Best regards
Did you bought the sensors and control unit? As I see from realoem.com this control unit is for F10/F07 etc but not for F30 series.
I want to make this retrofit too , to my 04.2012 F30, and I want to be sure it was working for your F32.
Thank you.
      05-23-2016, 04:36 PM   #15
gribouille1210
Hello i have received control unit and installed it correctly.
But i don't have received the 4 sensors.
When i receive it, and install it, i keep you in touch.
Best regards
      05-24-2016, 12:35 AM   #16
larry_bml
larry_bml's Avatar
Romania
31
Thank you. Please let me knou your part numbers for sensors and control unit too.
      06-05-2016, 05:34 PM   #17
gribouille1210
Hello,
tpms is working on my F32 production 11/13.
I have bought control unit: 6876227
And 4 new sensors 6798872.
Thanks to atzebmw who helps me A lot.
Like he says the sensors 6856227 are also ok with control unit 6876227.
Best regards
      06-08-2016, 01:08 PM   #18
BMW3291
BMW3291's Avatar
Thailand
Hello everyone,
I have bought:
pin 4 to ground
A173 is FEM, right? From pic, what number is A173*8B?
Can you explain code and parameter in ICM, KOMBI, HU_NBT and DSC?
Best regards.
      06-08-2016, 01:32 PM   #19
atzebmw
Best regards.
On your pic it is Nr. 9.
For coding you can VO code "2VB" in FEM, ICM, HU_NBT, Kombi and DSC.
Or here the manually codings:
FEM
RC_RDC_ENABLE = aktiv
ICMQL
IcmKod_B_S2VBA = verbaut
DSC
C_Funktion_RDCi_l = nicht_aktiv
C_Funktion_RPA_e = nicht_aktiv
C_RPA_Extra = nicht_aktiv
HU_NBT
RDC = aktiv
RDC_DRUCK_TEMP = aktiv
RDC_FORTSCHRITTSANZEIGE = nicht_aktiv
REIFENUEBERWACHUNG_RDC_RPA = rdc
RPA = nicht_aktiv
KOMBI
ST_TYR_RDC_ALIVE = aktiv
ST_TYR_RDC_TIMEOUT = aktiv
KOMBI DSC_MIT_RPA = ohne_RPA
      08-21-2016, 04:44 AM   #20
Lancelot
France
167
Drives: 2014 M Sport ActiveHybrid3
Hi, could one of you help me with the wire routing?
How do you route the cables from the front FEM to under the chassis? at which point does it go from inside to outside the cabin?
Where do you take the 12V and ground?
Thanks!
2014 M Sport ActiveHybrid 3
M Performance BBK - F80 CFRP struts brace - Quaife LSD - KW DDC coilovers - Akrapovic Exhaust - HJS EU6 downpipe - Wagner Evo2 Comp IC - BMC air filter - Powerflex Black Subframe Bushings - Bimmertech amp with Focal speakers
      08-21-2016, 05:43 AM   #21
atzebmw
Thanks!
12V comes from Z2*1B Fuse holder rear and Fuse 132.
Ground you can take everywhere. I connected ground on the left side of the trunk. There is a ground connection point.
All 4 cables i wired directly under the fuse holder rear to outside the cabin.
There is a hole covered with a black plastic cap under the fuse holder.
      08-21-2016, 07:46 AM   #22
Lancelot
France
167
Thanks!
And now, can you help me with how to actually connect wires to the FEM?
I unplugged the connector to A173*8B here, but how do I get to actually connect to PIN 51/52?
How do I safely open this big connector without breaking it?
