BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Those with 285 rear tires, come in!
      03-27-2015, 02:59 PM   #1
Titan 3
Titan 3's Avatar
101
Drives: E46 325ci ~ F36 428ix
I just ordered a set of VMB7's with a 245/35 - 285/30 stagger. The ream offsets are an et45. Is anyone having rubbing issues with this wide of a rear tire? I'll be running H&R sports temporarily, but plan to slightly tuck the tires once coilovers hit the market for the Gran Coupe Xdrive.
Thanks in advance for the insight!
Mike
      03-27-2015, 11:40 PM   #2
willpower
willpower's Avatar
26
Drives: f80 m3 zcp
I have VMB5 with hankook evo with that setup.
You'll be fine. I really like the fat tire look too.
I'm on KWV2, it just barely clears. I've been on it and city streets for about 5 months.
      03-28-2015, 12:15 AM   #3
betlion
Drives: bmw
depending on the tire brand
285 might rub, too tall
      03-28-2015, 03:36 AM   #4
metrickid
Dinosaur supervisor
metrickid's Avatar
Netherlands
3030
Drives: E91 318d
Without knowing the wheel width and size (19/20) your ET and tire width means nothing.
      03-29-2015, 03:23 PM   #5
willpower
willpower's Avatar
26
Drives: f80 m3 zcp
My 10.5 +45 285 VMB5 just barely fits. I'm pretty low, but not slammed.
      03-30-2015, 11:21 PM   #6
TurboM
TurboM's Avatar
Drives: 2018 F82 M4 ZCP
Front - 19X8.5 +40ET & 245/40/19
Rear - 19X9.5 +45ET & 285/35/19
Slightly lowered on Eibach sport springs (~.75" front & 1" rear). No rubbing issues on the rear, although it is VERY close. I have 5mm spacers in the front which pretty much makes for a +35ET in the front and it rubs the inside of the wheel well the tiniest bit only if I turn the wheel all the way one way or the other.
You may need a 5 or 10mm spacer in the front but you didnt specify the width of your wheels which can obviously make a difference.
      03-31-2015, 01:54 AM   #7
Titan 3
Titan 3's Avatar
101
Thanks for the insight. 20x9 245/35/20 et35 on the front, and 20x10.5 285/30/20 et 45 in the rear. The car is an F36.
      03-31-2015, 09:33 AM   #8
Hernandiaz11
Drives: 2014 435i M-Sport 6-Speed
If I had to guess I would say they will probably rub. all 4 tires are about 3/4" taller than stock. With those wheels you should have:
Front: 245/30 R20
Rear: 285/25 R20
I'm not saying the above sizes won't rub, but you definitely have a better chance.
      03-31-2015, 10:44 AM   #9
kyleb350
kyleb350's Avatar
Drives: '21 X3MC
Since you have xDrive, OP, be sure your tire diameters between your fronts and rears don't have >3% difference (I think it was).
      03-31-2015, 11:57 AM   #10
Jimminez
Jimminez's Avatar
Drives: 2014 F31 M-Sport
The difference between the front and rears should be <1% (for awd vehicles) while you're largest diameter should be <3% from stock.
Martin
Past - F31 M Sport Estoril Blue - Thread - Pic
Current - 2021 Audi RS6 Avant
      03-31-2015, 01:57 PM   #11
JarleM3turbo
Drives: 328i Xdrive Touring
Im running 245/30/20 and 285/25/20
Wheels are 9x20 ET 35 and 11x20 ET 48. No rubbing.
Lowered with H&R springs.
      03-31-2015, 02:10 PM   #12
Polo08816
Drives: 2014 335i M Sport
Mike
Does the car even have enough power/torque to make 285's necessary?
      03-31-2015, 02:26 PM   #13
kyleb350
kyleb350's Avatar
Drives: '21 X3MC
No, not really, especially with xDrive. And with 285's, your wheel and tire combo is most likely going to be heavier than stock (unless you spend the big bucks).
I'm guessing he's just going for looks.
      03-31-2015, 02:33 PM   #14
Titan 3
Titan 3's Avatar
101
Yeah, just enjoy the look of an aggressive stagger. The 245/285 combination in Bridgestone RE760's are identical in diameter, and if I drop to a 275 it's well within the 1% range. The 760's are notoriously small tires, so a 275 on a 10.5" seems like it would look a bit stretched.
I really don't want to deal with rubbing though... I'm getting too old to explain it to passengers. lol
      03-31-2015, 02:53 PM   #15
Jimminez
Jimminez's Avatar
And notoriously heavy. I had a set a few years ago and when I switched to PS2, it made a difference and feel in handling with a difference of 4 lb per tire.
RE760 weigh in at 29 and 31 lb, while tires like the Hankook or Pirelli are 25 and 27 lb (26 for Pirelli).
In the grand scheme of things, it's not huge, but I figure I'd point out the difference if you still had a choice, especially since now that heavier weight is pushed out even further up-sizing to a larger wheel diameter.
Martin
      03-31-2015, 03:11 PM   #16
Titan 3
Titan 3's Avatar
101
Totally just panicked and went down to a 275. I had the 760's on my E92 and really enjoyed the look and drive of the tire. I'm not too concerned with the extra weight... This car is just getting me to work and back. I'm putting a tune on it to get a little more power out of it, but not expecting much.
Thanks for the input, everyone!
-Mike
      03-31-2015, 03:22 PM   #17
bobbydigital
Drives: 2015 BWM 435GC
Make sure you post photos once they are mounted!
      03-31-2015, 04:09 PM   #18
Dippydo
Drives: 2023 M8 Comp
2012 BMW  [1.00]
275 is not a stretch really. Slight roll, but by no means a stretch.
      03-31-2015, 04:13 PM   #19
Titan 3
Titan 3's Avatar
101
Pics coming soon!
Thanks for the insight on the 275's... I'm betting it's the better answer.
      04-06-2015, 09:51 AM   #20
Titan 3
Titan 3's Avatar
101
Pics coming soon!
The wheels are shipping today from Cali! Stay tuned for pics in the next few days.
      04-06-2015, 10:26 AM   #21
obriennathaniel
@obriennathaniel_f30 on Instagram
obriennathaniel's Avatar
Drives: 582whp/596wtq '13 335i
I lose traction with my 285's, I wish I could go bigger. But I'm also FBO
CG Precision VS-1 Exhaust\DR-1 DownPipe | PS2 Turbo\Inlet | PDU PI w/Fuel-it platinum kit & E sensor | GFB DV+ Diverter Valve | BM3 w/AIC2-V|Tune CaryTheLabelGuy | Full E85 | ATM FMIC | ER Chargepipe Inlet/Outlet | AFE Intake | BC Coilovers | PSS 255/40-275/35 Velos Designwerks S3 two piece 19x9/19x10 | Osram Xenarc | LED retro | AWRON digital AC gauge|
