BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > Disconnecting TMAP Sensor
      06-19-2015, 08:00 PM   #1
Espi2
Drives: 2014 328i M Sport
Hey everyone,
This is a dumb question, but is there a trick to disconnecting the TMAP on the N20/26? Trying to install the AFE scorcher but don't want to break the sensor - I have some bad luck with simple installs (a story for another day). The MAP is easy to see how to get it out, but the TMAP doesn't have the same fastener. Any help is appreciated.
      06-21-2015, 12:52 AM   #2
rfcoolz
Drives: 2014 F30 328i xDrive
Originally Posted by Espi2 View Post
Hey everyone,
Removing the TMAP is fairly easy. Just press the small tab with your thumb, and use screwdriver to lightly push the other end (closer to the number). If you can send me a picture of your TMAP I can help put some drawing on it for a better understanding of how to use the screwdriver to help. That's not a dumb question, I had this problem too for BMS, but once u get it, it only take less than 5 sec to unplug.
      06-21-2015, 09:00 AM   #3
Espi2
Thanks! I'll send a pic in a few minutes. Would like to get this installed today, happy fathers day to me lol.
      06-21-2015, 09:40 AM   #4
Espi2
Any idea how to post a pic?
      06-21-2015, 10:04 PM   #5
rfcoolz
Just hold your the tab with your thumb right there and then lightly lift the other side with screwdriver like in the picture
      06-22-2015, 07:11 AM   #6
Espi2
Wow, that's awesome. Thanks!
      06-22-2015, 09:02 AM   #7
Dippydo
Drives: 2023 M8 Comp
2012 BMW  [1.00]
Also helps to press the connectors together then try to pull apart. This helps release the pressure if the locking part of the tabs are touching.
      06-22-2015, 07:43 PM   #8
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
2023 BMW G80 M3  [0.00]
2020 BMW X4MC  [0.00]
16' BMW X4 M40i  [10.00]
06 Cadillac STS  [0.00]
+1
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce
IG: @bmwF9XG80
      06-22-2015, 08:57 PM   #9
mdavis12
El Presidente
mdavis12's Avatar
Drives: 328i xdrive
This will come in handy. glad the OP asked. I have been looking at the install steps for a BMS stage 1.
      06-23-2015, 10:42 AM   #10
rfcoolz
I hope it helped you out.
      06-23-2015, 07:09 PM   #11
Espi2
I thought it would, but it's a different sensor. It's the one on the charge pipe. It won't budge.
      06-25-2015, 03:13 PM   #12
rfcoolz
I see that your car is 2014, and I believe that there is a small cover that requires T10/20 screw (I forgot which one exactly) to be removed in order to access the sensor. If it looks different, then you got the wrong one because I also did the same mistake as you before.
      06-25-2015, 03:14 PM   #13
rfcoolz
try to check this thread: http://f30.bimmerpost.com/forums/sho...30&postcount=1
Look at the very first picture.
      06-25-2015, 03:39 PM   #14
Espi2
Yea, I removed the cover to access, but I can't get the screw driver to lift the sensor - well I's sure I can but I don't want to break the connector. I'll keep trying, I'm definitely attacking the right one - thanks for the help.
      06-26-2015, 12:51 AM   #15
rfcoolz
Sorry for the always-late reply, but it should not be that hard. You will hear a very small "click" when you pull with your screwdriver and hold the tab the right way.
      06-26-2015, 07:57 AM   #16
Espi2
What do you mean by pull with the screwdriver. I've been trying lift the part where I put the screw driver. Is that right ?
      06-26-2015, 12:24 PM   #17
rfcoolz
You should do both pressing the small tab (the one I circled red) and help with the screwdriver from the other end at the same time.
      06-26-2015, 12:35 PM   #18
Espi2
Yep, that is what I have been doing. Are you just lifting up with the screw driver or pushing forward?
      06-26-2015, 01:29 PM   #19
rfcoolz
I can't really describe it since I did it by feeling. lol. It's just impossible to do it without screwdriver
      06-26-2015, 01:35 PM   #20
rfcoolz
I think the point is to make the head unstuck. Since its in there for many months exposed to dirt and stuff, it would stick like a glue and need some help to detach them.
      06-26-2015, 05:56 PM   #21
mdavis12
El Presidente
mdavis12's Avatar
Drives: 328i xdrive
just to for kicks, i tried removing both map and tmap connections. and it was exactly as described, took a couple minutes.
There is a tab in the middle of the connector towards the wires. push this down and hold it down, then using a screwdriver, catch the opposite edge of the connector and push forward with the screwdriver, while at the same time pull the connector with the tab still pushed down away simultaneously. If you feel it is going anywhere. stop for a second, push the small down enough to where you see it move, and gently push with the screwdriver till you a hear a click.
      07-02-2015, 07:44 AM   #22
Espi2
Finally got some time and installed the aFe scorcher. TMAP was a pain but got it off. This was worth the wait, very nice gain. Feels much quicker and more responsive.
