BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Bimmer-Tech F30 Match PP 82DSP Amp/DSP Upgrade
Extreme Power House
      06-25-2015, 09:39 PM   #1
CntryClub007
Drives: 2015 320i | 2013 X5-35i
Quick review of the Bimmer-Tech Amp Upgrade for the F30.
Overall Impressions - Incredibly Happy with the Quality. Incredibly happy with the mounting bracket & installation system. Exactly what I was looking for to give my vehicle the next level in sound quality, without ripping apart every door panel and doing an 8 hour installation. Everything just sounds better. Treble, Bass, Mids.
I have a SA-676A - Hi-Fi 2015 320i, I found myself blasting the speakers to hear a phone call, radio, anything really. With the new hardware, I'm listening at 15-25% volume level. All tones are great. Absolutely worth it if you are SA-676A 320/328/335. You can check this with a BMW VIN online tool.
Install time (30 minutes) total.
DIY Instructions
Tools: Ratchet, 8mm socket, 10mm sock, T-40, large flat head screw driver, and trim/clip remove tool (I purchased on Amazon)
Step 1: Remove the 4 panels in the trunk.
Step 2: Remove quarter panel cover. 4 clips and T40 bolt (bolt is covered by a small plastic trim piece of the anchor)
Step 3: Remove the amp retainer. 1-10mm nut
Step 4: Remove the amp bracket. 1-10mm nut and slide the bracket towards the front of the car
Step 5: Remove amp. 1-8mm bolt and wedge it out with a flathead (as shown)
Install everything back in reverse. Secure loose cables with 1 zip tie. Plug the 14-ft USB in first, it's not easy to access once the amp retainer is installed.
The DSP is ready to go out of the box. You can connect a USB cable and optimize settings further through the Match software (for example if you have aftermarket speakers), but I didn't find that necessary.
This is a great upgrade if you want all aspects of audio to be improved on the car. I would purchase this over the BavSound Stage 1, as well as over a JBL MS-8 or JL 6-Channel (Since the F30 has 7 channels).
Installation Video & Pictures:
Video - Installed:
DSP:
Bimmer-Tech Mounting Bracket (Base of DSP):
Mounting Bracket Installed - OEM Amp:
Mounting Bracket Removal - OEM Amp:
Mounting Bracket Removed - OEM Amp:
Mounting Bracket Installed - DSP:
DSP Installed:
      06-27-2015, 09:03 PM   #2
paul223
Drives: f10
How does the underseat subs sound? Does it get enough power from this amp?
      06-28-2015, 05:59 AM   #3
Technic
Technic's Avatar
Drives: 2015 320i
The PP82DSP outputs a little more than 3-times the OEM power output to the OEM woofers.
Or enough to wake them up without long term durability issues if not abused.
      06-28-2015, 07:02 AM   #4
Osmansky
Drives: BMW 316i
So to make sure I understand correctly, How is it connected to the NBT?
DIY Instructions
Video - Installed:
DSP:
DSP Installed:
      06-28-2015, 07:24 AM   #5
Technic
Technic's Avatar
Drives: 2015 320i
This is a HiFi system... PP82DSP replaces the OEM amp in the trunk.
The last photo shows it plugged into the OEM amp harness in the car.
      07-08-2015, 06:38 AM   #6
Patrys@BimmerTech
Patrys@BimmerTech's Avatar
Poland
277
Drives: 2007 E92 335i
CntryClub007 - Thank you for the great review!
      07-13-2015, 07:41 AM   #7
Fantom2k83
Drives: F30 328ix HIFI
Hi you still have this item? I have this item too but I clear all settings and cant tune it for, can you send me settings on my mail? please. Sorry for my bad English
Fantom2k83@mail.ru
      07-15-2015, 11:38 PM   #8
jojo7
Drives: F320i
Hello CntryClub007,
I did the installation by foolowing your instructions. However, I am having trouble putting back the (amp retainer) Step 3: Remove the amp retainer. 1-10mm nut. Is it something I do not have to install after replacing the amp? If it's needed after the installation is it possible to take a picture of yours with the amp retainer attached so I know how to position it correctly. Thanks much!
      07-16-2015, 10:03 PM   #9
CntryClub007
Originally Posted by jojo7
Hello CntryClub007,
Are you referring to the retainer as the black cover? If so, that doesn't need to be replaced.
      07-16-2015, 11:44 PM   #10
jojo7
Drives: F320i
Yes. I am referring to the black plastic cover. So it's something I can chose not to install? I installed it but then I am having a hard time inserting the other black plastic with the groves in that spot. Thank you!
      05-27-2017, 03:49 PM   #11
antah
Czech_Republic
Drives: F31 330xd
Hi, guys, thanks for manual!
Do you have an idea how channels are distributed within this amp in Hi-Fi configuration?
2 channels - front doors
2 channels - underseat subs
2 channels - back doors (I believe I can split it for mid-high freq as well if I get HK door panel)
1 channel - central speaker.
So, main question - are OEM features will remain the same including simple BASS/TREBLE settings?
I hate there is no app for Mac OS ;( but i saw there are pre-made settings by a lot of users around here. Can I at least upload it with mac? or no way? I have no idea where can I get PC laptop...
Honda Accord -> Subaru STi -> E93 -> F30 + F15 -> F30 -> F31 LCI + waiting for G31
      05-27-2017, 08:57 PM   #12
Arthurrs
Drives: 2014 328i xdrive
I used Parallels Desktop running Windows 7 to upload the configuration file into mine. Do a search in the forum here, you'll find some really good tunings for the factory speakers that are a noticeable improvement from the factory amp. You still have the tone controls available in car's settings, but frankly I find leaving them "flat" is about right for the kind of music I listen to.
2014 328i xdrive Luxury Line
      06-21-2017, 02:09 PM   #13
AG17
Drives: 2014 328xi Black Sportline
Hey Guys,
Read through many many pages and have decided the bimmertech amp will be the best way to go to upgrade the weak sound/bass in the HiFi system. I have concerns about the ASD. Will it be way too loud with the new amp install? Do I need to buy the deactivation wire from bimmertech in order to code the asd off or is there another way?
Thanks for your help!!
      06-21-2017, 09:59 PM   #14
ronanz
Gettin It Figured Out
ronanz's Avatar
Drives: '14 435i FBO ACF S2
Originally Posted by AG17 View Post
Hey Guys,
Either use ESYS or THIS (if you have a iPhone) to code ASD off...
My Build Thread can be found HERE
      06-22-2017, 12:21 AM   #15
dvdowens
Drives: 2015 435xi M-Sport
Selling my Bimmer-Tech F30 Match PP 82DSP Amp if anybody is looking.
      06-22-2017, 02:27 AM   #16
antah
Czech_Republic
Drives: F31 330xd
I just placed an order with Bimmer-tech yesterday, damn!
      12-04-2017, 02:44 AM   #17
eruiz
Drives: 2015 320i Sport Alpine White
Hi
I purchased and installed a PP86DSP a couple of weeks back, I found myself frustrated.
The quality did improved, better sound definitely, clearer vocals and punchier bass, but a little over the midline volume, the tweeters started to crack, I had to bring the volume down again. I was thinking, maybe this is too much for the stock speakers, then I bought the focal IFBMW-S for the front, expecting to get along with the amp, They didnít. Tweeters still cracking, I have tried the preset the company send and many others, I canít turn the volume near 3/4 because there is this horrible distortion. When you spend the money the amp and speaker costs, is not to keep the volume down.
      12-04-2017, 08:02 AM   #18
Maciej@BimmerTech
Maciej@BimmerTech's Avatar
Drives: Subaru
Hi,
I don't know if you purchased the amp from us or not but regardless here is a procedure for fixing almost all odd problems with A PP82 or PP86.
Hard reset
To do a hardware reset push the control button on the amplifier for at least for 5 seconds until the status LED keeps flashing red when no computer is connected to the amplifier.
Loading a tuning file to PP82
To load or modify a tuning file with the .afpx extension launch the 3.40a version of the DSP PC-Tool on a computer connected to the amp via the supplied USB cable
https://www.audiotec-fischer.de/down...TOOL_3-40a.exe
Before the amp launches you may need to go to control panel in windows, then to device manager and update the USB device manually - as shown in the below video. Once the drivers are updated (some times it is necessary to update them twice in a row until the question mark vanishes) you should be able to start the DSPtool. The connection process prompts for an update. Confirm the update and load the tuning file (.afpx file attached). Once you have loaded the file to the amplifier make sure to save it with the save and store button.
Detailed information about the file loading process can be found on our website in the support tab under the DSP Special Vol.2 button:
https://www.bimmer-tech.net/audio-amplifier-for-bmw/
Loading a tuning file to the PP86
To load or modify a tuning file with the .afpx extension launch the latest version of the DSP PC-Tool on a computer connected to the amp via the supplied USB cable
https://www.audiotec-fischer.de/down...TOOL_4-20b.exe
Hardware issues with these amps are practically nonexistent, so a hard reset usually solves any odd issues. As long as the tune that is loaded after the reset is appropriate distortion really shouldn't happen.
One more thing about the PP86
There is an "Input Sensitivity" Knob on the PP86 amplifier. This Input Sensitivity knob needs to be turned all the way to the right hand side in BMW's - or else the input will most likely be clipped causing all sorts of distortion.
