BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > F15 10.2" Monitor installed to F30 car
      10-18-2015, 05:36 PM   #45
pbjr
Drives: 435i M-Sport MT
Just want to start off and say thanks to the OP and others. I picked one up off eBay and it seems to be working. I like it. Now how to figure out a way to make it fit without cutting up my dash. I'm using zip ties to temporarily hold it.
      10-18-2015, 05:38 PM   #46
pbjr
More pics
SirMoo3.00
      10-18-2015, 09:26 PM   #47
F30JetsFan
Drives: 2012 F30 328i Sportline
Some things are better left alone.
      10-18-2015, 09:38 PM   #48
PabloK
PabloK's Avatar
Drives: F30
Sweet comment bro!
Screen looks great. Any issues with nav or systems settings on the new screen?
Can you take a picture with your trim re-installed so we can get a better idea of the increased size?
2014 F30 335i / 2014 F31 328d / 2014 F22 m235i
2019 G05 5.0 / 2012 E70 X5 50i / 2007 X5 3.0is
2011 e93 M3 / 2009 E60 M5 / 2004 E46 M3
2017 Alpina B6
22 Ram Trx / 22 M5 CS
      10-19-2015, 01:48 AM   #49
BMW3291
BMW3291's Avatar
Thailand
Drives: F30 Active Hybrid 3
Look great.
I see in coding list the 10.25" screen has 2 resolutions, 1280x480 (same as 8.8") and 1600x600
If the resolution is higher than 8.8", you need to code it.
HU_NBT 3000 DISPLAY_SIZE_RESOLUTION
      10-20-2015, 09:44 PM   #50
PabloK
PabloK's Avatar
Drives: F30
Originally Posted by PabloK View Post
can you take a picture with your trim re-installed so we can get a better idea of the increased size?
Any update on your screen? is it working ok still? any idea on how your going to measure and cut the dash for proper fitment?
Thanks!
2017 Alpina B6
      10-20-2015, 09:50 PM   #51
kenhoteh
kenhoteh's Avatar
Macau
70
Drives: F30 M-Sport 320i
Originally Posted by pbjr
More pics
[IMG][/IMG]
Look this photo for your reference to done your project.
KenHo Macao S.A.R.
      10-21-2015, 07:29 AM   #52
cedchung
Mauritius
64
Drives: 2011 F25, 2014 F30
Originally Posted by MSportTune2 View Post
Yes, mine is modified by ELEBEST and reversible. I went this route so I can demod when it is time to sell the car. Loved the big screen.
can you post pictures please?
      10-21-2015, 08:37 AM   #53
DFozzy
DFozzy's Avatar
Drives: 2015 M3 (MG/SS)
2015 BMW M3  [0.00]
2015 Acura MDX  [0.00]
This looks really intriguing... I had a 7-series as a loaner for a day a while back, and I agree the larger/higher resolution screen is really nice.
What about using a spacer on the bottom instead of cutting into the dash?
      10-21-2015, 01:18 PM   #54
smilo
smilo's Avatar
France
44
Drives: BMW F26 Sport M-Pack
I think best solution to fit it on the dashboard is to 3D print a module to put between the new screen and 8.8" old screen place. Cutting the OEM dashboard could be a negative thing in the long term...
      10-21-2015, 02:05 PM   #55
Dimitris76
Drives: Estoril Blue F34 328dX M-sport
I would use black Sugru ( google it up!) to mould a pedestal that perfectly fills the gap between the dash and the base of the new screen. You can then glue it all together or drill it and use blind nuts to mount the screen.
/Dimitrios
FastFrog143.50
      10-24-2015, 12:07 AM   #56
pbjr
Thanks for the comments. I do think height is the way to go to avoid cutting the dash. I did pick up some sugru to play with. I also coded it to the higher display. So far no issues everything works like on the 8.8" screen. Noticeable screen improvements are with the cameras. I like that the most. Albums art looks better. The rest is the same. Overall I like how it completes the dash by filling the remaining space that was left by 8.8". I would only recommend this mod if you can score one on eBay for 250 or less. I'll try to post some new pics tomorrow or Sunday.
      10-24-2015, 05:20 PM   #57
mbfanos
Drives: 330i G20
Can you post some photos when you finish this project?
      10-26-2015, 08:07 PM   #58
smilo
smilo's Avatar
France
44
An other F30 with 10.25 CID
I haven't installed it yet, but I think just modifying screen could fit it on the dashboard
      10-27-2015, 12:45 PM   #59
d1985
Drives: F31 330d
Please keep us posted on this one
      12-12-2015, 11:17 AM   #60
PabloK
PabloK's Avatar
Drives: F30
any updates?
2017 Alpina B6
      01-16-2016, 03:32 PM   #61
Alex@Alpine
Drives: E90 M3
I managed to get the screen in without touching the dash. A lot of crazy work, you'll need to carefully remove the plastic casing, then take the screen and lens apart, have a glass cutter trim the glass a little. Shave edges on the metal, and shave some plastic front & rear.
      01-16-2016, 10:15 PM   #62
MSportTune2
Aland Islands
80
Drives: F30 MSport
I had my screen installed by Elebest here few months ago. The plastic cover on the screen was modified without taking it apart. No glass needed to be cut whatsoever. Only dashboard cut done was on the base to accommodate the bigger mounting area on the bigger screen. As this is their expertise, I can't share more but wanted to recommend that you don't cut the dash like OP as it is not a reversible process.
      01-18-2016, 05:54 PM   #63
david51
david51's Avatar
France
538
Drives: bmw M3 F80
Hello Alex
you have pictures of cutting glass?
      01-18-2016, 05:57 PM   #64
Alex@Alpine
Drives: E90 M3
Hello Alex
No sorry, I put everything back together but if you take it apart and push it into the hole you'll know where you have to cut
      01-18-2016, 06:08 PM   #65
david51
david51's Avatar
France
538
Drives: bmw M3 F80
ok thank you
      01-18-2016, 08:06 PM   #66
steelerfan
steelerfan's Avatar
163
Drives: 2017 X5 Silver
so has anyone done this with HU_CIC or does everyone have HU_NBT?
