| 09-10-2015, 04:14 PM | #1 |
![]() 10068
Rep 3,699
![]() Featured on BIMMERPOST.com B58 Engine and F30/F31 LCI technical training documents. 3 Series LCI.pdf B58 Engine.pdf |
| 09-10-2015, 05:35 PM | #2 |
Fool
1835
Rep 3,542
That explains the closed deck then:
Closed deck With the closed-deck design, the coolant ducts around the cylinder are closed from above and provided with coolant bore holes. This design is mainly reserved for BMW diesel engines. Due to the high combustion pressures in the diesel engine, a greater degree of rigidity is required in order that the forces can be safely absorbed. As the gasoline engine uses the same unfinished cast part as the diesel engine, it also benefits from this robust design. |
| 09-10-2015, 07:29 PM | #3 |
Rep 1,113
Forged Crank and 8HP50 tranny (368 ft. lbs vs 332 on 8HP45) are 2 things that stood out. Does this engine use the same size turbo as N55?
2003 11/02 Steel Gray Metallic on Red M3 - SMGII - VF570 - SUPERSPRINT - KW - BBS - CSL ROOF SOLD
2015 09/14 Alpine White on Red 435i xDrive MPPK - Expensive black vinyl with special lettering. SOLD 2020 12/19 Mineral Gray Metallic on Black Vinyl interior M340i xDrive Last edited by greekcs; 09-10-2015 at 07:44 PM.. |
| 09-11-2015, 12:35 PM | #6 | |
Rep 1,113
http://f30.bimmerpost.com/forums/sho...d.php?t=858575
2015 09/14 Alpine White on Red 435i xDrive MPPK - Expensive black vinyl with special lettering. SOLD 2020 12/19 Mineral Gray Metallic on Black Vinyl interior M340i xDrive |
| 09-11-2015, 12:42 PM | #7 |
ghey
525
Rep 2,042
Looks like the car uses 4G LTE now as well instead of 3G for the TCU (if properly equipped).
21 G05 > 20 G05 > 17 G30 > 14 F30 > 08 E90
| 09-11-2015, 12:46 PM | #8 |
European Editor
11165
Rep 22,992
Very cool! Thanks for posting this technical info.
| 09-11-2015, 01:53 PM | #13 |
Rep 7,331
Drives: 2018 340i M Sport
Garage List 2018 BMW 440i Conve ... [0.00]
2010 BMW 128i Conve ... [0.00] 2006 BMW 330i Sport [7.17] 2018 BMW 340i M Sport [8.89] 2020 BMW M340i xDrive [9.00] 2018 BMW 340i M Sport [8.00] 2004 BMW 330i ZHP [7.83] 2000 BMW 328i [6.17] |
I have no idea if this is a reason, but one of the downsides to the electric pump is that when it wears out and fails it does so with no prior warning. One second it's working and the next it isn't.
![]() www.bmwcca.org member #388003 - Use me as a referral & you could win a one day ///M Driving School!! notice: I don’t suffer fools ___________________________________________ |
| 09-11-2015, 02:10 PM | #14 | ||
![]() 89
Rep 1,296
Kind of makes 6NS a little more valuable now I suppose. Quote:
| 09-11-2015, 02:23 PM | #15 |
Rep 4,738
So what pushes the coolant around after you turn the engine off so you do not cook your turbo?
Current: 2021 M340i xDrivePrevious: '18 340i xDrive; '15 335 xDrive; '14 435i xDrive; '09 335 E92 xDrive |
| 09-11-2015, 02:28 PM | #16 |
Rep 2,233
Drives: '12 M3
IIRC, there was a secondary coolant pump (electric) on the B58 for cooling the turbos.
| 09-11-2015, 02:53 PM | #17 |
Rep 7
Forged crankshaft with 2 counterweights per bearing, same as the S55. The N55 has a cast iron crankshaft with 1 counterweight.
I bet we will see some massive power from this engine by tuners in the future. |
| 09-11-2015, 02:53 PM | #18 | |
![]() 10068
Rep 3,699
I checked - 6NS uses a different TCU. In a sedan, replacing it would require removing the headliner. Fortunately for me, wagons have it in the trunk. Still, the part is over $400. |
| 09-11-2015, 02:55 PM | #20 |
![]() 7
Rep 43
They went with a smaller turbo.
They also took out the use of the direct air intercoolers! Take a look at pages 46-47. Since they went that route I assume tuners wont be get lower IAT with out going meth or water injection? |
| 09-11-2015, 02:58 PM | #21 |
ghey
525
Rep 2,042
I think there is still a direct air IC, but the intake manifold now also has a coolant powered IC.
| Bookmarks |
