BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > ECU flash - questions
      05-11-2016, 12:58 PM   #89
Polo08816
Drives: 2014 335i M Sport
Originally Posted by cryptocar View Post
I've been having issues with printing for since 3.52.xx.
The new programming lines include all the lines needed for E-Series possibly the debug lines fix some of the issues with E-Series coding, since most of that hadn't been thoroughly tested in 3.54.xx. Looks like Beemerboy88 is including the E-series programming in his newest release, possibly with new codes now that it's been tested more.
I may put an older ISTA on the VM as well and have its DB files folder symlinked to the other ISTA directory for the purpose of printing to PDFs.
Fortunately the ISTAs aren't space-hungry. The DBs and PSdzdata files are.
      05-11-2016, 03:25 PM   #90
jgoens
jgoens's Avatar
3788
Drives: 2013 335i msport
Lol. I know storage space has become an issue for me as well. I run ISTA natively on my Win10 ultra book and keep a backup of the previous version + DBs and psdzdata on a little Samsung USB3.0 500gb external SSD.
I used to think the BMW software footprint was big. Then when I started down the path of Merc coding and diagnostics I realized BMW is a breeze compared to Xentry and the WIS DBs. By orders of magnitude lol. Needed to spring for a LaCie USB 3.0 6TB RAID storage device just to start downloading everything I need. My workstation I use for virtualization being out of commission for maintenance hasn't been helping the issue either. So much to do, so much to do.
Have you been able to code Mercedes? I was trying to figure this out a while back and asked around and it did not seem possible.
Last car: 2011 335i Msport. JB4. Vrsf CP
      05-11-2016, 04:21 PM   #91
cryptocar
cryptocar's Avatar
Drives: 13' F30 385xi VNV Speed Custom
Still working on that but I've had so many other things on my plate Merc coding and diagnostics have fallen by the wayside.
13' 335xi, ACF Tuned, ACF Stage 3 Turbo Kit (67mm),PDU PI, ACF Stage 4 LPFP, M-Perf Brakes, AEM CM10 Meth/Nitro, CG DR-1 + VS-1 3.5" Turboback, AFe S2 CAI+Ram Scoop, ER Chargepipe, Wagner EVOII Comp. FMIC, Stop-Tech SS Brake Lines, BMS Sport Oil Cooler Valve+Spacers F10mm R15mm, 19" Bridgestone Potenzas, KW EDC Coilovers, CF Seibon Hood + CSL trunk. Track:Pagid Race Pads, Stop-Tech Custom Pads Front+Rear Racing Tow Hooks
      05-12-2016, 07:50 AM   #92
aboulfad
aboulfad's Avatar
Drives: 2015 M4 MG/SO
2015 BMW M4  [10.00]
Originally Posted by Polo08816 View Post
http://cartechnology.co.uk/showthrea...8225#pid158225
Sounds like someone else thinks it's because ICOM is required. ENET will not work.
yup, doesnt work with Enet, I tried countless times, mentioned in the first thread trying to get ISTA/D programming working ! http://cartechnology.co.uk/showthread.php?tid=12734
      05-12-2016, 07:55 AM   #93
aboulfad
aboulfad's Avatar
2015 BMW M4  [10.00]
Funny I have no issues printing with 3.55.11 V2, I use foxit pdf reader driver, and my .config doesnt have any of the E-series programming!
      05-12-2016, 01:21 PM   #94
Polo08816
Wish I had another VM at work to check if these lines with 3.55.11 are consistent other versions...
Code:
    <!-- OperationalMode -->
    <add key="BMW.Rheingold.OperationalMode" value="ISTA_PLUS" />
    <add key="BMW.Rheingold.ISTAGUI.NewGUIActive" value="true" />
    <add key="StylesheetsImageLinkFixed" value="true" />
    <add key="BMW.Rheingold.RheingoldSessionController.Logic.TransferECUKomViaFASTA" value="true" />
    <add key="BMW.Rheingold.ISTAGUI.EnableAIRResearch" value="true" />
    <add key="BMW.Rheingold.CoreFramework.ILeanActive" value="false" />
    <add key="BMW.Rheingold.CoreFramework.PUKActive" value="false" />
    <add key="BMW.Rheingold.CoreFramework.PUKLoadSaveActive" value="false" />
    <add key="BMW.Rheingold.CoreFramework.IstaNFPackageFilter" value="ISTA_" />
    <add key="BMW.Rheingold.CoreFramework.OnlineUpdate.NewPackageStructure" value="false" />
    <add key="BMW.Rheingold.ISTAGUI.Pages.StartPage.ShowDisclaimer" value="false" />
    <add key="BMW.Rheingold.CoreFramework.PrintingType" value="DIALOG" />
    <add key="BMW.Rheingold.CoreFramework.PrintingType" value="both"/>
    <add key="BMW.Rheingold.CoreFramework.PrintingXpsPath" value="..\..\..\Print" />
      05-12-2016, 01:29 PM   #95
Polo08816
Code:
I played around with it but it may be simply use the default system printer. Once I changed it from Microsoft XPS (which kept opening OneNote) back to Adobe PDF (I have Acrobat X Pro installed in the VM) it now prints to PDF fine.
      05-16-2016, 08:18 AM   #96
Polo08816
I'm probably going to invest in a Schumacher INC-700A down the road.
Out of curiosity, anyone know of any cars that require more than 70 amps for flash programming? Want to make sure my eventual purchase is as future proof as possible.
      05-16-2016, 09:25 AM   #97
aboulfad
aboulfad's Avatar
2015 BMW M4  [10.00]
I think that's as good as it gets for that price range! The required amps depend on the number and type of ECUs, so hard to predict if this will be future proof but one of the best out there. If if this is for your own usage then you should be good.
      05-18-2016, 08:15 AM   #98
Polo08816
Received my ICOM yesterday. Tested it out today.
After setting the VM OS's IPV4 address and submask, it worked perfectly.
      05-21-2016, 10:18 AM   #99
dmayo305
dmayo305's Avatar
Drives: 2016 BMW 328i
cryptocar Any chance you would PM the link to the ISTA ver you're using, as well as the latest full PSdZData? I'm considering an attempt at ECU flashing, but haven't tried using ISTA yet, just Esys.
      05-21-2016, 04:45 PM   #100
cryptocar
cryptocar's Avatar
PM sent
      11-10-2016, 04:26 PM   #101
F30ed
Drives: F30 328i, X3 35M
Great discussion, detailed and interesting, I read the thread just for fun. 1 thing I am missing - why do you people do ECU flash?
As I understand , flash programming, is simply replacing executable code in the ECU to another (newer) version. But why? Is current software buggy? More functions added in new version?
Thanks
      11-10-2016, 07:16 PM   #102
aboulfad
aboulfad's Avatar
2015 BMW M4  [10.00]
Thanks
Yes and yes, although the details are sketchy as to what "bugs" were fixed or what new enhancements were introduced !
      11-11-2016, 01:27 PM   #103
F30ed
That is exactly the point of my question.
I am computer engineer myself, upgrades and patching on different levels is my bread and butter. But I do it for 3 major reasons:
- supportability
- new features
- fixing bug
Bugs: I have not seen a single description of any bug for DME let's say In several programming threads I read thru.
New features: again, with DME flush, I have not seen anywhere what improvements it would do.
Supportability: not a single note anywhere that dealer would say "You have old DME flash, we are not gonna change your tires" or something like that.
If anyone can explain the value of programming, I would appreciate that.
      11-11-2016, 07:36 PM   #104
aboulfad
aboulfad's Avatar
2015 BMW M4  [10.00]
@F30ed , you may want to visit other forums like the F80 where you will see mostly user reports of potentially perceived improvement or fixes. All this based on subjective feedback from fellow users. To date, all psdZdata released and available to us have no accompanying release notes and doubt that will ever change. It is only BMW that knows exactly what changed.
Thus said, some people flash different ECUs for various other purposes, such as retrofitting modules not originally in their car's, flashing software for transmission designed for the GTS onto non-GTS, ... the list goes on... and it is fun!
Almaretto2374.00
cryptocar497.00
      10-23-2017, 10:34 AM   #105
dargorbr
Brazil
Drives: F30 320i
cryptocar
can you send me the link for the ista version you're using?
ecu flash
