01-25-2016, 06:09 PM | #1 |
Rep 14,115
Drives: G82 M4C X-Drive
Track Handling Package
Looking into purchasing a new 340i M Sport. Right now I am torn between the Coral Red interior that I want, to a Black interior but with the Track Handling Package. I would like to go on the track at least a few times with this car, but I actually plan on getting a WRX beater for the track and dirt track. The question is: is it really worth it? How much better are the brakes and active suspension? What if I plan on lowering the car? How does that effect the active suspension?
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 Last edited by jmg; 01-25-2016 at 06:27 PM.. |
01-25-2016, 09:54 PM | #2 | |
Rep 807
As for brakes, you can't have to much brakes. If you plan on lowering, it definitely reduces your options and makes it harder since you'll need to go with a higher end coilover which plugs into the connector of the adaptive suspension in order not to give faults. Or low cost like springs. Also, Dinan has some software updates that can further stiffen the car If you have the money, go for it. I don't think you'll have any regrets. |
01-26-2016, 11:05 AM | #3 |
Rep 378
Drives: '16 340, ex e92 335, ex e46 M3
I'm a waiter, not a driver, but I have spent a LOT of time studying, and I have talked with a couple of owners. Adaptive is a must, but you don't have to get the Track Pack to get that. Std. brakes are more than adequate for daily use with occasional track use. While the jury is still out on VSS, I wanted it. My car, which is on the North Atlantic, has both the Sport & Track Packs.
Happy hunting! |
01-26-2016, 11:31 AM | #4 | |
2006 TIME Person Of The Year
9720
Rep 6,445
01-26-2016, 11:40 AM | #5 | |
Rep 764
01-26-2016, 12:59 PM | #6 | ||
Rep 228
01-26-2016, 01:26 PM | #7 |
Rep 4,984
A stock 340i is fine. Unless you track it regularly, you don't need a track package, brakes or suspension.
Case in point: http://f30.bimmerpost.com/forums/sho...d.php?t=954033 Enjoy!
<b>2023 M5C SRG|Aragon || 2018 Macan GTS</b>
2019 F90 Comp MBB|Black (sold) 2018 F80 ZCP TB|SS (sold) 2015 F30 335 AW|CR (sold) 2015 F31 MG|CR (sold) 2011 E90 JB|Oyster (sold) |
01-26-2016, 01:41 PM | #8 |
Rep 3,440
ZTR brakes are not significantly better than standard 340i brakes: the front rotor goes from 340mm to 370mm, and the pads use a different material.
Adaptive suspension probably won't be as easy to lower properly as standard suspension. Though if you're buying RWD, sport or adaptive will be lower than standard already - and in my view, that's low enough. The most important part of the track package, however, is something that no one has mentioned: Michelin PSS tires. They are absolutely, unquestionably, undeniably the best OEM supplied tires you can get today, short of hard core stuff like Z1SS or AD08. |
01-26-2016, 01:42 PM | #9 |
Rep 1,071
Based on my experience driving 3-Series BMWs at numerous HPDEs over the past 15+ years, the OE brake rotors, calipers, pads, lines and fluid are very capable for track days. In my opinion, the most important track handling option in these cars is the (RWD) sport suspension combined with max performance summer tires.
01-26-2016, 07:44 PM | #10 | |
2JZ-GTE
3053
Rep 4,006
My car has run flats and is track pack. |
01-26-2016, 07:50 PM | #11 |
Rep 3,440
01-26-2016, 11:53 PM | #12 |
Rep 807
01-27-2016, 08:52 AM | #13 |
Rep 764
01-27-2016, 09:50 AM | #14 | |
Rep 740
01-27-2016, 12:13 PM | #15 |
Rep 347
I'd be curious to know what makes the standard brakes so awful for just driving on the street. Can you elaborate?
IG: LBR_uno
01-27-2016, 12:53 PM | #16 |
Rep 3,949
01-27-2016, 01:41 PM | #17 |
Rep 184
Quick story, i have a rwd Msport with the adaptive m suspension, and my buddy has a 328xdrive w/o both. Going around a curvy road one time and i was able to go 55 easily with no issues and felt like a breeze. I looked in my rear view as he's trying to keep up and he was in the other oncoming lane. Obviously other factors come into play, but I've driven lets just say "very spirited" in both cars and the suspension is definitely worth it. You'll be sitting 10mm lower with the m sport as well. I would get the track package if you're into handling and precision. My opinion enjoy the handling at its finest with the package. Good luck
01-27-2016, 01:57 PM | #18 | |
Rep 3,949
01-27-2016, 09:07 PM | #19 |
Rep 14,115
I went with the Track Handling Package and I'm glad I did! Thanks everyone!
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
01-27-2016, 10:24 PM | #20 |
Rep 807
It must be a 335i option because my 320i doesn't have it nor did the 328i loaner I drove.
01-27-2016, 10:59 PM | #21 |
Rep 14,115
You can discriminate chassis and throttle on the 340i as well. I believe chassis only works if you have adaptive suspension.
01-28-2016, 09:58 AM | #22 | |
Rep 740
Since the MSport brakes are thicker and have larger calipers, the stopping power is pretty good. responsive and you can actually feel it. |
