03-10-2016, 08:06 PM | #1 |
Supreme Allied Commander
3897
Rep 54,605
Drives: F80 M3
Location: Santa Barbara, AP, Brembo, GIAC, Koni, Ohlins, Performance Friction, www.hpautosport.com
GIAC Software Flash for your N20 N26
GIAC software is now available for the BMW models equipped with high output N20 and N26 2.0L Turbocharged engines. This software calibration accommodates 91-93 octane fuel, as well as the factory exhaust and intake system. While retaining smooth drivability, the program offers dramatic and consistent power improvements throughout the entire power band over the OEM software. On 91 octane fuel, gains are as high as 47 wheel HP and 64 ft. / lbs. wheel torque in some areas of the power band. Peak gains are 32 horsepower and 59 ft. /lbs. of torque at four wheels over stock, on 91 octane fuel.
Notable features include the following: properly recalibrated air/fuel ratios improved throttle response for a drive-by-cable system feel optimized torque control for smoother, faster shifting smoothed power curve for greater linear acceleration The new high security DME Bosch MEVD17.2.X of the F-series BMW Turbo equipped models prompted GIAC's development of an entirely new proprietary flashing protocol for this product line, requiring ECUs to be bench flashed at an authorized GIAC software installer. MSRP for the software is $xxx(please contact your GIAC dealer) USD (does not include taxes or installation fees). Contact your local GIAC dealer for additional information and final pricing. Engine platforms to be supported: N26B20 (stock: 241 hp, 258 ft. /lbs.) [U.S. models, available now] N20B20 (stock: 154 – 241 hp, 177 – 258 ft. /lbs.) [Int'l 241 hp version supported currently] N20B16 (stock: 168 hp, 184 ft. /lbs.) [In development] Dynamometer test results from an MD-500 Mustang dyno are included here. The graph plots power tests (wheel HP and TQ) for a 2014 F30 BMW 328i Steptronic. The red line denotes a completely stock 328i Steptronic with OEM software, exhaust, intake and intercooler, on 91 octane. The blue and green lines denote two different runs for the same 328i Steptronic with GIAC 91 octane software, OEM exhaust, OEM intake and OEM charge cooler, also on 91 octane. 2014 F30 BMW 328i Steptronic Raw All Wheel Horsepower: Stock vs. Stage 1 91 octane pump 2014 F30 BMW 328i Steptronic Raw Power Gains Over Stock: Stock vs. Stage 1 91 octane pump 2014 F30 BMW 328i Steptronic Crank Horsepower: Stock vs. Stage 1 91 octane pump Last edited by HP Autosport; 04-04-2016 at 09:38 PM.. |
04-05-2016, 11:30 AM | #3 |
Assassin
144
Rep 156
Drives: 2013 F30 335i Xdrive M-SPORT
Interesting...
Whats the installation process? ECU removal and send to you for remap? Or through OBD2? and what about cost?
2013 F30 335i w/ Xdrive M-SPORT
MHD Tune, M Performance stainless pedals, M Performance trunk spoiler. |
04-05-2016, 02:03 PM | #5 | |
3897
Rep 54,605
Drives: F80 M3
Please PM for price or go here as this is a information only thread and posting prices from vendors are strictly prohibited: http://www.hpashop.com/GIAC-Software...?categoryId=-1 |
04-05-2016, 03:42 PM | #7 |
3897
Rep 54,605
Drives: F80 M3
Yes, GIAC just flashed one.
BMW M235 Chassis MEVD17xx Flash. [CAR MAKE]: --- BMW® [YEAR]: --- 2015 [PLATFORM]: --- BMW M235 Chassis MEVD17xx [ECU NUMBER]: --- SW7540108 [FILE NAME(S)]: --- 0170377283_7540108_M235_gl01_0170377283_.7z [LAST UPDATE]: --- 04.05.16 [BILLING CODE]: --- 55Agcb [MSRP]: --- $800 [FLASH LOADED]: --- Bench flashed New VAG BMW suite with logger. [OCTANE TYPE]: --- Premium Gasoline [CHIP OPTION TYPE]: --- Gen 1 - A [AVAILABLE MODES]: --- Pump only [HORSE POWER GAIN]: --- 20-45 hp [TORQUE GAIN]: --- 30-60 ft-lbs [REV LIMITER]: --- NA [SPEED LIMITER]: --- Removed |
04-05-2016, 05:38 PM | #8 | |
IG @bmwF9xG80
3817
Rep 7,595
"Logger" ? These bench/flash test were only tested on 91 octane Correct? I see it says "Pump Only" so it means it won't be tuned for those who use E30 blend + 93octane ? So for us on 93 octane ? or some that use occasional 100 octane ?
60-130 6.5s X4M
60-130 5.04s G80 M3 Stock Turbo 60-130 4.82s | 9.4@148mph 1/4 Hybrids IG: @bmwF9XG80 |
04-05-2016, 05:50 PM | #9 | |
3897
Rep 54,605
Drives: F80 M3
91 or 93 depending on where you are located. Race gas file not available yet. |
04-05-2016, 10:55 PM | #10 | |
IG @bmwF9xG80
3817
Rep 7,595
Also, from the GIAC site the list for GIAC Dealers is not accurate or database not working correctly since its also showing actual car dealerships under the list and I'm sure they wont be tuning BMW in a Audi Dealership ? Would be nice to see the same car stock and GIAC tuned with 93 octane Thanks
60-130 6.5s X4M
04-06-2016, 12:00 AM | #11 | |
3897
Rep 54,605
Drives: F80 M3
The delta is likely the same as the base run is on 93 and so will the performance flash. No, not typically. Most independent tuners will flash all that is available from GIAC. |
04-06-2016, 06:37 AM | #12 |
IG @bmwF9xG80
3817
Rep 7,595
Well still looks better than Dinan and cost less lol, but GIAC is only offering stage1 what about when stage2 becomes available ?
Will stage1 have Cat-Cel-Delete for those who are currently running catless downpipes?
60-130 6.5s X4M
04-06-2016, 07:23 AM | #13 |
Rep 179
What physical alterations are made to the ECU in order to bench flash? There's been a lot of talk recently of tuners drilling or pouring epoxy.
04-06-2016, 10:41 AM | #14 | |
IG @bmwF9xG80
3817
Rep 7,595
Also the BIG question is, that I saw on the F80 thread was HP Autosport does GIAC need to bench flash for update/revision or flashing back to stock or is it done thru OBD2 after initial bench flash ? Because I guarantee no one will bench flash you back to stock for free, but obd2 (5mins) will be able to update, revision 2, or flash back to stock at no extra cost (my local tuner has been doing the latter) among a few not many here in the states.
60-130 6.5s X4M
04-06-2016, 12:07 PM | #15 | |
3897
Rep 54,605
Drives: F80 M3
No, it's not likely free(that is up to your local GIAC dealer) as there is labor involved, not just a plug-in and download(even this involves a flat rate charge of 1/2 to 1 hour of labor time). |
04-06-2016, 01:08 PM | #16 | |
Rep 676
Drives: '17 F31 340xi US Spec
04-06-2016, 03:45 PM | #17 | |
Rep 1,503
FBO M235i r
F80 M3 |
04-06-2016, 04:11 PM | #18 | ||
Dejan
1755
Rep 4,197
Drives: 2018 Audi S3
Good to see other vendors joining the F chassis flashing option. I'll stay with my Enzo flash. 10,000 miles zero issues and I can run race gas and E30 mix. I'm on stage 2 with a downpipe and intercooler 93 octane.
FBO-PS1 and stuff
04-06-2016, 05:54 PM | #19 | ||
Rep 902
Drives: 13' F30 385xi VNV Speed Custom
Garage List 2013 Mercedes SL63 ... [0.00]
2010 VW Tiguan 2.0 ... [0.00] 2015 Tesla P85D [0.00] 2014 Mercedes S63 AMG [0.00] 2007 Mercedes GL450 [0.00] 1967 Ford Mustang [0.00] 2013 BMW F30 335xi [0.00] |
13' 335xi, ACF Tuned, ACF Stage 3 Turbo Kit (67mm),PDU PI, ACF Stage 4 LPFP, M-Perf Brakes, AEM CM10 Meth/Nitro, CG DR-1 + VS-1 3.5" Turboback, AFe S2 CAI+Ram Scoop, ER Chargepipe, Wagner EVOII Comp. FMIC, Stop-Tech SS Brake Lines, BMS Sport Oil Cooler Valve+Spacers F10mm R15mm, 19" Bridgestone Potenzas, KW EDC Coilovers, CF Seibon Hood + CSL trunk. Track:Pagid Race Pads, Stop-Tech Custom Pads Front+Rear Racing Tow Hooks
04-06-2016, 06:02 PM | #20 | ||
Rep 902
04-06-2016, 10:42 PM | #21 |
IG @bmwF9xG80
3817
Rep 7,595
Thanks MissionPerformance cryptocar dd1981 ocN55
Enzo, ACF, MP = can bench flash (initial 1st time) and everything else done thru OBD2 GIAC although these N20 numbers on 91 octane and stock car looks very decent, what will happen when a customer gets a DP or wants a stage2 ? You guys are you going to bench again and take out the ECU ? Why would anyone choose GIAC over some tuners as mentioned above that have been tuning Fxx since last year and revising and updating clients ?
60-130 6.5s X4M
05-27-2016, 03:30 AM | #22 | |
3897
Rep 54,605
Drives: F80 M3
If you are simply looking to drive daily or go down the drag strip once in a while you may want to choose a simple piggy back system because of cost. You can only trick the OME ECU to do so much before you pop a CEL, that is why some piggy backs has the auto erase CEL function. If you are going to track your car or just want total reliability, a true flash is the way to go. |
