BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > F30 Rear Subframe Bushings
      04-10-2016, 04:41 PM   #1
DVC
Diligentia Vis Celeritas
DVC's Avatar
Drives: 335i
It's been a long time since I've posted, but as I contemplate upgrades for this track season, I thought I would jump back in with a link to some some parts that I have been keeping an eye out for a couple years now... rear subframe bushings.
It looks like Bimmerworld is selling the set they developed for their F30 328 race cars (I kinda figured these guys would be first to market with these). From what I've read about this swap on other non-M cars, these are an amazing upgrade, so I'm looking forward to giving them a try.
      05-13-2016, 05:08 PM   #2
DVC
DVC's Avatar
Drives: 335i
Well, I guess I was the only one interested in these for F30s... makes sense now why it took so long for someone to bring them to market!
At any rate, I'll be installing them in the next couple of weeks, so impressions to follow.
      05-13-2016, 09:27 PM   #3
MickAv8r
MickAv8r's Avatar
Drives: 2014 EBII 328ix
Most people dont consider bushings until its time to replace them. I think Im currently done with suspension upgrades on my car but will be curious to hear your report.
Well weathered leather, hot metal and oil, the scented country air.
Sunlight on chrome, the blur of the landscape, every nerve aware!
2014 328ix EBII - Sport AT, Light Pkg, Blk Dakota, Moonroof, Navigation, Heated Seats, HK Audio, Driver Assist, Sport Pedals, Dinan Springs, Bilstein B8s, M-Performance BBK
      05-25-2016, 09:35 AM   #4
Seraphblade@sg
Drives: F30 328i
DVC , any updates / reviews?
      05-26-2016, 05:29 PM   #5
DVC
DVC's Avatar
Drives: 335i
Good timing for a quick update on this, as I installed them Tuesday night, and I've had a couple days driving around with them. (Ohlins Road and Track coil overs are going on today, so those will be the next review... but I wanted to do these a few days after the subframe bushings so I could post thoughts separately on each mod : )
So the verdict on the subframe bushings is extremely positive so far. Even just daily driving to work, the difference is very noticeable... the chassis feels totally solid (in a good way); GONE is that mushiness where the rear feels a bit disconnected from the frame. I was skeptical about whether these bushings would provide a noticeable improvement, but the result has exceeded the most optimistic of my expectations. If there's one downside, it's that you can more clearly feel what the rear suspension is doing, and with stock (Dinan-enhanced) dampers, the limitations of the soft dampers are much more apparent... But the Ohlins coil overs going on today should take care of that!
As for NVH, there is really no degradation whatsoever. Yes, the car feels stiffer - but the suspension seems to work more effectively at maintaining compliance without the added complication of rear subframe motion. The end result is that the ride is no more harsh, just more stable, with better, more clear feedback on what the back end is doing. Back end movement is crisp, instead of squirmy. These cars absolutely should have come this way from the factory.
The only challenge with rear subframe bushings is the installation. I am fortunate to have a mechanic friend (who works at a well-provisioned race shop) who helped me with the install after hours. In order to do it right, we took the entire subframe off, as we needed to use a hydraulic bearing press to get the bushings seated all the way in. All together, it took us about 7 hours... not an easy install for a DIY. So to pay a shop to do it, it certainly becomes a more expensive mod than just the $350 price of the kit... but if you're looking to take a big step forward in making the car feel more solid and communicative, then it's totally worth it.
      05-27-2016, 03:50 AM   #6
Bee Pee
Drives: AW M2 DCT
Send a message via Skype™ to Bee Pee
DVC,
Is your 335i a sedan ?
Did you consider retrofitting the OEM underbelly brace installed from a 4 series ??
More details about F32 brace being fitted to a F30 sedan in the thread below
http://f30.bimmerpost.com/forums/sho...78&postcount=7
BP
Gone but not forgotten - F20 M135i EB AT with options - what a hoot !
      05-28-2016, 03:52 PM   #7
crono06
crono06's Avatar
70
Drives: 2013 M Sport 335i xDrive
Originally Posted by Bee Pee View Post
DVC,
BP
If I remember correctly, these parts are also fairly cheap. I believe everything was under $100 USD.
      05-28-2016, 05:14 PM   #8
Bee Pee
Drives: AW M2 DCT
£150 here in the UK so may be 150-200 USD.
      06-01-2016, 01:22 PM   #9
DVC
DVC's Avatar
Drives: 335i
£150 here in the UK so may 150-200 USD.
Thanks - I wasn't aware of the F32 bracing parts... very interesting that they can be fitted on the 335!
glennQNYC - did you install these parts? If so, what's the verdict??
      06-01-2016, 08:05 PM   #10
glennQNYC
glennQNYC's Avatar
Drives: M Sport 335i
2014 335i  [4.83]
glennQNYC - did you install these parts? If so, what's the verdict??- did you install these parts? If so, what's the verdict??
I did install the F32 rear brace DVC. I wouldn't call any chassis brace a life changer but it was effective in adding stability when encountering mid-corner bumps or elevation changes. Considering the low cost- I wouldn't hesitate to do it again.
      06-01-2016, 09:56 PM   #11
DVC
DVC's Avatar
Drives: 335i
Thanks... ordered it from my local dealer, and picking it up tomorrow.
      02-05-2017, 09:08 AM   #12
Polo08816
Drives: 2014 335i M Sport
Rear Differential Bushings
I just wanted to add some information regarding the tools to do the rear differential bushings. I sent an email to getBMWParts and they were able to get back to me pretty quick.
Good evening,
I'm looking to replace my open rear differential on my 2014 335i RWD Auto (last 7: xxxxxx) with a BMW M Performance LSD in the near future.
I did a dry run here: http://f30.bimmerpost.com/forums/sho...9#post21090999
1. I wanted to confirm that Part # 83300495851 (aka tool 33 5 120) contains the following components pictured in ISTAD Rheingold: http://f30.bimmerpost.com/forums/sho...&postcount=142
33 5 121
33 5 122
33 5 123
33 5 124
33 5 125
My assumption is that this part number may be a special order since it's a tool. What's the typical ETA on something like this?
Yes, took kit 83300495851, $416.75 online does include those tools, along with 335126 and 335127 (puller jaws). Special tools are special order and non-refundable, and it would take us around 2 business days to get this set from BMW.
2. I am also researching tools used to remove and install the front and rear rubber mounts/bushings of the rear differential. I've had difficulty converting the BMW tool #s into part #s that I can put onto your site.
a. Front bushing install and removal: * Pictures of tool parts attached below.
33 5 161
33 5 162
33 5 163
33 5 165
33 5 166
33 4 465
33 4 466
* I assumed 33 5 16x translates into the 33 5 160 set which based on a bmw tools PDF I've seen likely translates into part # 83300495864. Would you be able to confirm this?
83300495864, $121.87 includes 161 – 165 above. It would take us around 2 weeks to get this set in as it’s available from Germany only at this time.
334465 is converted to part # 83300494981, spindle, 17.84 (2 business days)
334466 is converted to part # 83300494982, thrust nut, 51.70 (2 business days)
b. Rear bushing install and removal: * Pictures of tool parts attached below.
33 0 031
33 0 032
33 0 035
33 0 036
33 4 275
* These are the tools that I've been having a lot of trouble looking up. I would assume that 33 0 3x set translates into 33 0 030 but I haven't come across this in my research thus far.
330030 is converted to 83300496495, $266.29 and includes 330031, disc, 330032, bush, 330033, disc, 330034, disc, 330035, spindle, and 330036, nut. (1 in US, so 2 – 3 days if it holds, otherwise 2 weeks from Germany)
334275, plate, is converted to part # 83300494714, but is only available to order with set 83300494654, 153.36 (includes, 334271, plate, 334272, bush, 334273, plate, 334274, thrust piece, 334275 plate) (1 in US, so 2 – 3 days if it holds, otherwise 2 weeks from Germany)
      02-05-2017, 06:04 PM   #13
M-terkait
M-terkait's Avatar
Kuwait
110
Drives: F30 335i 3/13
Send a message via Skype™ to M-terkait
so not any independent shop can do lsd installs ? i see alot of special tools required..
PureTurbo
      03-29-2017, 07:19 AM   #14
Lancelot
France
158
Drives: 2014 M Sport ActiveHybrid3
This is really interesting.
I would be interested in other feedback regarding daily driveability and installation process, tips and tricks before taking the plunge, as this looks like a long and somewhat risky operation - not sure if it still applies or if it was for e9x only but i've seen people warning about not rupturing brake lines, needing to heat up the subframe with a flame, need for special install kits...
Then regarding daily driveability i'm coming from a not so great experience with anti roll bars, having chosen something too stiff for my needs on the rear, compromising comfort *and* grip, making me extra cautious when it comes to suspension mods.
Yet since the the F8x seem to need no bushings this kind of tells me it's the right thing to do.
2014 M Sport ActiveHybrid 3
M Performance BBK - F80 CFRP struts brace - Quaife LSD - KW DDC coilovers - Akrapovic Exhaust - HJS downpipe - Wagner Evo2 Comp IC - BMC air filter - Powerflex Subframe Bushings - Bimmertech amp with Focal speakers
      03-29-2017, 08:43 AM   #15
Polo08816
+1.
I'm not included to do an "upgrade" like this because chances are I will only need to replace the original rear subframe and differential bushings once through the usable life of the car at most.
Also, it requires removing the rear subframe which is not an insignificant procedure.
      04-27-2017, 06:58 PM   #16
Bee Pee
Drives: AW M2 DCT
Powerflex now showing rear subframe bush inserts for F series cars.....
https://www.powerflex.co.uk/road-ser...s+-3189/1.html
      04-28-2017, 09:13 AM   #17
Lancelot
France
158
Nice, those camber / caster adjustable bushings are interesting to get 2 more degrees of control on the car geometry;
BTW I think the OEM F2x/F3x bushings are also caster adjustable as their hole is slightly off center (not as much as the powerflex), I haven't figured yet how to rotate the bushing though.
      04-28-2017, 09:37 AM   #18
Bee Pee
Drives: AW M2 DCT
Lancelot,
stock F8x LCA and TS bushes are fixed/bonded construction and inner bush is concentric - photo of TS below
Even if you could rotate the inner bush, not being eccentric, it won't amount to anything.
BP
      04-28-2017, 09:39 AM   #19
Lancelot
France
158
Lancelot,
BP
Oh yes but my F80 TS now have F30 bushings
      04-28-2017, 01:10 PM   #20
Lancelot
France
158
Here's the pic to show what I mean with retrofitting F30 bushings onto F80 TS
The bushing center is slightly off and there's an indent - presumably to help rotate it.
      04-28-2017, 08:14 PM   #21
Big Nodge
Drives: 340xi 6MT
I installed these with my coilovers and swaybars. The bushings were not a direct fit into my 340i, my shop called bimmeworld and had to modify the bushings to get them to fit. If I recall the bushings itself fit but the hole in the middle through which you bolt them down had to be modified. I love the outcome from a handling perspective, but I've had a lot of creaks from the rear ever since. Just getting around to diagnosing that now. Early in that process but the bushings are a potential culprit.
      05-19-2017, 01:56 PM   #22
///CSL
///CSL's Avatar
Drives: ///
DVC any feedback about that ohlins?
