BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > USA - California > ▀▄ eas | BMW Coding & Personalization - $95 "ALL YOU CAN EAT" Special!
Vorsteiner
      07-27-2016, 02:30 PM   #1
chris @ eas
european auto source is proud to be your #1 Southern California coding facility!
Whether its a simple Check Engine lamp or are looking for full retrofit coding - we are your one-stop facility for your programming needs.
Why should you choose eas as your SoCal coding facility?
- Over 10+ years experience in module coding
- Fully Equipped with Autologic Diagnostic Scanner/Programmer
- Autologic Optical Interface (OPS Diagnostic Head)
- Proper Voltage Stabilization maintained with Fronius ACCTIVA Professional Flash (70 Amp)
- Non-biased programming facility, with no fear of warranty rejection.
The Autologic diagnostic tool for BMW vehicles is without doubt the most comprehensive tool to be made available to independent BMW specialists. Autologic BMW is unique in offering full dealer-level fault code read and re-set, full component activation, electronic control unit procedures, clearing and setting of adaptation values, full coverage of (ECU) control unitscoding, full programming capability including engine control modules and transmission control modules, adjustment of engine idle, real-time reading of all dynamic data, procedure for engine and immobilizer alignment, procedure for trial substitution of control units and procedure for the fitting of BMW accessories.
The Autologic Optical Interface has been designed to program the CCC-A control units on BMW. Connecting directly to the fibre optic MOST bus, the Autologic Optical Interface is able to communicate with CCC-A, CCC-BO, CCC-ASK, CCC-ANT, ULF TCU and MASK ECUs. The Autologic Optical Interface significantly reduces the time to program these control units and further increases the reliability and recoverability of flash updating these control units.
Power Stabilization
Intelligent battery charging systems are very important given the technology of BMWs. We use the Fronius ACCTIVA Series with Active Inverter technology, the only all-round charger which Autologic recommends.
Detailed Explanation of features
When completed, a complete demonstration of all features are given so you are 100% familiar with your new options.
Why do you not perform remote coding?
A number of precautionary steps are taken in order to ensure your BMW is safe during the coding process, which cannot be verified remotely. Your pride and joy and its well-being is important to us!
Coding/Individualization (options may vary by model/build configuration) - $95, unlimited options
- Remove Seatbelt Chime/Reminder
- Disable iDrive Legal Disclaimer
- Close Windows with FOB
- Fuel Stop Suggestion in Route Guidance
- Close Windows with Comfort Access (CA)
- Disable Rear Camera Legal Disclaimer
- Digital Speedometer on BC Stalk
- Add WeatherBand Radio
- Fog Lights + HighBeams
- Disable Side Camera Legal Disclaimer
- Always Remember Air Recirc. on startup
- Allow Top Camera View at all speeds
- 1-Touch Window Up while Doors Open
- Disable Night Vision Legal Disclaimer
- Always Remember AC OFF on startup
- Allow Side Camera View at all speeds
- Auto Start/Stop (remembers last option)
- Amber Corner Delete
- Fold Mirrors with door lock (AUTO)
- Fuel Reserve Warning (6 liter)
- Auto Start/Stop default to OFF
- Fold Mirrors with Comfort Access (CA)
- Fold Mirrors with FOB (2-Step)
- Add TPMS Tire Temp/Pressure Data
- DVDinMotion
- Change DVD Region Code
- Windshield Wiper Return
- Remove Speed Correction Factor
- Set HighBeam Assistant to AutoOn
- Change BT ringtone to personal tone
- Unlock Doors when ignition OFF
- Start vehicle without brake pedal
- Enable Video file import (NBT)
- Fog Lamp on when turning (signal)
- Door Handle LED on when in reverse
- Illuminate foglamps with Welcome Lights
- Unlock door when engine is OFF
- Pass mirror dips when in reverse (curb)
- Change iDrive startup animation (NBT)
- Turn off iDrive when door is opened
- Add slider in iDrive for ambient light
- Specify soft-touch blinker count (1-9)
- Enable Video playback from USB (NBT)
- Increase Angel Eye Brightness
- High-Beam Auto Assistant Default ON
- Enable Timestamp for Call Log (NBT)
- Disable Headlight Washer Jets
- Change NAV voice (British/US) (NBT)
- Enable Speech Input for Email & SMS (NBT)
- Enable Text in Office while Driving (NBT)
- Disable Audible Chirp when locking (NBT)
- GPS Current Location to NAV menu
Phone:
You can reach us directly by calling 866.669.0705
Hours of Operations:
Monday - Friday from 9AM to 5PM PST
Saturday - 9AM to 2PM PST
Sunday - Closed
Retail Location/ Installation Center:
Come check out our 8000 square foot facility in Anaheim, CA. We install everything we sell.
Contact Info:
Phone: 866.669.0705 x26
Email: chris@europeanautosource.com
Website: http://www.europeanautosource.com
Feel free to contact me via PM, email, or phone if you have any questions.
      08-02-2016, 04:31 PM   #2
chris @ eas
Coding slots available this week!
      08-16-2016, 01:13 PM   #3
chris @ eas
Thank you for the Inquiries! Coding slots now available!
      08-17-2016, 08:00 PM   #4
chris @ eas
Coding slots are filling up! book your appointment today.
      10-29-2016, 12:03 AM   #5
minc1209
minc1209's Avatar
Drives: 428i gran coupe
I'm went today for coding
eas guys very nice and very good job
thank you for everything
      10-29-2016, 08:40 PM   #6
the_man_in_blue
Drives: It's blue.
how long does this take? I'm wondering if I can block off a couple hours, or is this a sit in the shop and wait a few minutes kind of thing...
      10-30-2016, 02:16 AM   #7
minc1209
minc1209's Avatar
it's take 10~~20 min
      10-31-2016, 12:22 PM   #8
chris @ eas
PM coming your way!
      11-30-2016, 09:03 PM   #9
chris @ eas
Coding slots open!
PM for details and pricing!
      12-07-2016, 03:17 PM   #10
chris @ eas
Coding Slots available
PM for details!
      12-12-2016, 01:44 PM   #11
chris @ eas
Coding slots available for immediate booking!
      12-16-2016, 08:19 PM   #12
chris @ eas
      12-23-2016, 03:44 PM   #13
chris @ eas
[b]Coding slots ready for immediate booking!
PM for details![/B
      12-26-2016, 10:40 PM   #14
JaredG_F30
JaredG_F30's Avatar
532
Drives: 2014 335i, M-Sport, Manual
Do you have coding slots available Jan 7th? First thing in the morning would be great. Also, do you guys do nav updates?
2014 F30 335i, M-Sport, 6MT, V801s, custom exhaust, CTS Turbo Intake & IC, FTP CP, VRSF DP, TMS Strut Brace, BM3 Stg 2, 381 whp, 429 wtq (waiting for install: GFB DV+) Next: Ohlins R&T, M Performance LSD, M Performance Brake Kit
SPI Films Blog/DIY Vids
      12-27-2016, 01:10 PM   #15
chris @ eas
PM Coming your way!
      12-27-2016, 08:28 PM   #16
chris @ eas
Coding Slots available for immediate booking
PM for details and availability
      12-29-2016, 08:25 PM   #17
chris @ eas
Coding Slots available and ready for immediate booking
PM to book your appointment!
      01-02-2017, 08:41 PM   #18
chris @ eas
Coding slots open and ready for immediate booking!
PM for details.
      01-03-2017, 08:59 PM   #19
chris @ eas
Coding slots available for immediate booking,
PM for details!
      01-06-2017, 03:08 AM   #20
newuser310
Drives: 335
Can you guys enable the Euro adaptive headlights if I already have the LEDs and lighting package (all the hardware)?
      01-06-2017, 01:42 PM   #21
chris @ eas
PM'd
      01-11-2017, 08:52 PM   #22
chris @ eas
Coding slots available for this week!
Make sure you stop by this saturday for our Dyno / Coding event!
