BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > USA - California > ▀▄ eas | BMW Coding & Personalization - $95 "ALL YOU CAN EAT" Special!
European Auto Source
      01-22-2017, 05:04 PM   #23
sc68z28
Drives: 330e
Originally Posted by newuser310 View Post
Can you guys enable the Euro adaptive headlights if I already have the LEDs and lighting package (all the hardware)?
Are we talking Anti-Dazzle?
Can S5APA be removed, if I have S552A Adaptive LED Headlights, without any addition parts/hardware required?
---Bill.
      01-23-2017, 07:44 PM   #24
CalCarNut
CalCarNut's Avatar
Drives: 2015 F36 Jet Black Sport Line
Originally Posted by mo @ eas View Post
Coding slots available for this week!
Make sure you stop by this saturday for our Dyno / Coding event!
Damn, was this posted on the forums???? (dyno)
2015 BMW F36 428i JetBlack. Sport Line Edition
25% 3M Tint|-HD Tuning Stage 1 (formerly known as GSR Stage 1|
      02-21-2017, 03:41 PM   #25
chris @ eas
Coding Slots available for immediate booking!
Pm for details!
      03-20-2017, 07:49 PM   #26
chris @ eas
Coding slots are open and available for immediate booking!
      03-22-2017, 07:04 PM   #27
Heckys428i
Drives: 2016 Black 428i
european auto source is proud to be your #1 Southern California coding facility!
Whether its a simple Check Engine lamp or are looking for full retrofit coding - we are your one-stop facility for your programming needs.
Why should you choose eas as your SoCal coding facility?
- Over 10+ years experience in module coding
- Fully Equipped with Autologic Diagnostic Scanner/Programmer
- Autologic Optical Interface (OPS Diagnostic Head)
- Proper Voltage Stabilization maintained with Fronius ACCTIVA Professional Flash (70 Amp)
- Non-biased programming facility, with no fear of warranty rejection.
The Autologic diagnostic tool for BMW vehicles is without doubt the most comprehensive tool to be made available to independent BMW specialists. Autologic BMW is unique in offering full dealer-level fault code read and re-set, full component activation, electronic control unit procedures, clearing and setting of adaptation values, full coverage of (ECU) control unitscoding, full programming capability including engine control modules and transmission control modules, adjustment of engine idle, real-time reading of all dynamic data, procedure for engine and immobilizer alignment, procedure for trial substitution of control units and procedure for the fitting of BMW accessories.
The Autologic Optical Interface has been designed to program the CCC-A control units on BMW. Connecting directly to the fibre optic MOST bus, the Autologic Optical Interface is able to communicate with CCC-A, CCC-BO, CCC-ASK, CCC-ANT, ULF TCU and MASK ECUs. The Autologic Optical Interface significantly reduces the time to program these control units and further increases the reliability and recoverability of flash updating these control units.
Power Stabilization
Intelligent battery charging systems are very important given the technology of BMWs. We use the Fronius ACCTIVA Series with Active Inverter technology, the only all-round charger which Autologic recommends.
Detailed Explanation of features
When completed, a complete demonstration of all features are given so you are 100% familiar with your new options.
Why do you not perform remote coding?
A number of precautionary steps are taken in order to ensure your BMW is safe during the coding process, which cannot be verified remotely. Your pride and joy and its well-being is important to us!
Coding/Individualization (options may vary by model/build configuration) - $95, unlimited options
- Remove Seatbelt Chime/Reminder
- Disable iDrive Legal Disclaimer
- Close Windows with FOB
- Fuel Stop Suggestion in Route Guidance
- Close Windows with Comfort Access (CA)
- Disable Rear Camera Legal Disclaimer
- Digital Speedometer on BC Stalk
- Add WeatherBand Radio
- Fog Lights + HighBeams
- Disable Side Camera Legal Disclaimer
- Always Remember Air Recirc. on startup
- Allow Top Camera View at all speeds
- 1-Touch Window Up while Doors Open
- Disable Night Vision Legal Disclaimer
- Always Remember AC OFF on startup
- Allow Side Camera View at all speeds
- Auto Start/Stop (remembers last option)
- Amber Corner Delete
- Fold Mirrors with door lock (AUTO)
- Fuel Reserve Warning (6 liter)
- Auto Start/Stop default to OFF
- Fold Mirrors with Comfort Access (CA)
- Fold Mirrors with FOB (2-Step)
- Add TPMS Tire Temp/Pressure Data
- DVDinMotion
- Change DVD Region Code
- Windshield Wiper Return
- Remove Speed Correction Factor
- Set HighBeam Assistant to AutoOn
- Change BT ringtone to personal tone
- Unlock Doors when ignition OFF
- Start vehicle without brake pedal
- Enable Video file import (NBT)
- Fog Lamp on when turning (signal)
- Door Handle LED on when in reverse
- Illuminate foglamps with Welcome Lights
- Unlock door when engine is OFF
- Pass mirror dips when in reverse (curb)
- Change iDrive startup animation (NBT)
- Turn off iDrive when door is opened
- Add slider in iDrive for ambient light
- Specify soft-touch blinker count (1-9)
- Enable Video playback from USB (NBT)
- Increase Angel Eye Brightness
- High-Beam Auto Assistant Default ON
- Enable Timestamp for Call Log (NBT)
- Disable Headlight Washer Jets
- Change NAV voice (British/US) (NBT)
- Enable Speech Input for Email & SMS (NBT)
- Enable Text in Office while Driving (NBT)
- Disable Audible Chirp when locking (NBT)
- GPS Current Location to NAV menu
Phone:
You can reach us directly by calling 866.669.0705
Hours of Operations:
Monday - Friday from 9AM to 5PM PST
Saturday - 9AM to 2PM PST
Sunday - Closed
Retail Location/ Installation Center:
Come check out our 8000 square foot facility in Anaheim, CA. We install everything we sell.
Contact Info:
Phone: 866.669.0705 x26
Email: mo@europeanautosource.com
Website: http://www.europeanautosource.com
Feel free to contact me via PM, email, or phone if you have any questions.
Hello does coding void the warranty? I'm new to the BMW family.
      03-22-2017, 07:42 PM   #28
chris @ eas
It is very Unlikely for a dealer to void a vehicles warranty over coding. The options we offer are options the vehicle is already capable of. Most dealers wont even notice your car is coded!
      03-22-2017, 11:42 PM   #29
Heckys428i
How can I make an appointment with you?
      03-23-2017, 11:38 AM   #30
tom @ eas
tom @ eas's Avatar
2010 BMW M3  [5.00]
2015 BMW M4  [3.50]
Just give any of us a call, PM or email and we'll be happy to get you set up. We're even open Saturdays.
Tom G. | european auto source (eas)
email: tom@europeanautosource.com web: www.europeanautosource.com tel 866.669.0705 ca: 714.369.8524 x22
GET DAILY UPDATES ON OUR BLOG FACEBOOK YOUTUBE FLICKR INSTAGRAM
      03-24-2017, 06:55 PM   #31
chris @ eas
Coding slots open and available for immediate booking!
      03-27-2017, 07:59 PM   #32
chris @ eas
Coding slots available for immediate booking,
PM for details!
      03-28-2017, 07:09 PM   #33
chris @ eas
Coding slots available for immediate booking!
PM to book your appointment!
      03-30-2017, 08:02 PM   #34
chris @ eas
All PM's replied to!
Coding slots still available.
PM to schedule!
      04-03-2017, 12:31 PM   #35
chris @ eas
PM to get your car coded today!
      04-04-2017, 05:03 PM   #36
chris @ eas
Coding slot still available for this week!
      04-06-2017, 07:53 PM   #37
chris @ eas
PM to get your car coded!
      04-07-2017, 07:14 PM   #38
chris @ eas
PM today to schedule your coding appointment!
      04-09-2017, 05:26 PM   #39
theoaks212
Drives: 328i
328i Coding
hello can you install LED lights.. pls PM me for pricing.. thanks
      04-10-2017, 12:17 PM   #40
chris @ eas
PM Coming your way!
      04-10-2017, 06:32 PM   #41
chris @ eas
All PM's Replied to!
PM today to get your vehicle coded!
      04-14-2017, 07:10 PM   #42
chris @ eas
PM to book your coding appointment today!
      04-17-2017, 06:55 PM   #43
chris @ eas
PM to reserve your slot today!
      04-19-2017, 07:03 PM   #44
chris @ eas
Coding slots still available for immediate booking!
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
