M2 Technical Topics > Track / Autocross / Dragstrip > 18 inch Track wheels
      07-31-2016, 07:37 PM   #1
koastal
Australia
376
Drives: F87
These Koya semi forged SF03 fit
Not all 18,s do
ET- 20 front - 9 inch
ET - 35 rear - 10 inch
M2 track.pdf
      09-19-2016, 08:42 AM   #2
Twt
Twt's Avatar
634
Drives: 2017 M2
18 wheels
Does anyone know if a set of 18 track wheels/tires will fit inside the M2
      09-19-2016, 02:51 PM   #3
rjn
Drives: 2017 M2
Tire rack has an 18 x 9.5 inch square solution that clears the calipers, and they're wickedly affordable.
TR Motorsports C4 is the name of the wheel. I think they're not yet in stock, but my buddy (their wheel engineer) says they're just a few weeks out.
These will be my track wheels, and likely winter wheels too at this price.
Rob
      09-19-2016, 07:34 PM   #4
Twt
Twt's Avatar
634
Drives: 2017 M2
What tire/size do you plan to use for the track
      09-20-2016, 07:05 AM   #5
rjn
Drives: 2017 M2
He say 265s are the easy and best fit - no mods nor spacers, so that's my plan A
Also says that 275s can be done with a fender roll and max camber in the back, and that depending on tire choice (how big a rim protector), might need a spacer up front.
As for tires, I'd been running BFG Gforce R1s for a long time, but just tried some Bridgestone RE-71R on my E36, and like them, so that'll probably be the first set
Think I'll wear out a set of 265s and let someone else do that 275 development work, and wait to hear how it works out
Rob
      09-20-2016, 01:11 PM   #6
Twt
Twt's Avatar
634
Drives: 2017 M2
Good plan....I may try running R888s..used them on my Z06 for years in rain or dry
      09-20-2016, 01:11 PM   #7
David@ActiveAutowerke
Drives: M2
18x10 et35 with 275/35/18 works great in the rear, no rubbing at -1.8* camber.
18x10 et23 with 275/35/18 works up front with -2.5* camber but you have to trim a small tab where the bumper meets the fender if your car is lowered.
      09-20-2016, 01:16 PM   #8
Drives: M2
18x10 square with 275/35/18 NT-05
      09-20-2016, 02:01 PM   #9
FAN_F1
FAN_F1's Avatar
74
Drives: 2017 F87 M2 / 2009 997.2 C4S
Like!
Like it, a lot!
2017 F87 M2 M-DCT ALPINWEISS / Oct 2016 / BMW WELT European 'Re-Delivery'
2016 F87 M2 M-DCT ALPINWEISS May 2016 / BMW WELT European Delivery (Gone)
2009 997.2 C4S PDK PCCB (DD)
1991 E30 318is Diamondschwarz/Blk (Garage Queen)
      09-27-2016, 07:31 AM   #10
M3 Adjuster
Albania
7906
Drives: 1M, X1 M Sport, E46 325ic
Yes they do. Either upright or lay then down on the back seat in pairs.
      09-27-2016, 07:32 AM   #11
M3 Adjuster
Albania
7906
Sharing is caring
      09-27-2016, 07:34 AM   #12
M3 Adjuster
Albania
7906
The Apex EC-7 also fits in 18s.
I have heard that the Apex Arc- 8 does not however.
      10-11-2016, 11:11 AM   #13
CosmosMpower
CosmosMpower's Avatar
2051
Drives: F87c, GT3, MK7 GTI
Anyone know if Apex EC7 in 18X10 ET25 square will fit with a 265/275/285 tire?
      10-11-2016, 11:41 AM   #14
Drives: M2
It would work up front with a little negative camber but will be a bit aggressive for the rear.
      10-11-2016, 01:56 PM   #15
CosmosMpower
2051
Meaning it will rub for sure?
      10-11-2016, 04:17 PM   #16
Drives: M2
I haven't actually tested that fitment in the rear but our car has 18x10 et35 275 in the rear and with a 10mm spacer I'm pretty sure it would rub.
      10-15-2016, 08:20 PM   #17
CosmosMpower
2051
Would that combo work without the spacer?
      10-17-2016, 11:07 AM   #18
Drives: M2
We run the 18x10 et35 without a spacer with no rub in the rear. I meant that adding a 10mm spacer to mimic the et25 fitment you proposed would likely make our car rub. Et35 works but I doubt et25 would.
      10-17-2016, 01:30 PM   #19
CosmosMpower
2051
Thanks I was thinking I'd just buy another pair of ET35's since the ET25 fits in the front.
      11-06-2016, 07:54 PM   #20
MilehighM3
MilehighM3's Avatar
Drives: Harrop E90 M3
2009 E90 M3  [6.50]
I'm running 18x9.5 ET35 with a 15mm spacer up front to clear the strut/ cool springs. 275/35 RE71R and no clearance issues at all.
      01-17-2017, 08:30 AM   #21
_pancho_
_pancho_'s Avatar
Sweden
Drives: modified F87 M2 Man -17
Hello,
what wheels are you using?
regards Tobias
      01-17-2017, 07:01 PM   #22
MayorAdamWest
MayorAdamWest's Avatar
Drives: 2017 F87 M2
18x10 ET33 all square with 275 RE71r fit thanks to Alekshop.
CSBM52721.00
m2
