09-29-2016, 12:13 PM | #1 |
Rep 1,782
How do you guys cope with wheel hop? I don't normally dump the clutch on my car........ Usually because u end up smelling clutch due to stock clutch and e85 powaaaahhhh. However the wheel hop is really aggravating if I'm on a road with any kind of grip. Any advice other than the obvious....
13' 335i M Sport. EBII/Coral Red 6MT. RPI GT exhaust, Resonator delete, PS1, GFB DV , BM3 Stage 2, ER CP, VRSF DP, VRSF 5.5in Stepped FMIC, Dinan Shockware. Carbon M Performance rear diffuser. M4 trunk lip. Conti DWS06 225/40/19 and 255/35/19
09-29-2016, 01:55 PM | #2 |
3441
Rep 79,211
Aside from a differential lock down kit (available on the E9x chassis), you can start with upgrading the shocks.
It really depends on what is primarily causing the wheel hop but there is plenty of slop in the F3x chassis, between sub frame bushings, suspensions bushings, ETC ETC |
Chicken_Joe606.00 |
09-29-2016, 03:34 PM | #3 | |
Rep 1,782
09-29-2016, 10:21 PM | #4 |
Rep 389
Drives: '13 F30 335i MSport
I got one...don't dump the clutch. Stop light drag racing or what? What tires u running?
2013 GSM 335i MSport
09-29-2016, 11:17 PM | #5 |
Rep 1,782
I got one...If you would have read my post thoroughly then you would have seen that I don't normally dump my clutch smh. I don't stop light drag anything. I went to the drag strip and got stupid wheel hop with no burnout and waterbox wet tires. I run 255/35/19's BFG G Force.
09-30-2016, 06:03 AM | #6 | |
Rep 389
963mw331.00 |
09-30-2016, 07:38 AM | #7 |
Moon Parasite
655
Rep 1,336
So the F30 has the same size (diameter) half shafts ?
2020 X4M Comp. (currently stock) - Was 2015 335 MSport -MPPK -Borla ATAK -Dinan Sport+ - E.R. Charge pipe / 2013 X1 35i Sport - Dinan tune / 2009 X6 50i Dinan badged |
09-30-2016, 08:44 AM | #8 | |
Rep 1,782
10-01-2016, 11:33 AM | #9 |
Rep 6,990
Limited-slip Diff and either Dinan Shockware (if you have dynamic suspension) or coilovers/better shocks if not.
10-01-2016, 12:06 PM | #10 |
Rep 1,782
I was planning on getting the shockware if I can manage it
03-23-2017, 08:20 AM | #11 |
Rep 3,947
Chicken_Joe606.00 |
03-23-2017, 03:23 PM | #13 |
Rep 100
Same issue here. If I dump the clutch it'll just light the tires up instantly. If I slip it a bit I get wheel hop. Running MPSS 275 on the rears with stock clutch.
FBO with E85 here also. |
Chicken_Joe606.00 |
03-24-2017, 05:40 AM | #15 |
Rep 775
Lots of power and open diff sounds like the problem. Am sure you know you need a limited slip to help get power to the ground.
Enjoy the Drive,
Steven 2014 435i M-Opt, M LSD, Dinan CAI/IC/BTurbo/Stage 4, ER TIC/CP, GFB DV+, Fabspeed HJS cat DP & Mich PS4S. |
Chicken_Joe606.00 |
03-24-2017, 07:36 AM | #16 |
Rep 2,957
Same problem here. I thought it was my tires but it sounds like even with topline tires it's happening. I'm FBO/E85
03-24-2017, 07:40 AM | #17 | |
Rep 3,947
03-24-2017, 07:41 AM | #18 |
Rep 2,957
03-24-2017, 07:45 AM | #19 |
Rep 3,947
Chicken_Joe606.00 |
03-24-2017, 08:18 AM | #20 |
Rep 1,782
Unfortunately I don't have an LSD aggravatingly enough. I feel like the M Sports should come with an LSD stock and have the option to remove it if the buyer wanted as a no charge option from the factory.
GTBrandon260.00 |
03-24-2017, 11:22 AM | #21 |
Rep 775
Agree the Ltd Slip Diff should have been std, or at least an option you can check off when ordering the car. Had wheel hop with open diff in the 2014 435i. So.... just had the M LSD installed and it is easy to feel the difference. Am still breaking it in (for a total of 500 miles) so am not getting too aggressive, yet can easily feel the improvement. The car rotates MUCH better in the twisties and putting power down is far easier with no wheel hop. With the LSD it is easier to have the car 'properly' oversteer rather than hop.
You really need the Ltd Slip Diff when you start making some good power and drive the car. JMHO YMMV
Enjoy the Drive,
Chicken_Joe606.00 |
