BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > 340i b58 coolant loss
View Poll Results: Does your b58 consume coolant?
Yes 46 54.76%
No 38 45.24%
Voters: 84. You may not vote on this poll
      11-21-2016, 04:00 PM   #23
XRAVE
Member
XRAVE's Avatar
256
Drives: 135i
Just checked today, 4000 miles and the main tank is at the minnmium mark. Inter cooler tank is full.
Previous: 2013 135i Space Grey w/Coral Red | 6 Speed MT | M Pkg | JB4 | AA Downpipes | AA Exhaust |
Previous: 2015 M3, BSM[/SO/CF | DCT | Adaptive M | 19" Black | CF Roof |
Current: 2016 340i, BSM w/Coral Red 18" Grey | 6MT | M Pkg | Track Pckg | MPE | JB+
      03-06-2017, 09:57 PM   #24
High Flier
Drives: 2016 340iX 6MT MPPSK 93 Octane
I had a low coolant light around 3000 miles, with some evidence of coolant leaking around the cap. May have been high pressure due to low coolant? The dealer topped it off and gave me some extra coolant to take home and top it off after the engine cooled down...yes it's lower when cooler. I do have to top it off every 1000 miles or so, but check it regularly now before the light come on.
      03-29-2017, 09:41 AM   #25
XRAVE
Member
XRAVE's Avatar
256
Drives: 135i
Seems like in 3 months I've dropped significantly below the minimum line. 9 Months ago it was at max. Is the normal rate or should I get this checked out?
Also, is filling with distilled water recommend?
      03-29-2017, 09:59 AM   #26
bimmer456
Drives: 340i
Had coolant added at 8k miles, not since then and I'm at 13k mikes
      03-29-2017, 10:46 AM   #27
insanecoder
Drives: 340isDrive
U guyz are making me nervous again.. gonna check it again tonight
      03-29-2017, 10:49 AM   #28
Cruz28/40
Cruz28/40's Avatar
Drives: 2017 340i w/ MPPSK
I would get it checked
2017 340i w/ MPPSK & Many M Performance Parts
2016 328i (wife's)
      03-29-2017, 03:51 PM   #29
cptcrunch
Captain Crunch
cptcrunch's Avatar
84
Drives: 2016 340i
Had low coolant warning in October 2016 ~4k miles, the secondary tank was dry. Dealership filled it up with no questions and I went on my way. No problems since.
Current: BMW Welt Delivery 4/14/16: European Delivery - 2016 340i EBII/Saddle - ZMP | ZCW | ZDA | ZLP | ZTP | M Adaptive | Rear Shades | MPPSK Before and After Dyno
Retired: 2011 335D Space Grey/Black - ZSP | ZPP | ZCW | 6FL | Sat Radio | Nav | $600 Base Audio Upgrade
      03-30-2017, 12:49 PM   #30
STR8-6IX
Drives: RWD 528i N52
people, dont forget to check your coolant levels when the car is cold so you get an accurate reading.
everyone keeps saying that the coolant system is a closed loop and that coolant consumption is not normal, but it is so common with BMW's especially if driven aggressively to the point where i see topping up my coolant and checking it occasionally as normal. what gives?
      03-30-2017, 12:51 PM   #31
bimmer456
Drives: 340i
It may be evaporating through the coolant reservoir cap as this appears not to be pressurized and the cap feels somewhat loose. That would explain why no leaks are detected when doing a pressure test. They may need to redesign the reservoir and/or cap.
      03-30-2017, 12:54 PM   #32
STR8-6IX
I dont think it is evaporating, I opened the tank while the car was warm once to check coolant levels and release some pressure due to aggressive driving 5 minutes earlier and alot of pressure came out. it doesnt seem to be leaking at all.
I'm almost certain its just being burned through the engine because it happens faster when you drive aggressively, but many people keep telling me this is not possible. I know for certain there are no leaks though and this is also happening with other cars owned by friends/family like an Acura and Mazda. they are new cars, no chance of those leaking either and we checked.
      03-30-2017, 01:25 PM   #33
bimmer456
Drives: 340i
I'm not sure how it would be burned through the engine as it doesn't go into the combustion chamber unless it's leaking into the oil or the engine itself. That would not be normal and would be a serious problem. Much of the coolant is water and it would have to be going somewhere, it can't technically be burned I would think. It remains a mystery as there aren't any leaks.
      03-30-2017, 01:38 PM   #34
mookie45
mookie45's Avatar
412
Drives: 2017 AW 340i M-Sport
Damn, not this again
      03-30-2017, 01:42 PM   #35
kern417
Drives: 2018 440i
there are a few threads on this already.
http://f30.bimmerpost.com/forums/sho....php?t=1343545
http://f30.bimmerpost.com/forums/sho....php?t=1349796
http://www.2addicts.com/forums/showthread.php?t=1331686
seems like some people are replacing the cap to fix it.
      03-30-2017, 02:37 PM   #36
insanecoder
Drives: 340isDrive
thanks I'll note that.. maybe the cap seals arent the greatest
      03-30-2017, 02:38 PM   #37
enjoythemusic
enjoythemusic's Avatar
126
Drives: 2014 BMW 435i Dinan Stage 4
Grab an oil sample and send it to the lab. That's the best way to know if collant is making it into the engine. I'd do it sooner rather than later. Sure maybe they need to 'burp' the system, yet for ~$30 you can get an analysis to be sure.
Enjoy the Drive,
Steven
2014 435i M-Opt, M LSD, Dinan CAI/IC/BTurbo/Stage 4, ER TIC/CP, GFB DV+ & Mich PS4S.
      03-30-2017, 02:39 PM   #38
bimmer456
Drives: 340i
Originally Posted by rak299 View Post
You may be right, but I don't know what concentration got installed at the factory. I will pretend that BMW coolant has a boiling point of 180C and water boils at 100C. If we assume the correct liquid is a 75/25 mixture (25% water), it would boil at 160C without a cap installed and vent at about 175C with the pressure cap. If some cars got produced with 50% water, it would lower the temperatures to 140C without a cap and vent at 155C with a cap. Normal coolant temperature under load might be 160C. In that case, it would vent (evaporate) with the wrong mixture and not vent when the concentration is raised. I know that coolant is normally heated above the normal boiling point because I know someone (not very bright) who got badly burned trying to remove a cap before the engine cooled down.
Yes that is why it is pressurized to raise the boiling point.
      03-30-2017, 03:57 PM   #39
kern417
Drives: 2018 440i
That's not really true regarding the oil analysis. Copied from one of the linked threads:
Originally Posted by kern417 View Post
if you have a blown headgasket, it can go one of three ways:
1. Burning oil: gasket broken between oil passage and combustion chamber
2. Burning coolant: gasket broken between coolant passage and combustion chamber
3. Mixed fluids: gasket broken between coolant passage and oil passage
if it's not burning (check exhaust for sweet smell) and you're losing coolant, then you have a leak somewhere in the system or it's evaporating past the cap. easiest way to verify is pressure test the system and the cap.
      03-30-2017, 04:00 PM   #40
kern417
Drives: 2018 440i
correct. personally i wouldn't play with the percentage. most coolant concentrate bottles will tell you the max and min ratios as well as the boiling/freezing points for each combination. usually it's between 40%-60% mix, otherwise you risk freezing the system in the winter or boiling it in the summer.
      03-30-2017, 04:06 PM   #41
bimmer456
Drives: 340i
Originally Posted by chippychip View Post
How many of you are having issues with your BMW 340i eating coolant? I'm up to 2000 miles and have already added half a gallon between the engine coolant and intercooler tank. By the way, I've read too many posts where people think the second coolant tank is for the turbo when it's really for the air to water intercooler.
I had mine topped of at 8K miles
      03-30-2017, 04:07 PM   #42
bimmer456
Drives: 340i
Originally Posted by F30MGM View Post
lost a little bit, topped off with distilled water and havent had a issue yet
I just brought mine to the dealer and they added BMW coolant and pressure tested for leaks free of charge. Even got a loaner for a few hours.
      03-31-2017, 08:56 AM   #43
Cruz28/40
Cruz28/40's Avatar
As I've said before those that had there coolant drop low once and then refilled is not an indication of a problem as the bmw dealers here in Germany are telling me that due to the design of our systems it may not get filled all the way from from the factory and may need a top off after some miles have been driven.
2016 328i (wife's)
      03-31-2017, 09:36 AM   #44
kern417
Drives: 2018 440i
people keep posting this but how does that make sense? if your oil was low after 4000 miles, would you just assume that they didn't fill it all the way at the factory? not to mention multiple people in here have had to get it topped off more than once.
