BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > 340i b58 coolant loss
Extreme Power House
View Poll Results: Does your b58 consume coolant?
Yes 52 54.17%
No 44 45.83%
Voters: 96. You may not vote on this poll
      03-31-2017, 10:08 AM   #45
insanecoder
Drives: 340isDrive
Checked mine last nite cause you folks got me worried again..
after loosening the cap a few turns, the sweet sound of fffffffffffft pressure relief
and all levels were still at or slightly below max
I think if you check your engine after an hour after being parked
and you dont hear that pressure relief when opening your cap
and notice low coolant levels
maybe you should consider a trip to the dealership for a new cap
      03-31-2017, 11:49 AM   #46
Cruz28/40
Cruz28/40's Avatar
Drives: 2017 340i w/ MPPSK
Originally Posted by kern417
Originally Posted by Cruz28/40 View Post
As I've said before those that had there coolant drop low once and then refilled is not an indication of a problem as the bmw dealers here in Germany are telling me that due to the design of our systems it may not get filled all the way from from the factory and may need a top off after some miles have been driven.
people keep posting this but how does that make sense? if your oil was low after 4000 miles, would you just assume that they didn't fill it all the way at the factory? not to mention multiple people in here have had to get it topped off more than once.
It makes perfect sense if you think about the procedure for filling coolant you usually have to fill it to max, run the engine up to temp and then check it again after the engine cools off. Sometimes it takes more than one cycle of doing that before you don't see the coolant level dropping anymore. I doubt they are taking the time to do it more than once at the factory and so some, myself included are needing a top off and then it's good. I never said this applies to those that are seeing a coolant loss after topping it off more than once. In that case I say see the dealer.
2017 340i w/ MPPSK & Many M Performance Parts
2016 328i (wife's)
      03-31-2017, 02:47 PM   #47
kern417
Cheapskate
Drives: 2018 440i / 2010 X5
you can't just say you "doubt" they do that. the implications are significant. you'd have cars overheating, blowing radiators/radiator hoses, blowing head gaskets...you just can't assume an oem would give you a vehicle with that risk up in the air.
that being said, the procedure you mentioned may be how you fill it up in your driveway for cheap, but OEMs use a vacuum filling tool to push coolant past the thermostat and make sure the system is full at the factory. most if not all sell the tool to dealerships and they fill your coolant the same way.
      03-31-2017, 03:42 PM   #48
Cruz28/40
Cruz28/40's Avatar
Ok, I say that I doubt that because they don't have the time to run every build serveral times. Talk to your dealer or for quick reference check out a factory video on YouTube and you'll see what I mean. They fill up all the liquids, test the engine... everything checks out then they move it out. Customer gets the car after everything is settled and puts some miles on it and then it's not unthinkable that the whole system didn't get enough fliud from the factory so it ends up showing low after miles are put on it.
2016 328i (wife's)
      03-31-2017, 05:28 PM   #49
jparnes1
jparnes1's Avatar
Drives: 2016 340i, 2012 Z4 35i
Not only that, but the TIS instructs you to run the bleed cycle to further purge air, if any, left in the system.
2016 340i XDrive, EBII/black, 6 MT, M Sport, Track Handling, Cold Weather, Tech, Lighting, Driver Assistance Plus.
2012 Z4 35i, ED 2/24/2012, Melbourne Red Metallic, Black Leather, Carbon Trim, 6MT, M Sport, CW, PP, PS, NAV, CA.
      03-31-2017, 09:19 PM   #50
kern417
Cheapskate
it really is. i don't hear about it being an issue for any other model/brand, so it doesn't make sense to assume that any fluid that the engine needs to run properly would be low from the factory. and if it was, it would be be known within the first 1000 miles of driving the car.
not to mention that bmw has engineers that focus on reducing warranty spending, and they view all of these simple fill ups as an expense that should be avoided. so no one on their end is writing this off as something that can be expected.
what does make sense to me is that bmw created a new engine with a new cooling system and one of the parts has a design/manufacturing flaw that becomes obvious within the first year.
      04-01-2017, 12:52 AM   #51
STR8-6IX
Drives: RWD 528i N52
Originally Posted by High Flier View Post
I had a low coolant light around 3000 miles, with some evidence of coolant leaking around the cap. May have been high pressure due to low coolant? The dealer topped it off and gave me some extra coolant to take home and top it off after the engine cooled down...yes it's lower when cooler. I do have to top it off every 1000 miles or so, but check it regularly now before the light come on.
Low coolant does not equate to higher pressure.
The difference between low and high mark on the reservoir is 250ml. The coolant light only comes on when you are over 3L low on coolant, meaning you neglected to check and top up coolant for far too long. Also, coolant level is only accurate when engine is cold so be sure to top up then.
      04-01-2017, 12:56 AM   #52
STR8-6IX
You only get an accurate reading when the engine is cold. Coolant reads higher then actual when engine is warm.
My cap is 100% sealed, makes the pressure sound even an hour after opening the reservoir yet my car drinks coolant like an alcoholic. If there are no leaks and coolant is not being burnt due to a faulty head gasket, the only real culprit is your cap which usually should not be the case.
Looks like this will simply remain as a mystery..
      04-01-2017, 02:51 AM   #53
Cruz28/40
Cruz28/40's Avatar
Wonder if the any of the 140i or 240i cars have issues with the coolant and we'll have to wait and see about the 540. I'm not sure I would say design flaw until we see that large number of people are experiencing this. I would be interested in knowing how many have reported to dealers but I dunno if that can be found. I have only had to top mines off once as it went slightly below the min line and I had the dealer pressure test and all was good. I'll have to ask my German friend who has almost 50K on his 340ix if he's had to add coolant.
      04-01-2017, 12:25 PM   #54
kern417
Cheapskate
one of the links i posted is from the 2addicts forum. but i agree more likely a manufacturing flaw if it's the cap. the stuff isn't that difficult overall but imo someone is messing up.
      04-01-2017, 12:40 PM   #55
insanecoder
Drives: 340isDrive
The plot thickens.. sheesh so its not just the cap ?
Then its maybe the same 335 egr issues
that or hopefully its not that cheap plastic waterpump
      04-03-2017, 01:08 PM   #56
XRAVE
Member
XRAVE's Avatar
365
Drives: 135i
Had to fill up the tank twice before it stabilized at the max line. First fill was well below the min line, all in all I used ~750ml of distilled water. Not sure what that brings my ratio to.
I'll keep an eye on it. If it came full from factory, I'm losing ~125ml for every 1000 miles.
Previous: 2013 135i Space Grey w/Coral Red | 6 Speed MT | M Pkg | JB4 | AA Downpipes | AA Exhaust |
Previous: 2015 M3, BSM[/SO/CF | DCT | Adaptive M | 19" Black | CF Roof |
Current: 2016 340i, BSM w/Coral Red 18" Grey | 6MT | M Pkg | Track Pckg | MPE | JB+
      04-03-2017, 01:25 PM   #57
hollandog
hollandog's Avatar
Drives: F30
2016 BMW 340i  [4.50]
topped up twice before at around 3000 and 5000 miles. now at 9800 miles coolant still at max. I guess like the other poster said it took couple top ups to fully flush the system.
      04-03-2017, 02:39 PM   #58
STR8-6IX
the system is about 6-7L. you're fine for now in terms of the ratio.
      04-28-2017, 12:10 PM   #59
Buzzo
Drives: MT 244'80 V70R'07 340x'16
Had to top off around 9K and today again at 18K. Not enough coolant loss for the warning light to come on.
      04-28-2017, 12:19 PM   #60
BEAR-AvHistory
2018 440M-Sport MPPSK/THP
BEAR-AvHistory's Avatar
359
Drives: 2018 440M-Sport MPPSK/THP
If there is no sign of leakage could be as simple as they are not properly burping the engines to get all the air out of the system.
Kevin
2018 440M-Sport MPPSK/THP - 2017 CX-5 - 2016 Genesis R-Spec Coupe 6MT - 2013 135is Cab 6MT/JB4 - 2009 V-Star - 2009 Expedition 4X4 - 1998 Ranger 4X4 5MT - 1965 Cobra MK-IV 5MT BUILD LOG
      05-30-2017, 09:01 PM   #61
x5mad
x5mad's Avatar
88
Drives: F30 340i
Mine has had no coolant issues as of 7k km. I wonder if it's just the early cars. My build date is October 2016.
Do we have to mix with water? What would be pros cons of say filling with 100% coolant? Also the dealer told me tap water is fine and stated on the bottle. Any problems using tap water to mix?
      05-30-2017, 09:57 PM   #62
goj
goj's Avatar
Drives: 2016 EBII 340i 6-MT
My first issue was at 7700 miles so you're not quite at that yet. Your best bet is to let it sit over night and open the cap and look at the indicators inside
BMW CCA Member #516012
2016 340i, Estoril Blue, Manual Transmission
      05-30-2017, 10:42 PM   #63
CIRCLING THE DRAIN
CIRCLING THE DRAIN's Avatar
Drives: 16' AW 340i xDrive
I've said this before and I'll say it again........if you're loosing coolant something is wrong! Once properly filled and purged you should never need any additional coolant in a street car no matter how hard you drive.
If you do need coolant something is leaking somewhere or the car is overheating at some point and venting (very abnormal for a street car)
I have owned street cars, race cars, street bikes and race bikes, I never had to add any coolimg system fluids unless the machine overheated or something was leaking(gasket, joint, seal, hose, radiator, etc.)
Aslo, with the suggestion about coolant concentration being an issue I find that very hard to believe since many race engines operate with water and water wetter, no coolant. They dont blow up or require constant addition of water.
I would say that if my bmw required frequent coolant top ups and they try to convince me that this is normal, i would be very pissed.
Sorry to all those that have this issue but this is just my take on it.
M Perf Muffler w/front resonator delete | RW Carbon (CF Rear M3 Spoiler, CF Mirror Caps) | MPerf replica front splitter | CF Vinyl Wrapped Interior Bits | MPerf running board decal | BMW Mudflaps ( it snows alot here) | Bimmertech Comfort Access | Dinan Springs & B-stops | Dinatronics Sport | Hitch |
      05-31-2017, 07:47 AM   #64
kern417
Cheapskate
do not use tap and do not put 100% coolant. distilled water has the properties that make it work efficiently without damaging or corroding your cooling system. remember water is the primary working agent. Coolant just expands it's operating temp range (hence the name ANTI-FREEZE )
      07-12-2017, 10:42 AM   #65
XRAVE
Member
XRAVE's Avatar
365
Drives: 135i
Update from my last post 3 months ago.
I had to add about ~300ml of distilled water again. I'm still loosing about 100-125ml a month. I'm going to take it this Friday to get it checked out because I've never seen anything like this. Inter-cooler tank has remained at max since day 1.
      07-12-2017, 12:04 PM   #66
bimmer456
Drives: 340i
I only had to add coolant the one time after the 1st service. Maybe it was underfilled at the factory, but haven't had to add anything since. Added coolant at 8K miles and now at 19K haven't added anything, maybe they topped it up at the last service.
