04-17-2017, 11:02 AM | #1 |
Rep 942
Bluetooth calls on handset not car?
I think since iOs 10.3, most of the time when I dial from the car, the call is just on the handset; I then have to grab the handset from the armrest and change to Bluetooth.
Is this just me? Bluetooth is upto date, iPhone 6S is upto date, its a real PITA!
2016 F80 M3
04-17-2017, 12:10 PM | #3 |
Rep 536
Drives: 2013 335xi Alpine White
Sometime you have hiccups with Bluetooth. Try deleting the pairing of the phone from the car and redoing the connection. You may need to delete the pairing from the phone as well
04-17-2017, 12:11 PM | #4 |
Rep 942
It connects just fine, I can access the phone and everything, but when I actually make a call the audio is on the handset, not through the car.
If I pick up the handset and switch the source then its fine.
2016 F80 M3
04-17-2017, 12:25 PM | #5 | |
Rep 536
Otherwise it's a bad update of iOS and you'll have to speak to Apple about that. |
04-17-2017, 03:11 PM | #7 |
Rep 10
Drives: 2013 Active Hybrid 3
I've been having the same issue. I've had to switch the call back over to BT in order for the car to take the call back over.
I'll try re-paring the phone to see if that clears it up. |
04-17-2017, 04:29 PM | #8 | |
Rep 106
Did you find a fix? I have tried deleting and repairing multiple times did not fix the issue.
2014 BMW 428i xDrive M-Sport
04-17-2017, 06:18 PM | #9 |
Rep 106
Just tested it with my Bluetooth headphones and it does the same thing. It's definitely a IOS issue.
Has anyone contacted Apple?
05-16-2017, 09:43 AM | #10 |
Rep 43
Bump...anyone have any updates on this or additional input? I'm experiencing the same symptoms.
Phone pairs fine when car starts up. When receiving phone calls, if I press the button on my steering wheel, I can't hear the other person through my car. If I make outgoing calls from my car's interface, same thing. Can't hear the person through my car. |
05-16-2017, 10:55 AM | #11 |
Rep 942
Sorry, I never posted the resolution:
Deleted all Bluetooth devices, added the phone back, and all sorted. Also responds much quicker to answering too.
2016 F80 M3
05-16-2017, 12:59 PM | #12 |
Rep 3
I have the same issue. No audio when answering or placing a call.
Had to take out phone and change audio to phone. If you change it back to the car it works fine. This only happens on the first call made or received. Was at dealer Saturday and talked to the Genius about it. We deleted and re-paired the phone and it was the same. He said it is a known issue and is related to the last IOS update. They are trying fix it, but nothing to date. |
05-16-2017, 03:13 PM | #13 |
Rep 938
Another one here with the same problem. Massive pain in the arse and since 10.3.
I'll try the repairing idea....
Current car: 2017 BMW G30 520d M-Sport, BMW F46 218d Grand Tourer
Previous cars: 1989 BMW E30 316i, 1998 BMW E36 323i Coupe M Sport, 2009 BMW E87 116d, 2013 BMW F31 320d M-Sport |
05-17-2017, 02:32 AM | #14 |
Rep 942
For what it's worth, I didn't just delete & repair.
I deleted all Bluetooth devices from the car. I also deleted my car from the Bluetooth menu on my phone. Restarted the head unit (hold down vol knob for AGES) Repaired.
2016 F80 M3
05-17-2017, 12:51 PM | #15 |
Rep 1,739
Too late..I was going to suggest exactly this. iOS will sometimes get confused when you have multiple bluetooth pairings saved. When in doubt, delete all pairings and start fresh.
08-08-2017, 10:26 AM | #16 |
Rep 56
So I did the NBT Retrofit, and I can get the phone to pair, sound to come through, but I cannot get the MIC to work. Havent been able to figure that one out yet.
08-24-2017, 08:00 AM | #17 |
Rep 13
I have the same problem with iPhone 6S and 7, both at iOS 10.3.3. BMW HU and BT software is also two months old.
Tried clean setup but no luck. BMW or Apple should look into this because it is a serious issue for driving safety. |
08-25-2017, 09:19 AM | #18 |
Rep 8,942
Mine goes with however I initiate the call - so through idrive car through phone phone. Which I actually prefer. Same for answering.
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
08-29-2017, 12:05 PM | #20 |
Rep 40
Drives: F30 330e
The solution for me was to have just one phone paired in the car, if i add another phone even if its not connected will route audio to connected phone instead of the car Bluetooth.
beanbaguk455.50 |
