BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Another Stock N55 Charge Pipe Failure
      07-27-2017, 11:35 AM   #1
Polo08816
Drives: 2014 335i M Sport
Well, folks, I have now experienced the dreaded charge pipe failure...
The car in question is my 2014 335i M Sport RWD with SAT. It has approximately 78,500 miles on it and I did purchase the BMW Extended Warranty Platinum for 5years/100,000 miles. The only modifications are M Performance Suspension Kit, M Performance Limited Slip Differential, F8X M3/M4 brake pads, and APEX ARC-8 + Michelin PSS 255/40/18 all around. The powertrain has remained completely bone stock for the entire life of the car. No tunes, piggybacks, downpipes, intakes, etc.
It failed around ~7:30 in the video below which was taken at Summit Point, WV during an HPDE:
Here's a picture of the cracked charge pipe:
I'm thinking that because the charge pipe is plastic, it will withstand stock boost pressures initially. But after age and repetitive heat cycles, the plastic becomes brittle and is prone to failure right where it connects to the throttle body.
I was able to duct tape it and drive it to a BMW dealership in Eco Pro mode after that failure.
The Service Advisor said that because the powertrain is stock, this failure would be covered under my extended warranty.
Here's what it looks like after the repair work:
The service advisor said that this was the 3rd stock N55 to come in this week with a cracked charge pipe. The other two vehicles had cracked charge pipes around 35,000 miles and 50,000 miles.
I'm curious if we're going to be headed to recall...
I've attached a ISTA ISTAD Charge Pipe PDF as a reference in case you may want to upgrade to an aftermarket charge pipe. My plan is to run the original plastic BMW charge pipe until the extended warranty has run out.
File Type: pdf ISTA ISTAD Charge Pipe DIY Reference Version 1.pdf (2.88 MB, 190 views)
      07-27-2017, 11:44 AM   #2
Zel335
Zel335's Avatar
75
Drives: 2012 335I Sport
Most likely not, being these cars have been out since 2012. It's more limited to the people that drive the cars hard, and if you look whom buys these that doesn't happen that often.
      07-27-2017, 11:47 AM   #3
jgoens
jgoens's Avatar
3119
Drives: 2013 335i msport
Because tracking. Time for: tunes, piggybacks, downpipes, intakes, etc.
I think you said you were against that stuff a while ago, but time to go to the dark side and get a metal pipe.
Nice vid by the way--looks like fun.
2013 335i Msport Black sapphire/Coral red. JB4. VRSF DP, ER CP, Dinan Shockware. VRSF 12mm/15mm spacers. Cobra dashcam. Various codings.
Last car: 2011 335i Msport. JB4. Vrsf CP
      07-27-2017, 11:54 AM   #4
Polo08816
I'm going to stay away from tunes, downpipes, intakes, etc. while I'm under warranty. Tracking the car is one of the most stressful conditions for the car and once you start adding powertrain modifications, other weak points start to show rather quickly. If I need that much power, I need to just bite the bullet and buy an M2 or M3.
I may consider the metal pipe post warranty period unless BMW revises the charge pipe and starts selling an improved OEM version.
      07-27-2017, 11:57 AM   #5
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
Well, think of it like this. You'll never own the car when itbreaches 150k miles so you'll probably never replace it again.
Water pumps and hoses on the other hand.
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line
      07-27-2017, 12:00 PM   #6
Polo08816
I'm confident that BMW has calibrated everything in the car to fail spectacularly at 101,000 miles - just outside my extended warranty coverage.
F32Fleet843.50
zinner302.00
Aatish3317.00
      07-27-2017, 12:18 PM   #7
E90 LCI
E90 LCI's Avatar
Drives: '13 EBII 335i Bootmod3
Send a message via Skype™ to E90 LCI
My stock chargepipe cracked with no mods at 35k miles
Polo08816890.50
      07-27-2017, 04:46 PM   #8
mike@x-ph.com
mike@x-ph.com's Avatar
Drives: 2007 e92 335i / 2013 F30 328
Glad your car is under warranty
Polo08816890.50
      07-27-2017, 04:57 PM   #9
Polo08816
Me as well.
I used to drive it Monday to Friday but now I have a work car. The remaining 21,000 miles on the warranty are going to be some hard miles at the track.
      07-27-2017, 05:40 PM   #10
zinner
zinner's Avatar
302
Drives: 2015 335i Msport
congrats on going solo!!!
Polo08816890.50
      07-27-2017, 06:03 PM   #11
trohde78
trohde78's Avatar
Drives: 2017 Camaro 2SS 6MT
It's pretty sad that they will crack on a stock vehicle. They could at least reinforce that connection point since they had plenty of experience with this issue on the N54 as well.
Polo08816890.50
      07-27-2017, 07:13 PM   #12
Muwiee
Muwiee
Muwiee's Avatar
Drives: 07 335i '12 335i
2012 BMW/335i  [0.00]
Had same issue in Sunday. My car is totally stock. I got aftermarket pipe and waiting to see if the warranty will cover the price of the pipe. I went with the FTP from Bavauto. Broke in two spots. Right around connection to throttle body and also where vacuum line connects.
      07-28-2017, 04:54 PM   #13
BMW DIY Guy
Drives: 2014 435i
I have a spare OEM pipe in good condition if anyone is interested.. *grin* (the Active Autowerke upgrade is installed!)
      07-28-2017, 05:31 PM   #14
LiquidMercury
Drives: 2012 F30
Not so sure your warranty would cover you going out and buying a better part and them reimbursing you for it. unless it's exactly the same cost as stock?
      07-28-2017, 06:19 PM   #15
Muwiee
Muwiee
Muwiee's Avatar
I called them and they said unless a BMW dealership did work thy won't cover it. Even if I had bought the crappy OEM plenum.
      11-03-2017, 09:38 AM   #16
Anshu
Anshu's Avatar
73
Drives: '13 F30 335i
My stock charge pipe blew up on Wednesday. Never had a tune, no aftermarket mods other than suspension and muffler swap.
United BMW Roswell wants $755 to replace it because my factory warranty expired (I'm at 50,700 miles) and CPO "does not cover it"....
Going to make a fuss if the manager doesn't end up covering this. This is total bullshit.
      11-03-2017, 09:42 AM   #17
yoandry
yoandry's Avatar
Drives: 13 F30 335i & JGC
Send a message via AIM to yoandry Send a message via MSN to yoandry
CPO should cover that, otherwise tell them to show you in writing where does CPO warranty says it doesn't cover.
If not get the VRSF for $225 i think and do it yourself.
PS2+ WMI + MHD Bef+JB4, VRSF DP, CP, FMIC Race 6, AFE Mtum Intake, MPPK, MPE, MP-Susp, MP-Brakes, 437M, MP-interior trim, MP-Alcantara Steering Wheels W/race display, MP-Lip, MP-Diffuser, MP-Spoiler, MP-Rocker Panel, MP-Sills, MP-Pedals, MP-Grille, MP-Mats.
      11-03-2017, 09:56 AM   #18
Anshu
Anshu's Avatar
73
There saying that its a normal wear and tear item and I said its part of the turbo induction system and the manager blew it off basically.
Think I'm going to just go aftermarket at this point. Does the VRSF still have fitment issues?
      11-03-2017, 10:00 AM   #19
jgoens
jgoens's Avatar
3119
And then put a tune and DP on and your good to go.
Anshu73.00
      11-03-2017, 10:22 AM   #20
ronanz
Gettin It Figured Out
ronanz's Avatar
Drives: '14 435i FBO ACF S2
ER is another option...OEM fitment
My Build Thread can be found HERE
      11-03-2017, 10:30 AM   #21
enjoythemusic
enjoythemusic's Avatar
245
Drives: 2014 BMW 435i Dinan Stage 4
Sadly, welcome to the 'club'. Yeah, the CP blew on the 2014 435i earlier this year and she had around 28k miles on her. To be fair, the car had Dinan Stage 2 at the time so nothing crazy yet a nice improvement over stock. Frankly, get the ER CP and be done with it. JMHO YMMV
Enjoy the Drive,
Steven
2014 435i M-Opt, M LSD, Dinan CAI/IC/BTurbo/Stage 4, ER TIC/CP, GFB DV+ & Mich PS4S.
kabrichx116.00
      11-03-2017, 10:37 AM   #22
BMW DIY Guy
Drives: 2014 435i
No doubt super frustrating, but yeah, welcome to the improved CP club! I am a big fan of the Active Autowerke CP, and my DIY video can help you through the install. (Or probably any other brand as well)
Sorry for the crappy experience but thankfully you are a relatively easy fix.
I on the other hand wont be driving my car for a week.. literally. I have roughly 600 miles left on my warranty and after a full inspection by my independent shop, have a laundry list of little things for the dealer to fix. The earliest date possible? A week out... no driving for me! *laugh*
Check out my DIY Channel on YouTube!
F32, F80, E39, E46, E53, and E83 projects from Pro Auto Motion, Active Autowerke, AvinUSA, Karbonius Composites, Ignition Projects, Go Fast Bits and more!
** BMW DIY Guy **
