BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > Centre cap removal/refitting
European Auto Source
      08-11-2017, 12:54 PM   #1
MrChumley
Drives: F33 440i convertible
I've just noticed that one of my wheel centre caps is misaligned. Being as how I've got terrible CDO I want to straighten it up.
Can anyone advise the best way to get it off and back on without damaging it or the wheel please?
A quick Google suggests either duct tape (would that take the paint off?) or a screwdriver wrapped in cloth. I'd be interested to hear from anyone who's actually done it successfully.
      08-11-2017, 12:58 PM   #2
LiquidMercury
Drives: 2012 F30
Well, if you're truly OCD, you'll take the wheel off and pop it off from the inside of the wheel pushing outside.
Me, I'd use a butter knife wrapped in a cloth, pry it from the outside and it'll pop right out. Or a plastic pry tool will do preferably of course.
      08-11-2017, 01:05 PM   #3
greatbm
Drives: F33 428i M-Sport convertible
duct tape is fine just make sure applied very firmly to most of the face of the centre cap and give it a good yank it will come off with no damage.
F33, 428i M Sport, Moonstone individual, cashmere beige
      08-11-2017, 01:17 PM   #4
MrChumley
Thanks for the replies. I'm a bit of clumsy twunt so I'll probably give the duct tape a try.
      08-11-2017, 01:36 PM   #5
ronime
Attention-seeking whore
Drives: BMW 320i xDrive M Sport
Suction cup/rubber sucker type of thing as found on windscreen mounts for portable sat navs and phones.
BMW 320i xDrive ///M Sport
      08-11-2017, 01:46 PM   #6
MrChumley
Thanks, interesting suggestion. I think I've got one at the back of the man cave somewhere. Have you done it successfully yourself?
      08-11-2017, 02:02 PM   #7
ronime
Yes I have. Do be prepared to be surprised and disappointed at the amount of rust on the spigot in the centre of the hub though.
      08-11-2017, 02:04 PM   #8
MrChumley
Thanks, I'm not worried about that - as long as it stays there.
      08-11-2017, 02:19 PM   #9
dubdemand
Drives: 330d M Sport Touring
Sucker is definately a good option but they do tend to slip out of alignment again quite quickly though...
LCI F31 330d Sport Auto: MG with saddle brown interior, MS+, adaptive LED, pro media, comfort pack, heated seats/wheel, speed limit display, HUD and reverse assist camera
      08-11-2017, 02:38 PM   #10
MrChumley
Oh well, I'll give it a go. It's just been off for a minor repair so I guess the guy didn't put it back straight. All the others are more or less right.
      08-11-2017, 03:42 PM   #11
sensible
sensible's Avatar
110
Drives: BMW 320i M-Sport
We have a suction cup for removing the halogen GU10 lights. That works perfect.
      08-11-2017, 03:56 PM   #12
LiquidMercury
Drives: 2012 F30
Ask the missus to get down there. Easy peasy.
      08-11-2017, 06:55 PM   #13
Hugrov
Drives: F30 LCI
Sucker cup for removing GU10 halogen bulbs as previously mentioned, it works a treat. Got mine off eBay for around 4, I do remove the centre caps every now and again to clean and dry inside the wheel to try to keep the inevitable corrosion at bay!!
      08-12-2017, 02:24 AM   #14
Tux
I bought and use this:
Small MR16 Black Sucker - Suction Pad for Removal of GU10 and Halogen Lamps - Bulb Remover Tool https://www.amazon.co.uk/dp/B008HSPL..._C8PJzbW9ZT2PA
      08-12-2017, 05:18 AM   #15
Rhino at Work
Rhino at Work's Avatar
141
Drives: EB F30 340i Shadow Edition
If you ever need to explain the concept of first world problems to anyone then look no further than this thread. 😀
      08-12-2017, 02:09 PM   #16
onstat
Wales
22
Drives: 335d Touring
They've got the gu10 removers like these in Wilkos for 2 and they work perfectly on mine.
F31 335d M Sport | Estoril Blue & CR | M Sport+ | Pro Nav | Comfort Pack | Adaptive M Sport suspension | Active Cruise
      08-12-2017, 03:53 PM   #17
MrChumley
I couldn't find a sucker pad in the end and I couldn't be bothered to go shopping, so I used duct tape. Worked a treat.Thanks again for all the suggestions.
      08-16-2017, 05:31 PM   #18
greatbm
Just bought same from screwfix 2.99. Tried and works no problem, my previous method was duck tape this tool is much easier.
      10-05-2017, 11:29 AM   #19
John in VA
Drives: '13 328i xDrive
MrChumley, how often do you find you need to re-position the centre caps? Some of mine rotate on a daily basis.
_______________________________________________
2013 BMW 328i xDrive in Orion Silver/Venetian Beige - Premium & Cold Weather Packages, Navigation System
      10-05-2017, 01:12 PM   #20
Drek
Drek's Avatar
Nigeria
301
Drives: 2015 335d xDrive F31
It can't be that bad..
F31 335d with stuff.
R1100S for two-wheeled japes.
XWV40
      10-05-2017, 01:23 PM   #21
MrChumley
I just did it once, after the wheel had been off. It's been fine since.
      10-05-2017, 01:24 PM   #22
MrChumley
The wheel or my CDO?
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
