BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > USA - California > SoCal dealers willing to fix squeaky MSport brakes
European Auto Source
      08-27-2017, 04:40 PM   #1
wickedwahine11
Drives: AW 428i M Sport convertible
As many of you with MSport blue brakes know, not only do they create massive amounts of dust, they are incredibly screechy at slow stops. I took my car into South Bay BMW to get them repaired, and was armed with the TSB bulletins showing the BMW instructions of chamfering, etc. They did chamfer the pads, and it became a little less frequent but has not stopped.
I took the car in for a different issue this week and spoke with a different service advisor and foreman. Both were very nice, but also gave me the standard "high performance brakes do this."
Has anyone had any success at getting these brakes or pads repaired or replaced with a permanent solution by a SoCal BMW dealer? I am at my wit's end over this, like nails on a chalk board, it irritates the hell out of me. I am resigned to getting ceramic pads when the free maintenance wears out, but not sure I can stomach another year of these screeches. It has gotten to the point where I even named my car "Kreischen," German for screech.
I live in San Pedro but will go as far north as the Valley to get this fixed if anyone knows a SA that will do the job. Anyone?
2014 F33 BMW 428i convertible - Alpine White on Black Dakota leather - M Sport Package - Technology Package - Cold Weather Package - Driving Assistance Package - Premium Package - Harmon Kardon sound system - Lighting Package
      08-28-2017, 03:27 PM   #2
lazyme4evr
Drives: 2015 435i
Bump. Same issue here as well!
      08-30-2017, 11:41 AM   #3
Charlie@McKennaBMWService
Charlie@McKennaBMWService's Avatar
Drives: 16 BSM F80 M3 & 15 AW F23 M235
2016 BMW M3  [0.00]
2015 BMW M235  [0.00]
2013 BMW M3  [0.00]
2008 BMW M3  [0.00]
2006 Subaru STI  [0.00]
Well as a manager of a service department myself, I can tell you first hand that I experience this same particular issue all the time with both my 2016 F80 M3 and my 2015 F23 M235. Unfortunately to be completely honest there is no permanent remedy to resolve the issue with brake dust or squeaky brakes, my only advice would be to keep your vehicle/brakes clean relatively often. On average I wash my vehicles once a week and at times will use the spray on chemical solvent that cleans & eats away at all the brake dust and it seems to help a lot. Another option would be to opt out and replace your pads with aftermarket ones(ex: StopTech sport/street pads) but something like this may create warranty related issues where you service your vehicle so proceed at your own risk.
Instagram: cboy1
      12-09-2017, 03:20 PM   #4
StockLOL
Drives: 2018 340i MPPSK
Charlie do you spray the solvent directly on the brakes? I have a 340 coming with big brakes and will be trying this is the squeaking is bad. How bad is it? Can you hear from inside car?
Also is McKenna a Dinan dealer? Would you guys install Dinantronics?
      12-10-2017, 09:49 PM   #5
2016 BMW M3  [0.00]
2013 BMW M3  [0.00]
2008 BMW M3  [0.00]
Correct, a lot of big name detailer companies make touchless wheel cleaner sprays which seems to help a lot. Again, if used often it should help diminish the brake squeak noise by a lot.
Yes we are a Dinan authorized dealer.
Instagram: cboy1
      01-03-2018, 02:52 PM   #6
madrrio
Drives: 335i m sport
i believe my sound wasnt exactly the brakes, but the rotor lip along the outside where the brake pad didnt wear out and would ride along.. it would cause the noise at any braking pressure.
      01-05-2018, 04:44 PM   #7
Radmobile
Drives: 2014 435i & 228i
If your rotor is developing a lip then you might be able to get a service department to replace the rotor as that's a tell tale sign that you're due for rotors.
Most if not all BMW service departments now have axle mounted lathe machines to turn the rotors. When customers go in needing new brakes, more often than not it's just new pads and they resurface the rotors. The axle mounted lathes don't require the tech to remove the rotors so it's far more cost effective for them to resurface the rotors than replace them. That is unless you're developing a lip at the rotor's edge. At which point you may need them replaced.
2014 BMW 435i M-sport (alpine white/black)
2014 BMW 228i (alpine white/black, slicktop)
1999 BMW M3 (titanium silver/dove grey) - sold
      01-07-2018, 04:34 AM   #8
upsidedownfunnel
Drives: 2014 335i Sport 6MT
It really depends on how bad it is. Some people are just unrealistic on how much noise the brakes should make.
If it bothers you a lot, you can get quiet pads like the Centric Posiquiet. They really do work but you'll lose a bit of performance.
https://www.turnermotorsport.com/BMW...lic-brake-pads
      01-12-2018, 02:14 AM   #9
RonDeezy
RonDeezy's Avatar
Philippines
Drives: 2015 335I M-Sport
I just went in for service this week and had my squeaky M brakes taken care of. They found excessive pad material on front and rear pads. They went ahead and chamfered/cleaned the pads. So far so good and I haven't heard them squeak again. I had my service done at Bob Smith BMW in Calabasas. Ash Lumian was my service advisor. Cool SA who will address all your concerns!
Current: 2015 F30 335I M-Sport | Alpine White | Gloss Black Grills | Gloss Black Roof Wrap | H&R Sport Springs | SoCal F3X Member |
Previous:2012 E92 335I M-Sport | Black Sapphire | Coral Red | Gloss Black Kidney Grille | BMS Intake | Custom Muffler Delete
