Bimmerpost for iPhone and Android have just been updated with a host of bug fixes. If you've ever had trouble logging into it in the past, give it a try now!
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Overly Reactive Steering?
VIBE Motorsports
      09-05-2017, 03:52 AM   #1
Mountain_Commando
Mountain_Commando's Avatar
Australia
71
Drives: 435i Gran Coupe M-Sport
Hi guys,
My previous bimmer was a 2013 328i with sportsline package. The steering on that car was rock solid stable. It would track straight like an arrow regardless of the road texture or tilt.
My current bimmer is a 2014 435i with M-Sport package. For some reason, the steering on this car seems to react to any deviations from fully flat surfaces of the road. Meaning if the road surface is grooved or tilted, the steering seems to want to move into the same direction as the groove/tilt, to the point that I have to fight the steering to keep it going straight. This is especially annoying on bad roads, because the steering reacts unpredictably, like it has a mind of its own. This happens regardless of whether I'm in Comfort mode or Sports/Sports+ modes.
Is this normal? I had thought that M-Sport package would have an even more stable steering than sportsline?
435i Gran Coupe | ///M Sport Pkg | 430hp | MHD Stage 2+ | BMS Intake | Catless Downpipe | FMIC | Black Sapphire exterior | 9H Ceramic Coating | Black Anthracite interior | 19" Black ///M Wheels | Red ///M Brake Calipers | Alcantara ///M Steering wheel | ///M Metal Pedals | Alcantara dash panel | Carbon Fiber trims and gear knob | Angel Eyes LEDs | Surround Cameras | Spoiler | Coded ///M iDrive, Mirrors, HUD |
      09-05-2017, 04:20 AM   #2
jmg
jmg's Avatar
Drives: 2016 F80 M3, i3 REx
It's called tramlining and every car has it to some extent. Having had a 2013 328i with the sport suspension in the past, I can say that I didn't witness any significant tramlining, so it's not inherent to the car itself. It's either your tires or your suspension.
More info here:
https://m.tirerack.com/tires/tiretec....jsp?techid=47
I have noticed in my current car that there was more tramlining when my non RFT Conti CS5 were wearing down near their limits which was greatly reduced with new tires. How old are your tires and how much tread do you have left?
Old and worn suspension components can also effect tramlining and your car is just about that age to start replacing worn parts.
F80 ///M3
i3 REx Giga World
Previous: F30 340i M Sport ZTR F30 328i Sport Audi B7 S4 25Quattro #33 of 250
      09-05-2017, 04:43 AM   #3
HighlandPete
Drives: BMW F11 535i Touring
The Tirerack article describe the possible causes well.
Something as simple as tire setting pressure can make a difference. Many run pressures too low, run-flat tires are particularly sensitive to correct working pressure to prevent running on the sidewalls.
      09-05-2017, 08:04 AM   #4
Mountain_Commando
Australia
71
More info here:
Ah, that article explains it perfectly! My front tires are fairly worn out, thus I did suspect they were the culprits (though I didn't know why, but now I do thanks to the article).
On the suspension though, I'm only at 28,000 km (17,400 miles). Plus the suspension feels nice and stiff on fast corners whilst on Sports mode. Guess I'll start with the tires and see how that goes.
Cheers!
      09-05-2017, 11:22 AM   #5
chiefneil
Drives: 335i M Sport
I've noticed that my 2014 335i m-sport has significantly less tramlining than my 2002 330i did. In fact so far I've noticed an almost complete lack of tramlining which is a little bit eerie tbh; I still instinctively tense up and grip the wheel harder whenever I'm in one of those highway lanes with a rough pavement line passing under one wheel.
Anyway, I believe decreased tramlining was one of the reasons BMW muted steering feel in the F3x. EPS makes it easier for the engineers to dial it out.
      10-06-2017, 02:37 AM   #6
Mountain_Commando
Australia
71
More info here:
Ok I just got new front tyres (non-RFT's), and WHAT a difference! I didn't realize how much driving joy I was getting robbed off till now. Thanks for the tip!
      10-06-2017, 03:34 AM   #7
Calvin36
Calvin36's Avatar
Drives: F30 335i M Sport
More info here:
Tires are always one of the most important items to upgrade/replace! glad you figured it out!
      10-07-2017, 08:53 AM   #8
roundel335
roundel335's Avatar
Drives: 13 335i Sedan, 16 228i Cabrio
You may also want to get an alignment done when getting new front tires. You can get just the standard 2-wheel alignment or a 4-wheel alignment, but it's definitely worth it to avoid uneven tire wear and handling quirks.
2013 F30 335i M-Sport 8AT/MPE/MPPK/JB+, 2016 228i M-Sport Cabrio 8AT
      10-07-2017, 11:48 PM   #9
Mountain_Commando
Australia
71
Yes I think you're right. I was just thinking alignment would further stablize the handling.
