BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > CANADA > F32 brake fluid interval???
European Auto Source
      09-09-2017, 07:36 PM   #1
stvding
stvding's Avatar
Drives: 435xi
Idrive showing 3 years. But last visit to town+country dealership, they said 80 ish days left from end of july. So about 2 yr.
Wtf???
      09-09-2017, 08:18 PM   #2
M2Rush
Drives: 2014 BSM 335i x-drive
It should be done every two years as they tend to collect water over time but if you're on lease and don't plan on keeping then 3 years shouldn't be an issue.
However, it is safer and if it lets you sleep better at night and put your mind at ease, I'd say go for it.
This is an extreme maintenance schedule if you plan to keep for as long as possible.
https://www.bavauto.com/media/import...ages/f32mc.pdf
      09-09-2017, 08:23 PM   #3
stvding
stvding's Avatar
Drives: 435xi
Ok...I bought the car but plan on selling it sometime next year
      09-12-2017, 01:03 PM   #4
reyoasian
Drives: 340xi MPPSK
I personally do it every spring, but that's just me.
Generally every 2 years is a good rule of thumb, but may vary depending on how your pedals feel.
Brake pedal feel is very important...you don't want air bubbles to build up in the brake lines which will make your pedal feel like stepping on sponge, and you're basically pumping air with no brakes.
If it's for safety, you should do it more often as a preventive maintenance.
      09-12-2017, 05:02 PM   #5
TheUltimateDrivingManiac
Freude am Fahren.
Drives: F15 X5 xDrive35i
Every 2 years.
Freude am Fahren.
      09-14-2017, 04:21 PM   #6
Bestodabest
Drives: 2014 435i Xdrive
If you're not racing the car, and you're not in the habit of leaving your brake system open for periods of time, you can go quite some time without changing brake fluid. Its probably one of the most neglected services, and rarely does harm come of it. Most customers only perform the service when its required (new caliper, brake line, a leak, etc).
      09-14-2017, 04:26 PM   #7
stvding
stvding's Avatar
Drives: 435xi
When do i need it then? Delivered back in 2015/09/26. Almost 2 yrs flat now
      09-14-2017, 04:46 PM   #8
Bestodabest
Keep it sealed, and you probably won't need to service it until you need to change a caliper.
      09-15-2017, 02:31 PM   #9
stvding
stvding's Avatar
Drives: 435xi
I never touch it
