BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F34 3-Series GT (Gran Turismo) Forum > Eibach springs lowering mod. feedback
European Auto Source
      09-20-2017, 10:00 AM   #1
tomf34
France
Drives: F34
I was not very happy with the handling of my GT so I purchase an Eibach Pro-kit (ref E10-20-031-03-22). I keep the original dampers and only change the springs in order to keep the modification in an acceptable price range.
Without replacing the dampers by adustable ones the dampering effect is unchanged. I was a little bit afraid of the final result but the Eibach springs are shorter but also thicker than the original ones and the pairing with the original dampers gives a good result.
The lowering is moderate (-2 to -3 cm) and the resulting ground clearance is now similar to the one of the 3 serie sedan model. Speed pumpers can be cross without any second through.
The dynamic results are very good in term of lateral stability with no more lateral roll. I have the feeling that I have change from a SUV to a sedan. After realigning the wheels (you really have to have it done properly by a professionnal with a recent test bench) the car is more stable in curves. The overall confort is also not really affected by the lowering.
As a conclusion I am very happy of my "new" GT after this lowering.
      09-26-2017, 01:36 AM   #2
HaciendaPirate
Couch Potato
Sweden
Drives: F34 320d GT -14
Thanks for sharing your experience! I'm also thinking about this, if you do have som pictures before/after please upload them!
Garage:
BMW 320d GT -14
Next buy:BMW M3 E46 or E90, _OR_ Porsche 997 Carrera S
      09-30-2017, 02:42 PM   #3
HaciendaPirate
Couch Potato
Sweden
Regarding the ground clearence I found this information:
BMW F30 EfficientDynamicsEdition - 124 mm
BMW F30/F31 - 140 mm
BMW F30/F31 xDrive - 145 mm
BMW F34 - 165 mm
BMW F34 xDrive - 165 mm
So, a F34 with lowering springs is about the same as a stock F30/F31.
Reference: https://www.press.bmwgroup.com/deuts...che+daten+f34/ ("bodenfreiheit" = "ground clearance")
Garage:
BMW 320d GT -14
