BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > 2017 340ix Knocking Noise When Gas Tank is Below 1/4 Full
Vorsteiner
      09-23-2017, 11:29 PM   #23
smrtphusr
Drives: 2017 340i xDrive
Well when I posted my thread no one really cared so I took the car to the dealer and its normal sound. Just fuel pump working
http://f30.bimmerpost.com/forums/sho....php?t=1410955
      09-23-2017, 11:58 PM   #24
dsc888
Drives: 2017 340ix ///M Sport
Thank you! I did a search but your thread didn't show for some reason. But thank you for letting us know what your dealer told you and the fact that they checked another car on the lot and got the same results. I guess that will allow us to rest easier knowing it's nothing serious, although a bit annoying.
      09-24-2017, 03:09 AM   #25
eluded
2JZ-GTE
eluded's Avatar
Bulgaria
994
Drives: 340 6MT
I will listen for this noise the next time my racing light comes on (low fuel light).
      09-24-2017, 09:03 PM   #26
KGB_123_99
Drives: '17 330ix M-Sport
If BMW considers this sound is really normal...I really don?t know what to say.
      09-25-2017, 10:09 AM   #27
smrtphusr
Its only when gas tank is 1/4 full dont hear it other times
      09-25-2017, 01:41 PM   #28
bavarianride
Drives: bimmer
This is intriguing, will try to get to 1/4 tank and confirm.
      09-25-2017, 01:55 PM   #29
dsc888
I my case, you need to get to about 1/8 tank or less. Basically my noise started when the car warned me that I had less than 30 miles of fuel left.
      09-25-2017, 01:57 PM   #30
dsc888
Yup. I hear you. This noise should never occur. I have owned many cars before and none have made such a noise when the tank was low. My 2015 335ix that I traded didnít make this noise either.
      09-25-2017, 11:23 PM   #31
Kennybar112
Kennybar112's Avatar
Drives: BMW 340i xDrive
The B58 in the 340i has its quarks. I think the most worrying is the cold start warm up then engine shake after about 30 seconds. Regardless you'll go nuts chasing all these little noises that wind up always meaning nothing.
2017 340i xDrive Black Sapphire Metallic / Coral Red Fully Loaded
      10-05-2017, 04:51 PM   #32
KGB_123_99
So I got my car back from the dealer today, noise confirmed.
Unfortunately I was told that the noise is normal and is "within BMW spec", whatever that means. The noise is from the "fuel pump return".
I'll just have to turn up my radio I guess and keep the tank full.
      10-06-2017, 06:05 AM   #33
dsc888
Thank you for the update. I canít believe thatís normal but that seems to be what we will get told unless it causes drivability issues. Iíve been paying close attention and the noise can be ever so slightly heard at slightly below 1/8 full in my car. Iíve made it a point to just fill up before that point now to not hear it anymore.
      10-07-2017, 07:45 PM   #34
kern417
Cheapskate
Drives: 2018 440i / 2010 X5
i haven't experienced this on my car, but i was figuring if it was either a return or Purge valve. on volkswagens with the TSI engine, the valve is mounted to the intake manifold and sounds like marbles clanging together.
      11-14-2017, 12:54 AM   #35
Kaneda215
Drives: 2017 BMW 330i
As another data point:
I have a 2017 330i and I've noticed this too. Below 1/4 tank the knocking is pretty evident, though not as pronounced as some of the previous videos. That being said, I didn't reach under the car to record, and it was only heard in the cabin. I'm taking it in in a few days to work a separate issue and I'll report back if BMW has any fixes (although I'm sure they're going to align with the notion of it being within "within spec").
Onto other rattles and fixes that I've experienced:
I had a pretty bad rattle in the shelf behind the rear seats. The dealer applied felt tape to all the points of contact and that rattle is now nonexistent.
When I'm playing songs with any sort of bass, there's a very "ghetto" rattle that's heard from outside the car. This rattling is coming from the side skirts and the aforementioned fix did the trick as well. I'm actually taking my car in in a few days to fix the right side (wish I would have just done both when I was in last time).
      11-15-2017, 12:06 AM   #36
dsc888
Thanks for chiming in. I still have the noise but it seems less "loud" since putting 2,000 miles on the car. But it's still there below 1/8 tank BUT I've noticed that I can get it to make the noise at or below 1/2 tank for a few seconds if I come to a quick stop. I'm guessing the gas sloshed forward and thereby creating an low fuel load in the tank momentarily.
I'm still curious what the actual root cause is. Is it the fuel pump? Or is it related to the tank contacting something above it with less gasoline in the tank weighing the tank down, as mentioned by roundel335? BMW might say it's "normal" but no other car I had ever had this noise. Not even the 2015 335ix I traded for this!
I wonder if other members have had BMW address their issue since I started the thread but who may not have updated us here.
      12-03-2017, 03:15 AM   #37
dsc888
Any luck with the dealer, Kaneda215?
As a side note, I have noticed that the knocking has somewhat lessened in intensity now that I've driven the car about 2,500 miles. It will still knock as the tank gets below 1/8 of a tank but it's not very loud and will sometimes not happened at all. I'm not sure it is because of the colder weather her in the Northeast.
      12-18-2017, 07:24 PM   #38
Kaneda215
My dealer said it was normal as well.
      12-18-2017, 07:47 PM   #39
htisno1
Drives: 2018 340i M Sport
Just got my 2018 340i , the knocking noise after 50 miles left . so ignore.
      12-18-2017, 11:58 PM   #40
TheBingoBalls
It's the exhaust. The sound that I hear in the cabin is consistent to whatever sound is coming from the exhaust, heard from the outside. My guess is the sound resonates through an empty fuel tank and transmits that into the cabin. With gas in the tank, I'm assuming it's enough to dampen the sound so that you can't hear it. It's definitely not the fuel tank or anything mechanical.
      12-24-2017, 04:32 AM   #41
dsc888
Thanks for the update. Looks like we are all stuck with the noise unless BMW get enough complaints to figure out a solution.
      12-24-2017, 04:33 AM   #42
dsc888
Thanks for the feedback. Let us know if it gets better with time. Mine seemed to have lessened.
      12-24-2017, 04:35 AM   #43
dsc888
I agree. Now that Iíve heard it for 3 months, Iíve come to the same conclusion. Itís just annoying. Iím just curious if they had a running change to the design of the fuel tank or the fasteners that hold it to the underside thatís resulting in the noise.
      04-07-2018, 01:55 AM   #44
vtkachen
Drives: 230 i, 2017
I have the same issue with 2017 230i. Nice small but powerful car, however when the fuel tank gets below 1/2 this embarrassing noise start coming. The lower the gas level is the more persistent the noise. I wouldn't probably make too much fuss about it if it was a ... 'Yugo, for instance', but hey, it is "Ultimate Driving Machine" for God sake.
So, I went to the dealership three times with this issue. Do not want to go into the gory details, they replace everything but fixed the problem. When I pushed on them on the third time, they finally admitted that they unable to fix the problem at this time. It is an engineering mistake, and 'Engineers' are working on the solution.
Full pants of shit! It sounds like this issue is common to BMW!
The dealership told that it is not 'life threatening', but hey, defect is in the fuel tank! What is it so extra different in BMW from the other cars!
Shall we talk to lawyers?
Vic.
