BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Do wheel spacers affect handling?
VIBE Motorsports
      10-02-2017, 09:58 AM   #1
bimmer_335
Drives: 335i Coupe
Hi
I'm thinking of getting wheels spacers for my G30 759M 20" wheels (5mm front and 10mm rears).
my question is since that alters the factory rear/front track width slightly, would that cause under or over steer or change handling of the car in anyway. Or would you suggest getting same width spacers for front/back?
Sorry had to post here since G30 forum is not as active.
Thanks!!!
      10-02-2017, 10:59 AM   #2
Rick Hunter
Skull Squadron Leader
Rick Hunter's Avatar
158
Drives: '07 M Coupé & '16 435xi GCoupé
Loaded question(s)... that is awesome. In your situation, probably minimal effect, but better aesthetics.
Here are a couple of videos that explain the the changes that happen when you modify your track:
      10-02-2017, 12:35 PM   #3
Calvin36
Calvin36's Avatar
Drives: F30 335i M Sport
Whether it oversteers or under steers should also depend on your offset as well, especially if you're tracking your car. So it'll be a combination of the widen stance plus the offset you're running. But if it's everyday driving I'd assume there will be minimal difference.
      10-02-2017, 03:20 PM   #4
KC328_F30
KC328_F30's Avatar
Drives: F30 328i xDrive
My fear of spacers has always been any kind of steering wheel vibration at higher speeds on highway...sounds like its not an issue.
      10-02-2017, 04:05 PM   #5
Calvin36
Calvin36's Avatar
As long as you have a hubcentric spacer I heard it wouldn't be a problem.
      10-02-2017, 05:35 PM   #6
mike@x-ph.com
mike@x-ph.com's Avatar
Drives: 2007 e92 335i / 2013 F30 328
Hubcentric ones with the specs you are interested in will not affect handling in your case
      10-02-2017, 05:54 PM   #7
COKen
COKen's Avatar
Drives: 2014 435i / 2002 M Roadster
Just make sure your lug bolts are the correct length for the spacers you get.
2014 435i M-Sport, Mineral Gray, Black Dakota Leather, Driver Asst Pkg, Prem Pkg, Tech Pkg, 8 Spd Sport AT, Heated Front Seats, ACC, BMW M Perf Tune w/MPE, BMW LSD, BBS CH.
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, Steel Gray Metailic HT, TC Kline DA Shocks & Camber Plates, w/H&R Springs, Stromung Exhaust, SSR Type C.
      10-02-2017, 06:37 PM   #8
bimmer_335
Drives: 335i Coupe
Her are a couple of videos that explain the the changes that happen when you modify your track:
great way to talk me out of it...
but again I asked for it so thanks!!!
      10-02-2017, 07:12 PM   #9
Calvin36
Calvin36's Avatar
You wanted no BS assessment right? : even then I'm thinking of using some.. had some 20 and 25mm spacers on my G35 and tracked it no problem.
      10-02-2017, 11:07 PM   #10
Rick Hunter
158
Haha! The intention was not to talk you into or out of it. I just wasn't able to explain the science as elegantly as the guy in the videos (which BTW his channel is pretty awesome).
Spacers are going to provide mostly aesthetic benefit, and the widths you're planning to add will make negligible difference in performance (positive or negative). So go live a little and enjoy your unique ride.
For the record, I've got 17.5mm spacers all around on my F36.
      10-03-2017, 01:28 PM   #11
bimmer_335
Drives: 335i Coupe
true that... i'm going add them. Videos were pretty awesome btw thanks once again
      10-03-2017, 03:06 PM   #12
Calvin36
Calvin36's Avatar
Love the Engineering Explained videos. Sometimes the explanations blow my mind.
      10-03-2017, 03:48 PM   #13
XutvJet
Drives: 2016 M235 6MT
I haven't added spacers to my M235, but I did add new wheels 18X8 all around vs the stock 18X7.5 and 18X8 setup. The new wheels have 10mm more offset so it's just like running 10mm spacers. What I've noticed is that the car are much more sensitive to trammeling from ruts in the road. Overall, if the road has ruts or is bumpy, the car can be more of a handful as the suspension, especially the rear, has far more tendency to steer itself. It's proof of just how design BMW considers in their suspension and how operating the suspension outside of the designed parameters can have negative consequences.
      10-05-2017, 03:44 PM   #14
bimmer_335
Drives: 335i Coupe
Did you also change the tires or are they similar? are you finding the rear coming loose... 10mm is less than 0.4 inch shift on each side.
      10-07-2017, 12:32 PM   #15
XutvJet
Tires are the stock 225/40R18 and 245/35R18 Michelin PSS tires that came on the car. I'm hopeful some of the dartiness will be corrected when I go with a square 245/35R18 setup.
I do find the car more tail happy, but I'm not sure if it's because the engine has broken in (15K miles, feels much stronger than with sub 5K miles) or I'm just more comfortable with applying more throttle and the car itself.
I want to restate that this issue is only noticed on rougher pavement, typically while the car is turning, slow speeds or highway speeds.
      10-07-2017, 10:13 PM   #16
Humdizzle
Drives: 2010 ferrari 458
the changes are so minimal that you will only notice the differences on a track.
i didn't use spacers but i did get wider VMR wheels and H&R springs. The biggest change i noticed was my MPG dropped by about 2-3. This is partly because of more tire = more friction. but also the tire is now pushed out disrupting airflow around the car.
2013 335i EBII
2010 Ferrari 458
Previous: e36 m3, e46 m3 IR/IR, FBO E85 2010 GTR, Scion FRS.
      10-08-2017, 04:09 AM   #17
JJS
New Zealand
71
Drives: BMW F31 335i 6MT M-Sport
More positive offset (which is what most modern cars run) means the wheels are further inset, whereas spacers actually reduce positive offset. Unless you actually meant your new wheels have 10mm LESS offset.
EBII 335i Touring M-Sport (Munich built July 2013)
| 6 Speed Manual | 2VF Adaptive M Suspension | 2VL Variable Sports Steering | 403M wheels | M-Sport brakes | 688 Harman Kardon | 494 Heated Seats | 610 HUD | 322 Comfort Access | 5AC High-Beam Assist | 609 Navigation Professional |
      10-08-2017, 09:52 AM   #18
Incontinentia Buttocks
Incontinentia Buttocks's Avatar
3336
Drives: M135i
The short answer is "yes". From an engineering perspective they are also undesirable, as they will increase the stress on suspension components.
Why not just get wheels with the correct offset if you want them to stick out more?
      10-08-2017, 12:23 PM   #19
XutvJet
Potato, potuato. You know what I meant
      10-08-2017, 12:25 PM   #20
XutvJet
The problem is these cars are designed with a specific offset in mind. When you start pushing the wheels outwards, wider tires, etc. you're going to feel the consequences. It's not a huge deal, but to say there are no side-effects would not be a true statement. People love to overstate the positives of mods, but rarely elaborate or bring to light the negatives. The negatives may be less apparent if you're running less aggressive tires as the softer tread blocks will reduce some of the dartiness, trammeling, etc.
      10-09-2017, 03:35 AM   #21
JJS
New Zealand
71
Offset matters more on the steering axle. The kingpin angle of the strut combined with wheel offset determines the scrub radius. When I was in the habit of changing wheels for a more aggressive stance on my earlier cars, I almost always found the car handled best on OEM offset wheels.
      10-12-2017, 09:36 AM   #22
3336
Drives: M135i
You didn't read my post in the way that it was intended.
Best option? Leave as standard.
Second best option? Change wheels.
Worst option? Fit spacers.
