BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > Question RE: TPMS valves
      10-06-2017, 09:46 AM   #1
Dave_3
Dave_3's Avatar
Scotland
183
Drives: F32 430D sDrive Msport
I have an early 2014 430D (one of the first).
They changed the TPMS system a month or so after my build, so my car does not have the actual tyre pressures displayed in the I-drive.
I take it that my system only monitors wheel revolution disparity on an axle to detect a puncture and does not need any dedicated TPMS valves on my Alloy wheels ?
Just speccing up a set of winter wheels ....
D.
Escort Mk1 RS2000 (2.1 2x44IDFS, BVH, Kent FR32, 5spd, 180 BHP) : Fully Loaded F32 430D M Sport sDrive : Previously Full-Spec 335D E92 2006 : Capri MK1 full rebuild in progress
      10-06-2017, 09:57 AM   #2
Smee
Smee's Avatar
245
Drives: 435d
you need the TPMS with the rubber shaft i believe
Current : F32 435d M Sport - Mods : HR Sport Springs, 20" Veemann V-FS23 in Gun Metal, M Performance Body Kit, Pedal Covers, Eurspec CF Mirror Caps, More-BHP remap 364 BHP 741 NM, M4 Under Chassis Brace, 15mm Rear ARB, 8.8" Screen Retrofit and LCI Stereo facia Retrofit
      10-06-2017, 10:17 AM   #3
troggy1969
Drives: 335D MSport 2016
Look at your existing wheels, if they have rubber shafts then you don't have tpms monitors on your car, just the revolution monitor so you can fit any valve.
If you have metal valves then you have monitors and if you don't fit them you will get a warning when you start (it doesn't affect performance). I had the warning last year but I've bought a set of monitor to fit this year to be on the safe side.
      10-06-2017, 11:07 AM   #4
robbiep
Drives: F31 325d M Sport
If your car does not display the tyre pressures then you only need standard 'dumb' valves.
      10-06-2017, 06:27 PM   #5
bmnut
Drives: A blue/green one!
This ^ !
